Is there a specification for DUF files available?
Singular3D
I think about writing an importer for Cinema 4D. Importing with FBX works, but there are some adaptions needed, as Cinema 4D ignores the pre/post rotation of joints.
Unfortunately there are no sub-components defined in the FBX including information about DeltaAdd, Multiplied and Keyed. So all these things have to be set manually in order to be able to use a figure similar as in Daz Studio. This is certainly a long term task and features will be implemented one after the other.
Just a question...
http://docs.daz3d.com/doku.php/public/dson_spec/start
Thanks a lot for the fast reply.
Hi,
I cannot access the uv_set definition
http://docs.daz3d.com/doku.php/public/dson_spec/object_definitions/uv_set/start
Am I the only one?
Update: It seems that the PDF export works though.
Probably means it's being modified. I think rbtwhiz never sleeps...
Sleep is overrated anyway :)
