animation
Hello
I am still using DAZStudio 3.1.2
I want to create an animated file which contains several different clips
suppose I create the first animation ex frames 1 - 30
Then I create the second animation, let say : frame 40 - 60
the key frame #40 changes the original key frame #30
In other words the two clips affect each other
What shall I do to create unrelated clips in one file only ?
Thanks in advance
  • MarcCCTxMarcCCTx Posts: 955
    edited December 2012
    You could probably lock the last frame of the first animation, select every object and subobject and set a key frame. And then do the same thing to the first frame of the second animation. Otherwise, you'll have the object tweening from their last keyframe.
    I admit this is a pain in a complicated scene. You might consider doing a Save as (of course that doubles the storage requirements)
    edit: spelling
    Post edited by MarcCCTx on
  • jean_paul_baconjean_paul_bacon Posts: 55
    Maybe saving as an animated pose preset in a personnal library, for all your animated moving object. Like, my poses preset, scene 1 - take one, this is what I do for the moment.
    Post edited by jean_paul_bacon on
  • edited December 1969
    edit: spelling
    It seems it works, thanks a lot
