Pose transfer
Hi,everybody how do you do?
Probably is a noob question but it's possible to transfer a pose from genesis 2 to a genesis figure?I tried with genx2 but it doesn't seem to work.
Really hope someone could help,'cause this is a problem i never managed to get sorted
thank you very much
  • JUJUJUJU Posts: 1,133
    I think you need a pose converter but I don't know if there is one for G2 -> G1 ....I only know it from G1 to G2 ...
  • You can just apply a Gen 2 Pose to a Genesis 1 model. The result will be a similar pose.
    If I recall correctly, Genesis has a similar rig as Genesis 2 (albeit with a few changes) so the result will be similar. You can use the Content Library Pane to access your Genesis 2 poses (usually it is in My DAZ 3D Library > People > Genesis 2 > Poses > ....) Just select your Genesis figure and double click on a Gen2 Pose and it should be done.
    You might need to move the body parts a bit, but it should not require much change.
    This will not however work with Gen 3 - the rig has additional bones in the thighs and arms, which might cause weird bending to happen.
