My Libary folder
I have put many items in the my libary folder but I am only seeing 2 of the items I have put into the my libary folder. Is there any specail thing I have to do to get daz to see all the other items? I downloaded things for gensis charaters and other charaters.
  • barbultbarbult Posts: 27,499
    We need more specific information to help you. What do you mean by "seeing" the items? Are you looking for them in the Content Library pane or the Smart Content pane? Are you installing products from the Daz store or from other places?
  • 3Diva3Diva Posts: 12,058
    The My Library folders can be tricky. If products aren't put into the right folders often times they do not show up inside Daz Studio. I found this out the hard when when I downloaded a bunch of freebies and put them in the wrong folders. I'm trying to deal with the mess and get things in the right place, but it's a major pain. It would have been nice knowing these things when I first started, but it's all "growing pains" that comes with learning a new program. The problem with a lot of the older content and a lot of the freebies is that many are packaged wrong or put in the wrong folders so they end up in the wrong place if you just try and drop them into "My Library".
    If you could give us more information on what you downloaded we might be able to help out more. :)
    Cranky old fart here pointing out that you did spell library wrong all three times, might have some bearing on the problem.
    That is fine I sometimes type so fast that I miss some letters and don't post read what I type. So should I make my own folder in the my library?
  • Ron KnightsRon Knights Posts: 2,751
    Any time I setup directories, I always point and click to the appropriate folder. It cuts down on typo problems?!
    If you create your own library folders than spelling is critical.  I am always forgetting the 'n' in 'environment' so I had DIM installing to 'Enviroment' (I typed the path instead of navigating to it like Ron suggested) and Studio looking at 'Environment'.
