How to get rid of 4.9 confiuration error?
I installed the latest DS 4.9.2.70 a few days ago. I connected ok, but every time I open it I get the same message.
'Configuration of the system has changed. To use content installed using DAZ Connect, the content owner must re-authenticate'
I've tried connecting repeatedly, inputting my serial number, and choosing Work Offline, but the message appears every time I open DS. I have no other versions of DS 4 installed (I uninstalled the beta before installing the release)
Before I uninstall it completely and go back to 4.8, I thought I'd ask for suggestions. Also, does anyone know if there's a registry key I can edit to fix this?
TIA
mac
  • Richard HaseltineRichard Haseltine Posts: 111,359
    edited November 2016
    So you do actually connect before later selecting Work Offline? Is it forgetting your serial number too, or is that sticking?
  • macleanmaclean Posts: 2,438
    I've tried it two ways, Richard
    In Menu> Connect Login the Work Offline option is always grayed out, so I log in, then choose work Offline. If I re-open DS later on (when I'm offline), I get the error message.
    If I try Help> Register DS, that gives me either Connect or Work Offline> Serial number. If I choose Work Offline, the serial number is always blank and I have to input it. If I choose Connect, I get the error message later on.
    Earlier today I tried Content> DB Maintainence> Update Metadata and this evening I didn't get the error message, so that might solve the problem. I'll know tomorrow when I open DS.
  • I have had DS forget my serial number (and require revalidation) occasionally - but not every day. It's possible that whatever triggers my occasional hiccup (which I have told the devs about) may be happening on a regular basis to you - in which case the devs' odds of figuring it out are greatly increased. If it does happen again, please report it.
    Well, as soon as I opened DS this morning I got the error message again, so updating metadata didn't help.
    I'll submit a bug report before I uninstall it and go back to 4.8.
    Thanks for trying.
  • Is it asking for your serial number too, or just saying there's been a system change?
  • AndySAndyS Posts: 1,449
    Hi Richard,
    have got the same problem for several months.
    As far as I know, this problem appeared with the official 4.9.2.70 release. For some weeks, everything is fine, then it appears. Only telling that a configuration had changed and you should re-login. After doing so (with possible corruption of your PostgrSQL-CMS), for some weeks it keeps on being OK. But after several weeks (round 2 or 3) it appears again.
    I thought it was already reported here somewhere in the depth of this forum.
  • Posting to the forum isn't a report - bug reports are tickets for Techncial Support http://www.daz3d.com/help/help-contact-us
    Hi Richard,
    all users of 4.9 have that problem.
    I'm sure, that at least one has reported it. wink
    (see the discussions of the last month)
    I submitted a bug report and I already have a reply. They said that using the login button on the Smart Content pane will solve the problem. (By the speed and tone of the reply, I got the impression that this is a common issue).
    I've tried it and I'll see how it goes over the next couple of days.
    Richard - No it doesn't ask for the serial number - just gives the error message every time I open DS. But if I go to the Register dialog, the serial number is blank (despite me having entered it multiple times previously)
  • Ah, I see - I thought you were getting the issue i occasionally have where launching DS doesn't - instead I get the request for a serial number/connect to Daz as if it's a clean install.
    After logging in through Smart Content 2 days ago, I haven't seen the error message again. So it appears to be the correct way around the problem.
    This may be fixed in a future version, but in the meantime, it might be an idea to add it to the FAQ.
    Just one week passed a here it is again.
    Really bothering !!
    Really bothering !!
    Considering the regularity with which you seem to be suffering this problem, I think it's time that you consider that maybe, the source is not Studio, but rather something in your configuration/software on your machine, other than Studio?
    Hi mjc1016,
    you should know it better, cause there were older discussions about this effect - even you being involved.
    --> http://www.daz3d.com/forums/discussion/120976/configuration-error
    Post edited by AndyS on
