Geisha Builder for Genesis 2 Female, Genesis by DraagonStorm
ALLIEKATBLUE
in The Commons
I just picked up the Geisha Builder for Genesis 2 Female, Genesis by DraagonStorm and it says that the overlays are designed for use with the V5 UV mapping. I have so many characters, V4, V5,Genesis, V6, Genesis 2 V7, Genesis 3. How do you know what UV is being used. I used it on FWF Mayuree for Mei Lin 6 and the description says This product uses the Victoria 5 UV Maps. But when I appy the Geisha makeup, the lips and the torso materials are a little off. Is there some adjusting that can be made to line that stuff up? First I used the Geisha Builder for Genesis 2 and then used the one for Genesis. Using either script, materials are not lined up on the character.
You can check the UV set used by looking at the Surfaces pane and selecting a skin surface in the Editor tab (in almost all cases the skin surfaces will use the same UV set throughout). Mayuree is certainly showing as using the V5 set when i do that.
I know but Mayuree does not line up with the Geisha makeup
