ERC FREEZE
I have 4.9 64 bit DAZ Studio Software installed and I noticed that the ERC settings or maybe just the dialog box is different in this version and when i try to run it after creating a slider head morph as I have generally done in the past , I don't get any recognition of the utility being run - Of course if I go back and double click the slider it will move but the head morp doesn't occur. Is their a software error or variable seting I could be missing or does any one know if theirs a tutorial showing these settings for just ERC so I can go back and check my work - -
R-click on your new property and choose “ERC Freeze” is all I have here but it use to be enough - Seems like you just checked the Node 1 property and selected OK in the older version - It's been a while since I created a slider though
So you have the controller and the morph set to the values they need at the limit - usually one will be at 100% - and then you right-click on the controller and do ERC Freeze?
I think every thing is set right - I'll go back through it though - The 100 percent value could be the one I'm missing but I thought it was a default.
Type - Modifer Shape
Value - Minimum Set at 0 and not -1 or what ever
Percent - = No
ERC Freeze needs the controller and at least one other property, to be the controlled property/properties, to be off their zero values - the operation links the two so that as the controller goes away from zero the controlled properties move away from zero in proportion.
DAZ manual
start reading here http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/rigging/tutorials/creating_erc_pt1/start
Why can not acces next ERC freeze manual page?
Permission Denied
Sorry, you don't have enough rights to continue.
http://docs.daz3d.com/doku.php/group/education/kats_sandbox/creating_erc_two/start
I would expect a "sandbox" to be an area that is used for drafts, so it may simply not be ready yet, but I will ask.
How to do ERC freeze.
