Render Settings
Is there any way to render an iimage WITHOUT an "icon" image?  I'm not sure why it does that.  I get the regular rendered image plus an icon image.  Do I NEED the icon image??
  • mikael-aronssonmikael-aronsson Posts: 607
    edited July 2016
    They are for thumbnails, you don't NEED them, but I am not sure if you can turn it off.
    Post edited by mikael-aronsson on
  • FishtalesFishtales Posts: 6,236
    Save your images to another folder on your hard drive, e.g. MyDazRenders, and not to the DAZ default render library. You can specify that in the Render Settings/General/Image Path.
  • Richard HaseltineRichard Haseltine Posts: 111,842
    You can also save to a folder instead of a library from the render window - there's a button next to the library (or folder, once changed) name. I have my content library pointed to a folder that doesn't hold any images at all so that it won't make any thumbnails (it isn't, as far as I cna see, possible to have no render library folder at all) - use the Render Library Manager available through the Render Library pane option menu (then close the pane).
