Remove old script from Script menu Bar?
jcbunn
The Script Menu Bar can have many scripts with the same name, its kinda confusing, so how do I remove the old scripts from the Munu Bar? Thanks
Post edited by jcbunn on
The script file is in:
...\AppData\Roaming\DAZ 3D\Studio4 Public Build or Studio4
Well it could be in both.
The file is called: customactions.dsx
Back it up first (copy and paste).
Look at the image, you'll see V3Digitimes is the last script; and when I copy and paste the text from the file into notepad++ it displays it in a nice readable format
You can try removing it, to see
<CustomAction Accel="" Icon="E:/Documents/ AND THE REST "/>
... Which should work, but I have had issues - just be sure to back the file up first.
Edit:
Personally, this script option should be better, and certainly the removal should be, but not aware of anything.
A safer method would be to go to Window>Workspace>Customise, in the menus tab on the right expand Main Menus>Scripts, right-click on the unwanted items and remove them. You could also remove them from the the available custom actions if desired, by looking under Actions on the left and again right-clicking.
Thank you both!
Adding this to the "useful things to know" list
Thanks Richard, checking this out.
Damn that rocks, I've checked it out. I take back what I said, it is very much better.
