Problem with keyframes changing
So I have two keyframes in which I want my male model to move in Z axis. I create the starting position on keyframe 1, and create a new keyframe on frame 10 which will be the end position. Problem is, whenever I change the position of my male model on keyframe 10, it also changes the position on keyframe 1 to the exact same position, depsite having already created a keyframe there. So obviously nothing moves. Does anyone have any ideas what's going on?
Post edited by palmer_aif_1b587f57f9 on
Did you have the node (bone or figure) you are using to move the figure selected when you created the other keyframe? The Create Keyframe command applies only to the selected node(s).
