HELP!
ArhainArt
I am thinking my lap top is incompatible with IRay engine. See attached. Image on left is before rendering, right is after. Only happens when rendering in IRay. 3Delight works fine.
600 x 304 - 57K
Your anti-virus application has deletd a needed file - freeimage.dll. Kaspersky does this, as does one of the others. If you can, restore the file from the quarantine/vault area, otherwise reinstall DS, then make sure the file is marked as safe so it doesn't get removed again.
Thanks. In my case it is ZoneAlarm.
