error loading file
Hellcat
trying to load the Darius 6 mat files and get this error. i'm not sure how to read the log to determine the issue. any help is appreciated.
txt
txt
log.txt
173K
What are you trying to load, and what do you have selected when you do so?
i got the legacy UVs converter to use G2M textures on G3M. trying to load Darius 6 mats onto Genesis 3 Male. all other mats work except the skin
What error do you get? And does anything happen after that, for good or ill?
"error loading file. see log" and nothing happens at all. log attachment in first post
What is selected in the scene?
the figure i want the skin on... as i said above, genesis 3 male
OK, I thought maybe it was a hierarchical preset and wanted you to select the base figure but that doesn't appear to be the case. Sorry, I don't know what the issue is - you might want to try one of Cayman Studio's threads, if there is one for this set.
