LINERENDER9000?
Ok, so I was thinking about the day my computer started crashing everytime I try to render in IRay, and I realized something.. The last purchase I made just before that became a problem was LineRender9000... http://www.daz3d.com/linerender9000
I have no idea how to use this spacific product. I just know, thjat theres some way to make it render my images in a flat cartoony style image rather than a 3d one... Could it be possible, that i just need to make some adjustments some where. like maybe its trying to render my images in Lineart and 3d at the same time or something?...
Where do I go to switch between line art and Photo real 3D?
  • kaotkblisskaotkbliss Posts: 2,918
    You should be able to test this theory by uninstalling linerender and seeing if iRay still crashes your pc.
    If your pc still crashes, then there's something else going on, if it stops then there's some conflict with linerender.
  • Linerender uses scripted rendering - if you haven't set it on it doesn't do anything, it isn't a plug-in, so I doubt it is the cause of your crashing. If you get crashes while rendering, especially in Iray, I would suggest using GPU-Z to check your temperatures - it sounds like a hardware issue, as if a fan is not working or the heat sink is not properly in contact (or as if some GPU RAM has gone bad).
