Does Ginger for Genesis 2 need Stephanie 6 to work?
Hello! Still learning here about Daz! Thanks for all the info!
Does Ginger for Genesis 2 need Stephanie 6 to work? In the info of ginger it says "Ginger is a high quality character for Stephanie 6, a premier 3D model" but in the information it doesn't say Stephanie 6 is required... In contrast with
FW Alfred HD for Michael 6 that says in the information that Miachel 6 is required. Whats the difference?
  • fixmypcmikefixmypcmike Posts: 19,718
    I see Stephanie 6 listed as required.  The character uses the Stephanie 6 morph, so it won't look the same without Stephanie 6.  The texture doesn't require Stephanie 6.
  • HavosHavos Posts: 5,676
    Ginger uses Stephanie dialed to 0.5, below is what she looks like without Stephanie, so still pretty cute, imho.
    1024 x 1024 - 83K
    She requires Stephanie 6 to match the shape she has in the promo pictures. But it is not absolute requirement. As Havos posted, you can still use the figure without it, she will just look a bit different without the Stephanie 6 morphs. The skin will work on any Genesis 2 female shape you create, too.
    This applies to many other figures in the store that have requirements. They will all generally function this way. So Alfred 6 will be like that as well.
  • CybersoxCybersox Posts: 9,733
    The one thing to remember is that there ARE some characters that require a specific base's UVs as well as the morphs.  This isn't a big problem with Genesis 3, where the majority of the PA generated female characters have used the base G3F and G3M UVs, with a handfull using V7, but with Genesis and early Genesis 2 there are a number of characters that require a UV set other than the base figure or Victoria/Michael.
    edited November 2016
    They are very few in number, and even back then normally only happened with PA characters that appeared in the corresponding characters starter/pro bundles. The exception is M5 and V5, where there were a lot of characters that used them, but these uvs where bundled into Genesis 2 base, so should be available to all.
    Post edited by Havos on
    Available for use on Genesis 2, you would still need to buy M5/V5 to use them on Genesis. (or else use Map Transfer).
