Is There a Way to Scale the Diameter of G3 Eyeballs? SOLVED
xyer0
I'm working on an extreme morph with wide eye slits. Unfortunately, this causes empty space at the outside corner of the eye. If the eyeball could be scaled (Size) and translated (Depth), then I could remedy this. It's probably something simple, right?
Post edited by xyer0 on
Select the eye in the scene tab, then go to the parameter tab and scroll down to "scale", You can either scale the entire eye, or each axis.
EDIT: For transferring it backwards, you'd need to unparent the eye and then move it backwards, and reparent it, but I have no idea what that would do to any bones for eye movement.
Thanks, Bee, that has to be it. I was trying to do it through morphs. Have a pleasant evening.
Not quite sure why you need to unparent the eye, I've never done that just used thex,y and Z dials to move the eye after scaling, it is usually a good idea to lock the dials as some poses and restore can reset the scale and translates.
Thanks for the heads up. I will do that right now.
