batch render processing ?
hello all.
is there a way to batch the processing of rendering of several différent scene ?
like:open scene 1,switch camera view,render,save render file,close scene 1,open scene 2,switch camera view,etc....etc......
my rendering of only one scene take between 50min and 1h30,then it will nice to do automatic render processing the night when coomputer not used.
  • JimbowJimbow Posts: 557
    'Batch Render for DAZ Studio4 and RIB' is available here. Doesn't look like it does iray.
    'Batch Renderer for Daz Studio' by NDimension does 3DL and iray rendering, available at Renderosity.
  • keraberakerabera Posts: 146
    ok thanks
  • HoMartHoMart Posts: 489
    I use this fine tool very often, it works fine with IRAY ( you just can´t use the implemented " renderquality presets" - they´re for 3delight)
    Workflow:
    create multiple scenes and save them.
    when finished start 'Batch Render for DAZ Studio4 and RIB' , select the .duf files you want to render, select the output and temp path -> hit render
    when using it with IRAY it will render with the settings you saved with your scene (keep that in mind when saving your scenes)
    Only "advanced render settings" like: usage of GPU or CPU for render or threshholds for the texture compression will stay the same all the batchrender time.
    @HoMart - Thanks for that info.
    ah shit that doesn't work with the scene which have the start error "duplicated formulas detected",and of course i have this on all my character.
    angry
  • Any idea, how to get rid of that: duplicated formulas detected
  • Richard HaseltineRichard Haseltine Posts: 112,346
    You need to figure out which item is causing the error, and hope that it can be updated. The log file (Help>Troubleshooting>View log) should let you see the name of the problem file(s).
