Surface Editor Color Setting
I'm not sure when it happened, but at some point my Daz Studio stopped displaying RGB color values as ranges of 0 to 255.  Instead, it now displays them as ranges of 0.0 to 1.0.  For example, gray used to be 128/128/128, but now it's displayed as .22/.22/.22.  That would seem to indicate that I have more granular control over my colors (yay!), but these numbers don't have anything to do with the color picker tool (boo!).
So.  My question is this - is there either a preference setting to go back to the 0-255 values or is there a different color picker that I should be using that relates to the numbers that DS is using?
  • Richard HaseltineRichard Haseltine Posts: 111,842
    Generally 3Delight shaders use RGB integer values, Iray decimals.
  • MedzinMedzin Posts: 337
    That number for gray (128,128,128) appears have a correction applied.  The decimal equivalent of 128 should be 0.5019 (i.e., 128/255).
    The 0.22 number appears to have a gamma correction applied, 0.5019 * (1.0 / 2.2)
  • ChinchbugChinchbug Posts: 0
    Ah.  I see.  Looks like it's just the "Daz Uber" Iray Presets that uses these funky numbers.  Thanks for the help!
