Configuration Error
Hi,
since the use of DAZ 4.9 at the startup I often get the message shown in the attachment.
OK, if I re-login, it is OK for several days / weeks. But then, suddenly the message again starts to appear.
I only completely normal open and close the application. As I said: for a certain time it works fine, then suddenly I have to re-authenticate again.
I didn't change anything. Who changed the configuration of the CMS?
Dear DAZ Team: Are you playing around on your server?
WHY ??
What's going on?
506 x 97 - 13K
    What version of Studio? (full version/bit)
  • AndySAndyS Posts: 1,449
    Please see opening post.
  • 4.9 isn't specific enough - Help>About Daz Studio will give you the full version number - 4.9.x.y.
    edited October 2016
    Hi Richard,
    it is the latest officially delivered 4.9.2 General Release, of cause.
    I'm not a beta tester!
    Post edited by AndyS on
  • So 4.9.2.70? And you don't have an earlier version (of 4.9) too, or aren't running it if you do? That version should have the more robust system verification code - earlier versions were prone to deciding the system had changed when it hadn't, and running one of those will always cause 4.9.2.70 to decide the system has changed as the two systems conflict, but you should not be seeing that behaviour in 4.9.2.70 (though I am aware of another person who is, so you wouldn't be alone). What security software are you running?
    Hi Richard,
    of cause it is 4.9.2.70, the latest officially delivered General Release. DIM didn't show up any new update since !!
    So and as I already told you too, there isn't any security software running due to the total incompatibility of PostgrSQL.
    As you confirmed, I'm not alone with this problem, so I assume the bug is being worked on?
