Can you use poster contents in Daz?
Hi :) can you use poser contents in Daz? And if yes are there like limitations to what you can do if you use it in poser and not in Daz? :)
  • The only things you can't use are poser shaders. Other than that if you're willing to adjust the textures, everything works.
  • srieschsriesch Posts: 4,243
    Double-check that I'm not wrong, but I believe you also can't use poser dynamic hair, poser dynamic clothing, or poser (python?) scripting.
  • LeanaLeana Posts: 13,502
    Not everything, materials are not the only difference:
    • Poser dynamic hair won't work at all
    • Poser dynamic clothing will only be a static prop in DS
    • Figures using Poser weighmapping (introduced in P9, used for example for the Poser version of Star! or Dawn) or capsule rigging (introduced in P8 and barely used, but still) will load with lots of error messages and distort horribly if you try to pose them, you'd need to re-rig them to use in DS.
    • DS can't use morphs provided as PMD injection
    • Poser lights are rather useless in DS as most of their properties will be ignored. You can usually get something out of them with lots of fiddling.
    Now besides that most Poser content will indeed work.
  • PMD morphs should load with figures, but not from poses or props.
