Dynamic Cloth Control Install - Solved
abartleyabartley Posts: 38
 Purchased Dynamic Cloth Control.
How do I get this installed in Daz?
I have the serial No from my account but the plugin does not show in Daz 'About Installed Plugins' so I cannot register it.
Only 'Dynamic Cloth Plugin - Basic' shows which indicates to me that it is not installed.
I tried clicking 'Download and Install' on The product in my Daz on-line library shows to be 'Install Manager Ready' so I clicked on  'Download and Install' which took me to the Download Manager but nothing more happened.
Any advise appreciated.
Post edited by abartley on
  • If it is listed as installed in DIM uninstall and reinstall - the roblem may be that you told DIM to install both together, but since the control plug-in is much smaller than DS it was finished first and then replaced with the Basic plug-in when DS itself installed. The Control plug-in must be installed after DS to avoid this.
  • No...it is not listed as installed in DIM......Ive looked under both 'DS4_Dynamic Clothing Control' and 'Dynamic Clothing Control For Daz Studio 4.9+' but its not to be seen.
  • Are any plug-ins listed? Check that yoiyu hadn't set it to Hidden (use the Display Hidden box at the top of the Ready to Download tab) - you might have done so to get it out of the way when you couldn't use it.
  • I assume you mean are any plug-ins listed within Daz Install Manager?
    Well, frankly it does not appear so.....for example, I cannot find 'Genesis Generation X2' in DIM (which is a extrs purcase add on beyond vanilla), but it is alive and well, registered and working in Daz.....so should 'Dynamic Cloth Control' be showing in DIM at all?
    I clicked 'display hidden' as suggested but nothing comes up
  • frank0314frank0314 Posts: 15,120
    Post a screen shot of your Downloads tab so we can see if something isn't checked that should be.
  • fixmypcmikefixmypcmike Posts: 19,743
    On the "Ready to Download" tab click on "Download Filters" and make sure "Plugin" is ticked.
  • OK........check these out........and thanks for looking folks :)
    1920 x 1080 - 375K
    1920 x 1080 - 74K
  • Oh...and the 'Ready to install' on DIM is this....see attachment.
    This couldnt be the problem....could it ?
    1920 x 1080 - 119K
  • On the "Ready to Download" tab click on "Download Filters" and make sure "Plugin" is ticked.
    Composed and posted last comments while you were answering.......
    You got the problem.........plugins was not ticked.
    Thanks ever so much everybody for helping me get a solution :)
    Well it downloaded but did not show for registration.....so I unistalled and reinstalled as suggested:
    Anyway it is now reinstalled, registered and operating showing all the fuctions now............so once again thanks for the advise folks:)
