quick question
can i buy a character that is based on a character like aiko for example  but not have akio and still use it and still get its effects or  will it not work out or what
  • You can still use it. It won't look the same, though, because you'll be missing the thing it's built upon.
    Which character are you thinking of? Someone might be able to post a render without the Aiko morph dailed in.
  • Charlie JudgeCharlie Judge Posts: 13,629
    edited July 2016
    That depends on the generation of the "required" figured. If it is a pre-genesis figure (generation 4 (such as V4) and before ) the answer is: No, the basic figure is definitely required.
    If  the "required" figure is Genesis 1, 2, or 3 figure, then you can use it but the results may not be the same as if you had the required figure.
    Post edited by Charlie Judge on
  • i like alot of the girl 7 figures but i dodnt know if i want the base is all
  • BeeMKayBeeMKay Posts: 7,019
    edited July 2016
    Here's an example for Snowflake, a character based on Aiko, without using Aiko 7:
    Cpmpare to how the character looks with Aiko 7:
    From this thread:http://www.daz3d.com/forums/discussion/101066/snowflake-without-aiko7#latest
    Post edited by BeeMKay on
  • so  do you not have to use the base characters ?
    I don't have the base character, but that snowflake character sure went onto my "to buy" list after I saw the "without Aiko" image of her.
    If you have any character in particular you are interested, just post it here. Maybe someone can do a render for you without the Aiko 7 morph.
  • like ruby  from the girl 7
  • I've got her. Give me a couple of minutes and I'll throw you a render.
  • Here you go.
    2000 x 2800 - 3M
    Thanks, Hanabi. She almost looks like my niece. surprise
