Poses question
Can you use G3M poses on G3F? Also G2M /G2F poses on G3M/G3F? If yes how?
  • scorpioscorpio Posts: 8,534
    Yes, for G3M onto G3F select the figure and apply the pose.
    G2 to G3 is different they don't work as easily I use this to convert the poses
    http://www.daz3d.com/genesis-2-to-genesis-3-pose-converter
  • DDCreateDDCreate Posts: 1,424
    I've never had a problem using a pose set on a same Gen character either (G3M on a G3F and vice versa). And the pose converter does work pretty well. Sometimes you just have to do a few slight adjustments but nothing that takes longer than 20seconds.
  • barbultbarbult Posts: 27,680
    My experience with the linked pose converter is that it does not work with poses that are installed with Daz Connect.
    Didn't know that, as I don't use Connect- thanks its useful info to have.
