SaveGuard: Ultimate Scene Saver for Daz Studio Win 64 v1.2
matew said:
Artini said:
Saxa -- SD said:
Since no Wearables Manager thread, will post this here again :)
Wearables Manager makes sending a character to Hexagon for morph-making an absolute breeze.
Just did it.
Have scripts on toolbar of your choice, select undress script, send figure to Hex, make morph in Hex, back to DAZ and save new morph, click script to dress and Viola!
Before was always a groaner removing all items inorder to send to Hex.
With this and the raw power of Hexagon (it's not perfect but pretty darn good for morphs), that program so tightly bound with DAZ, can't even imagine using DAZ GeomEditor even with it's improvements.
Anyway, just wanted to pass on how much of a time-saver this was.
Been focussed on other 3d things, so this is why just doing & posting now.
Thks Matew.Great to know, that it is working for you.
https://www.daz3d.com/wearables-manager
I was wondering what is the difference between Wearables Manager and personality in Daz Studio.
I guess you meant Personas, right?
Wearables Manager doesn’t use or replace Personas.
Personas are a very old DAZ feature that defines metadata for interactive tools (like PowerPose handles). It has nothing to do with clothing or managing outfits.
Wearables Manager is specifically for organizing, fast putting on / taking off outfits, handling materials when geografts are present, and some toggling some material states — completely separate from the Persona system.Persona prsets are a newish feature https://www.daz3d.com/forums/discussion/comment/8999416/#Comment_8999416
Genesis 9 geometries don't matchIs there any geo-grafts on the figure ?
If there is, you can either export / import OBJ with Geometry Editor tool activated, or use the Load Morph option > Primary Figure from Graft (Facet Order) in Morph Loader Pro.
DAZ to 3ds Max Bridge support for Genesis 9After exporting genesis 9 character in DAZ, using the DAZ bridge to 3ds Max, I load the DAZ bridge in 3ds Max and click auto-import and max freezes. Waiting 10 minutes, I force exited from max. Tried a few times and same issue all the time. Tried Genesis 3 and 8 no problems with the same import process.
Just did it.
Wearables Manager is specifically for organizing, fast putting on / taking off outfits, handling materials when geografts are present, and some toggling some material states — completely separate from the Persona system.Products not being updatedRichard Haseltine said:
Do the Products have metadata? Check the list in DIM. If so, you may need to reimport metadata - Content Library option menu (the lined button at top-right of the pane, just under the PDF Manual button in your screenshot)>Content DB Maintenance, check reimport Metadata, then in the next dialogue check any of the missing products that are listed.
I tried that and it fixed the problem. Thank you. But what do I need to do to keep this from happening with new installs?
Suggestions regarding the list management function of the content libraryAs the number of loaded content paths increases, how to manage and quickly locate the desired products has become a very troublesome issue for me. I would like to put forward a few suggestions regarding functionality, and I hope they can be taken into consideration.
1. Improve the quick search function in the content library list based on SHIFT + the first letter. Why do we need to add SHIFT? Because many individual letters have already been set as shortcut keys for various panels, when these initial letters are clicked, various panels will repeatedly switch.
2. When the mouse hovers over a certain folder in the content library, the product preview image named "folder.jpg" in that folder will be automatically displayed, so that one can quickly know what is in this folder without having to navigate through one level after another to find out what is inside.
3. I know there is the "categories" function, but I can't guarantee that for each product loaded, a "categories" label will be assigned to it. Can we add a label to each folder that has already been assigned a "categories" label in the content library, so that I can know which folders have been classified and which ones haven't?
4. Allow using the right mouse button in the content library list to quickly set a preset color for the folder, so that users can quickly distinguish the product category of a folder based on their own preference for colors, for example, red represents characters, blue represents scenes, etc.
5. Allow using the left mouse button in the content library to drag folders for custom sorting.
6. Allow for convenient and quick import or export of the list of the content library, and also retain the order of these folders, which is very important. Sorting by the initial letter of the folders is often disastrous because the sorting based on product categories has been disrupted. It will be very difficult for me to find the product folder I need after clearing the entire content list.
7. Allow using the right mouse button in the content library to quickly lock certain folders that users particularly frequently use, so that after clearing the entire content list, these frequently used folders can be retained, and then other folders required for the next project can be loaded.d then other folders needed for the next project can be loaded.Products not being updatedDo the Products have metadata? Check the list in DIM. If so, you may need to reimport metadata - Content Library option menu (the lined button at top-right of the pane, just under the PDF Manual button in your screenshot)>Content DB Maintenance, check reimport Metadata, then in the next dialogue check any of the missing products that are listed.
UGH!!Window>Panes(Tabs)>Help will close it, or just load a different layout (Window>Workspace>Select Layout). If theer are other features, such as menus, that you want to keep save the layout first (Window>Workspace>Save Layout) then use the Import button at the bottom of Window>Workspace>Customise to seelctively load the elements you want, while not loading the panes.
SapphireBlue's freebies: Flower Earrings for G8/8.1F and G9I'm starting with a pose pack of 16 poses (with some expressions) for Lady Littlefox's Gumdrops characters. Gumdrops Candy the Base, as well as others LLF has created from that base, are available in the DAZ store. I love working with Gumdrops and wanted to make some starting poses for myself and thought I'd turn it into a little pack. The set also includes options to reset expression only, pose only, and pose and expression.
Download at Renderhub, or the attached files here. I've included a zip file and an installer file here. If all goes to plan, it should add Smart Content metadata too.
Importing Hands dial-ups into Blender?Hi Padone, thanks for the explanations! Very useful.
I finally tried the import on another machine and it worked just fine. Go figure...
Must be something funky in the Diffeo settings on my other machine. I'll re-install Diffeo on it and go from there.Connecting to the CMS DatabaseWhich metadata are you expecting? User data isn't the products you installed through DIM or DS, nor new protducts you have created yourself - it is only the non-product metadata, for your own saved scenes and presets or you own additions to product data that wasn't an edit of the product itself.
Connecting to the CMS DatabaseWell, this looks more or less the same just seven years later. I got a new refurbished computer running Windows 11. I installed DS. I am trying to export the metadata for my stuff in an old Winfows 10 computer to the new refurbished computer. For that I ran the EXPORT USER DATA in the old computer, and I got two files UserData_1.dsx and UserData_2.dsx from the proper folder in the old computer. I copied these files to the Runtime/Support file of the new computer, and I ran there RE_IMPORT METADATA inside CONTENT DATABASE MAINTENANCE. This took a few minuites but I do not see that the metadata in the old computer are imported into the new computer. Either I am doing something wrong or the instructions to export metadata are wrong or... I do not see any other possibility, is there any? Any help with this?.
Importing Hands dial-ups into Blender?This is also a perfect case to depict one important difference between blender and daz studio. For this hands set there's a set of poses which reference to a set of morphs wich reference to the figure standard set of body morphs for the hands.
hand poses < hand morphs < body morphs
Thus in blender we have to import the body morphs to make the hand morphs work, then import the hand morphs to make the hand poses work. Such a network of references is typical of daz studio and never used in blender for native files. That is, blender would simply have the hand poses in a library.
To convert this set for blender the best way would be to bake the poses in daz studio, then import the baked set in a blender library. Unfortunately it's also a lot of work, so it may not be worth it.
steps:
- in daz studio: edit >figure > bake to transform, then save the pose preset for each morph
- in blender: runtime > posing > import asset
https://bitbucket.org/Diffeomorphic/import_daz/wiki/Posing/Import Pose Library
p.s. Or another option could be to bake in blender instead of baking in daz studio, then save the pose assets. The saved poses will only work on the specfic rig though, I mean if we save poses for rigify they will not work on MHX or the daz rig, so importing poses directly from daz has its advantages.
Importing Hands dial-ups into Blender?OK, thanks Padone. I try it again tomorrow.
I wonder if I omitted the body morphs.
I used the same path to the morphs during custom import, but my figure might have been lacking some morphs to begin with.
This stuff sure ain't easy...Re-install of DAZ Studio + Assetsfelis said:
What I mean is if you do not want to install further with Daz Connect, there is no reason to log into Daz Studio.
That isn't entirely true, which is why updating the metadata is now an option in the log in dialogue rather than being done automatically.
You will still be able to use content you already have installed with Connect. If you want to fully get rid of Connect, then right-click on a product and select uninstall. That can only be done with what is installed with Connect.
You can look in your Connect folder what is already installed.
Let's appreciate/discuss today's new releases - more ongoinger threadmemcneil70 said:
Well to speak to the current sale, I found scrolling down one of the MartinJFrost's releases today (https://www.daz3d.com/rose-garden--rose-bushes) or (https://www.daz3d.com/lr-illuminated-candle-trees) a 'You may..." suggestion of https://www.daz3d.com/retro-super-roadster by Polish for $1.59. I am not sure how I missed it back in the day but it is in my cart now.
Quick Grab came up with a few items I found interesting:
https://www.daz3d.com/the-olde-victorian-theater - $0.79 - Not sure but I expect I will need to install the metadata but
https://www.daz3d.com/dforce-combat-uniform-outfit-for-genesis-9 - $1.59 - even if it isn't baggy enough to be a factual reproduction.
https://www.daz3d.com/ah-dforce-magical-wizard-outfit-texture-add-on - $0.79 - which I missed out on the original sale.
I think that Retro Super Roadster actually looks better than the model it's originally based on, its got a few new curves in the right places.
Importing Hands dial-ups into Blender?Just tried and works fine here, all the morphs are imported. I used "custom morphs" as it is easier then "daz favorites" in this case, though importing custom morphs requires a bit more of attention. The set is using the hand body morphs so you have to import them as well. Let me know if this works for you.
my steps:
- easy import G8 with "MHX compatible" body morphs
- import the custom morphs for the hands set, I didn't import the aliases as they are only used in the daz interface, plus I checked "make hidden sliders" to get all the morphs listed
To see where the morphs are located I clicked the parameter settings in daz studio.
"My Library\data\DAZ 3D\Genesis 8\Female\Morphs\Neikdian\Hands Dial-up"
update. I also tried with "daz favorites" and works fine here, it's just tedious to select them all in DS so "custom morphs" seems easier to me in this case.
my steps:
- in daz studio select all the morphs as favorites
- in blender easy import with "MHX compatible" body morphs and "daz favorites"
I too was wondering how I missed a couple of those. It turns out I own them already, but they're not showing as purchased on their store pages.
Importing Hands dial-ups into Blender?I finally got around to using the hand dial-ups today and noticed that only a few of the morphs imported via Diffeo.
All thirty G9 hand poses were flagged as Favorites in DS, but only 8 of them per hand were imported.
I've looked for hidden morphs in DS but didn't see anything related to the hands.Same with the G8F hand dial-ups. Only a few of the poses get imported.
I've tried a custom morph import, but that didn't help either.
Blender's console window didn't reveal any errors during import that I could see.Any idea why so many of them fail to import?
Let's appreciate/discuss today's new releases - more ongoinger threadWell to speak to the current sale, I found scrolling down one of the MartinJFrost's releases today (https://www.daz3d.com/rose-garden--rose-bushes) or (https://www.daz3d.com/lr-illuminated-candle-trees) a 'You may..." suggestion of https://www.daz3d.com/retro-super-roadster by Polish for $1.59. I am not sure how I missed it back in the day but it is in my cart now.
