Fur Jacket
beachlegsbeachlegs Posts: 532
I am looking for a fur jacket for k4, Here is a pic of what I am looking for if possible.
360 x 253 - 23K
  • beachlegsbeachlegs Posts: 532
    Sorry this is in the wrong place was ment for General freebie section.
  • fixmypcmikefixmypcmike Posts: 19,743
    Moved to the Commons, as it is a request for, not an offer of, a freebie.
  • JOdelJOdel Posts: 6,322
    If you've got Furrify, there are several fur shaders which could be applied to an ordinary jacket. You can't see the fur until you render it, but it does quite a good job.
  • FSMCDesignsFSMCDesigns Posts: 12,859
    Or you can just use displacement. this was an image to see if i could get semi realistic looking fur with displacement and it wasn't hard. then again, this was rendered in Lux, but shouldn't be much different in any other renderer that uses displacement. just create a noise map and tile it about 20 times and subdivide the jacket a couple of times.
    726 x 903 - 679K
    Thank you all so much everyone...FSMCDesigns I am not sure what displacement is and have no idea how to create a noise map ect as I am not Technical
    with poser yet but I will have a nosey and see if I can work it out myself as I like to learn that way...Thank's again everyone :)
  • Dani Foster HerringDani Foster Herring Posts: 275
    This blazer, though not perfect, is sort of the right shape.
    http://www.renderosity.com/mod/bcs/k4-girls-japanese-uniform/83313
    For the fur, maybe WhopperNnoonWalker-'s Store? Everything is on sale and they do have some fur textures.
    http://www.renderosity.com/mod/bcs/index.php?vendor=308023
    Hope this helps. Dani
    Thank you so much Dani I am sure I can work with them, The fur look's wonderful will give them a try
    as I can alway's use them on other item's...Thank you :)
