DIM partial customization? - SOLVED
DiomedeDiomede Posts: 15,457
edited October 2016 in The Commons
I bought several tutorials that are video format. They will take up a lot of space so I don't want them on the same drive as my other Daz3d purchased content.  Is there a way to direct DIM to put one category of content on a separate drive?  This not for a separate program like Bryce that can be directed to another location.  Or, should I download the tutorials manually to do that?
Post edited by Diomede on
  • namffuaknamffuak Posts: 4,513
    Fire up DIM and click on the gear icon to get into the setup tabs.
    Select the installation tab. Click on the '+' sign (bottom left) to create a new entry. Call it 'tutorial' or anything else that makes sense to you. Fill in the path you want your tutorials installed to. Click accept. Click the green accept.
    Now, on the Ready to Install tab, click on Show Details (bottom right). Click on the Content Path Shortcuts drop-down and select your tutorial entry. Select your tutorials. Start Queue. When finished, reset your Current Path Shortcut.
    Thank you.  That should be exactly what I am looking for.
