png sequence
Hello! I need to deliver an animation in PNG sequence, 32 bit, with alpha coat... do carrara 8 pro can do that? ... and if not, what is "close"??? thank you!
Hi Celmar! PNG inside Carrara8pro is 8-Bit per channel = R*G*B*Alpha = 32 Bit ! Close to that is RPF-Fileformat, sequenced PSD or uncompressed MOV - no OpenEXR etc. available. Sequenced PNGs are the best option. Greetings tezen
Yes, You can render an image sequence in PNG format.
And with alphas!
