converting stiletto heeled boots into thick-heeled boots
sriesch
in The Commons
While I could of course cobble something together from primitives or perhaps reuse another shoe, I wondered if anybody had created (or found) a wide heel prop that would likely work for converting multiple high-heeled boots from having tiny stiletto type heels to thicker, marginally more sturdy ones.
You could always use the Geometry Editor to select the heel, hide and delete the rest of the shoes (right-click context menu), load each separate heel as a prop, parent to the shoes, apply a Push Modifier to thicken (and lengthen) the heels, then use a Push Modifier Weight Node (Create menu) and the weight-apinting tools to remove the base of the heel from the effect, so you got the thickening without the lengthening.
