Dynamic Sheets
ArtbyphilArtbyphil Posts: 97
Hi
I got the dynamic sheets product as I just need a sheet to drap over various objects. Are there any instructins on using this? it says there are several diffrent sizes but it only seems to have the kingsize one and cannot figure out how to get the others. Also trying the one that I could find I draped it over a cube primative to try it but  soon as I touch or move anything it jumps back to the start and automatically goes flat again!
Does anyone know what I'm doing wrong.
Post edited by Artbyphil on
  • thd777thd777 Posts: 947
    The different sizes are set in the dynamic clothes control panel. There is a list where you select the size.
    The draping will always reset when anything colliding with it is moved. If you are done draping and want the draped sheet to stay the way it is, you need to freeze the drape. The command is in the top right menu on the control panel.
    ciao
    TD
  • ArtbyphilArtbyphil Posts: 97
    edited December 2016
    Cheers I'll check it out. Been using Daz Studio  for ages but actually not used the dynamic clothe before !
