Bed creasing
Second Technician Rimmer
Is there a known way to "crease" a matress under the pression of g3 sitting/laying on top of it without using a bed that has the morphs built in?
In DS you could use a dformer to alter the shape.
as long as there was enough mesh resolutuion - if the top of the matress was a single polygon you'd be stuck.
I often select the bed, go to edit -> object -> geometry -> apply smoothing modifier, then have the bed collide with the figure
