Creating sub-categories
iruchemairuchema Posts: 0
Hi!
I have a problem with the categories. If i try to "create a category from folder" on any on the folders-subfolders of my structure in the content library, it says nothing but dont create the category. And if i try to create a sub-folder from the "Categories" folder, i receive the error "unable to create container".
Any help? Thank you!!!!
    Are you seeing any categories at all?
  • iruchemairuchema Posts: 0
    Thank you for answering :)
    None. "Products" is empty also.
    Okay, that means the CMS isn't running or is being blocked from communicating with DS. What Operating System are you using? Under Windows, shut down DS and go to "Start > Programs > DAZ 3D > DAZ Content Management Service > Start CMS" to restart the CMS. Then restart DS and see if Categories are back.
    Ok, that worked, but i dont understand it... I could have sweared that i saw the CMS service running in the control panel....
    Well, thank you very much!!!!!!!!
