Duplicate formulas
Hi folks, I am getting this error " Duplicate formulas found in files, make sure that the content is properly installed"
Dazstudio is installed with a min om of content, because the reason for reinstalling was that i got this error in the last installation also.
Everything is installed with the install manager, the error came with daz own genesis3
Any ideas?
Check the log file - Help>Troubleshooting>View log - immediately after loading the figure. If you scroll to the end and look backwards you should find a fuller version of the message, with the name of the problem proeperty (or properties). There will probably also be other errors, about not being able to find certain targets for formulae - that's usually OK if so, those are corrective links for items you don't have installed so the lack of a link doesn't matter.
