Terradome3 - Changing defaults
dHandledHandle Posts: 617
edited December 2016 in The Commons
@traveler or anyone else who knows.
Is there a way to change the default settings for the Bzone to eliminate the haze in the distance?  I would like the distant hills etc to be clear, and not in the default atmospheric haze, but I can't locate any adjustments for that.
Thanks!
Post edited by dHandle on
  • The atmosphere doesn't load with the BZone, does it? Are you loading parts or assembled scenes?
  • dHandledHandle Posts: 617
    Hi Richard,
    The amosphere is separate. I'm just loading the BZone to serve as background for a separate scene.  It has a default atmospheric haze that I would like to remove.
    I was able to adjust the diffuse color to get the desired effect and eliminate the haze.  It was found in surfaces>TD3_BZone>terrain>diffuse>Base Color A (sides) and Base Color B (top).
    By making those colors darker, the haze effect was minimized.
    Thanks!
  • Oso3DOso3D Posts: 15,118
    I don't think that's a haze effect, but happy you found a satisfactory change.
    Post edited by Oso3D on
