Can't find !Iray Uber Base
I'm using Daz Studio 4.9 Pro and I've been trying to learn about shaders but I keep running into the problem that the files people refer to don't seem to be anywhere in my content folder. I've seen instructions to go into "Content Library > Shader Presets > DAZ Uber" but within the "Shader Presets" folder I don't have a folder called "Daz Uber". I have one called "Uber" but it doesn't have the same content that I seem to need. In particular the file "!Iray Uber Base" seems important, but I can't find it anywhere (including with search functions). Am I just being thick? Could it be somewhere else, or not installed at all? Is there a place I can download the Uber shaders or something? Thanks very much.
  • WilmapWilmap Posts: 2,917
    Mine is in Shader Presets/Iray/Daz Uber.
  • edited September 2016
    I don't have an Iray folder in Shader Presets. A search in file explorer didn't turn up a folder that looks right either. Thanks for the response, though.
    Post edited by jazzcmshine_1869cb6e81 on
  • SzarkSzark Posts: 10,634
    Did you install the Default Resources for DAZ Studio whuch is a separate file
  • FishtalesFishtales Posts: 6,233
    Are you using the 32 bit DAZ Studio or the 64 Bit. Iray is only available in the 64 Bit version.
    surely that is just the render engine, the shaders should still show up if installed.
    That's true, wasn't thinking :)
    I am having one of those days too, must be the weather. :)
  • Ah, okay, it looks like it was the default resources download, thanks.
    sweet
  • Did you ever resolve this? I'm having the same problem.
  • GordigGordig Posts: 10,805
    Looks like downloading the Default Resources solved it for the OP. Have you done that?
    That's what I'm trying right now. I'm also downloading the latest version as I had version 4.9 installed.
  • Yay! It looks like those shaders are in my directory. That's fantastic!
