Not using gpu when iray render
Hello all!
I just bourght a new laptop with a Gtx980m card with 4gb vram.
i have set up a scene with 3 Genesis 3 charters and some background.
Anyway, when i use SimTenero iray memory assistant it say that i have 900mb vram left. But when render it still doesn't use my gpu, just the CPU. Why is that?
when i set up a scene with just one charter it is ok, the gpu is rendering.,,
thanks //Daniel
  • EsemwyEsemwy Posts: 578
    Do you have CUDA installed? It probably wouldn't be installed by default on a new system.
    Ok, well i have no ide..i have installed the latest nvidia drivers(around 300mb). Just used the express setup..
    How and what do i have to do more to use the cuda cores?
    thanks for the reply.
    best Regards//Daniel
  • Richard HaseltineRichard Haseltine Posts: 111,939
    Assuming this is a Windows system Cuda is not a separate install.
  • Assuming this is a Windows system Cuda is not a separate install.
    Aha, it is a Windows computer. And i have the latest nvidia drivers and latest daz3d..
  • frank0314frank0314 Posts: 15,115
    Does you GPU have CUDA cores in it?
  • fastbike1fastbike1 Posts: 4,084
    The Memory Assistant is just a guess. Download something like GPU-Z so you can see the actual load.
  • Thanks for your answers.
    I use Windows 10.
    yes, i think the gpu have like 1500 something cuda cores.
    i will download z-gpu and watch.
    best Regards //Daniel
