DAY-SEVEN-BONUS code
Don't know if any one will be able to respond to this in time but what is the coupon code for the day seven bonus? I tried using 'DAY-SEVEN-BONUS' but it does not work
  • 3Diva3Diva Posts: 12,058
    It is DAY-SEVEN-BONUS - as you said. It's likely that you just have something in your cart interfering with the code.
    I would make sure that all seven of your picks are, indeed, in the Christmas Week Bonus Selection. Then make sure that there is nothing else in the cart to test it to make sure that they are working - only then would I add other things to the cart. And if something you add in the cart suddenly makes the seven items not free anymore, you've found the item that is causing the issue.
    Well it should. You must have only 7 bonus items in your cart from that list though, unless you have a qualifying new item to purchase then it can be 8 items. If you have an extra item it will not set the price to 7 free items & then you pay for the extra item; it will have you pay for all 8 items (9 items if you have qualifying new item).
    Day-Seven-Bonus
    Copy & paste that above to your coupon code form & apply and it should work if you have 1 - 7 freebie items (or up to 8).
  • FabeFabe Posts: 232
    yeah I see what my problem was, I had 8 instead 7 items. thanks guys
  • One other possible gotcha — earlier today when I was building a cartful including the Knight offer (so I got one of the free armour sets) I decided to buy the texture set to go with it. Then later I noticed that same texture set was in the bonus category. If you don't notice this happening, it's easy to hit the "one too many" error.
