Setting custom file paths outside of Daz
Stryder87
I'm rebuilding my main computer (doing it on a VM first, then I'll sysprep it and slap it on my main hardware) and ran into a small problem after I installed Daz. I was going to set up my custom file paths, but the program won't start due to the VM having limited video capabilities. Is there a configuration program in Daz that one can run seperately to set file paths in Daz without running the main program? Or, are there registry entries that I could adjust for that (a quick look turned up nothing obvious to me)? If so, where would those keys be? Or is there a file that could be edited? I just want to set this all up before I transfer the image from the VM to the destination hardware, run Daz and have it freak out that the file paths aren't there and start putting stuff in all the wrong places.
If you can run DIM, there are sample scripts for transferring the paths to DS. (You'll need to do the Connect path separately, however).
DIM runs and I've set that. No idea on the sample scripts though. Are they on the Daz site?
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/start
Look under "Directory Mapping".
Nice! Thanks.
