• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Error occurred while reading file
     ummm,your first post..
    It was step 3 actually.
    Apparently your PC restarted before DS(or Windows.Not all file operations are instantly written to disk) finished writing/compressing the file.
    Also , you should look into why your PC is randomly restarting it self while under heavy load.
    It shouldn't be.
    That can corrupt your entire harddrive and make your system unusable depending on what Windows was doing in the background when the sudden reboot happened.
    In the meantime I would put together an Windows Installer on a USB stick or CD/DVD what ever you have.You might need it if those random reboots keep happening.
    Windows installers are free and a tool to make them is free from Microsoft.
    https://support.microsoft.com/en-us/windows/create-installation-media-for-windows-99a58364-8c02-206f-aa6f-40c3b507420d
    Jason Galterio said:
    Well, it appears that I lost all my work from this morning. This is my last resort to recover the work.
    Has anyone seen this error before?
    Here is what the log says:
    2022-04-22 10:29:28.662 [INFO] :: *** Scene Cleared ***
    2022-04-22 10:29:28.711 [INFO] :: Prepare asset load (open): /2022.04.20/US_XT_Setup_v02.duf
    2022-04-22 10:29:28.711 [INFO] :: Locking viewport redraw...
    2022-04-22 10:29:28.711 [INFO] :: Viewport redraw locked.
    2022-04-22 10:29:28.761 [INFO] :: Native format content directories: 8
    2022-04-22 10:29:28.761 [INFO] :: Poser format content directories: 8
    2022-04-22 10:29:28.761 [INFO] :: Other import format content directories: 0
    2022-04-22 10:29:28.761 [INFO] :: Begin asset load (open): /2022.04.20/US_XT_Setup_v02.duf
    2022-04-22 10:29:29.815 [INFO] ::     Json Parser (2461529,32): Syntax Error - expected ',' or ']'
    2022-04-22 10:29:29.989 [INFO] :: Error loading asset: D:/DAZ Installs/Projects/2022.04.20/US_XT_Setup_v02.duf
    2022-04-22 10:29:29.989 [INFO] ::     Operation failed
    2022-04-22 10:29:30.025 [INFO] :: Unlocking viewport redraw...
    2022-04-22 10:29:30.025 [INFO] :: Viewport redraw unlocked.
    Here is what happened:
    1. Scene was rendering fine.
    2. Changed the Z-axis of my camera to lower it a bit.
    3. Saved the file.
    4. Started a render and walked away.
    5. Came back to my system having rebooted. Which isn't that unusual. If I render too many times without a restart, this will happen. (Some idiosyncracy with UltraScenery I believe.)
    6. Logged back in. Started DS. Tried to reopen the file. Error.
    7. Shut down completely. Restarted. Tried again. Same error.
    The file was rendering just fine before moving the camera of all things. So I don't understand why that would cause this.
    I had been saving the file with the icredmental changes. I'd rebooted a couple of times. No issues up until this.
    By
    IceCrMn IceCrMn April 2022 in Technical Help (nuts n bolts)
  • Importing OBJs Oddities
    Kainjy said:
    The answer for the problem 2 is because not all 3d softwares use the self world reference axis orientation:
    softwares like Maya put Y as the vertical axe (X and Z are the plain axes), while in 3D studio Max is Z (X and Y in plain).
    For invisible parts maybe the problem is the imported material, you can fix it applying a new material to whole object or editing the imported one
    Thanks, that's the train of thought that led me to experiment with the import functions. Previous imports I did today had the same problem, only I didn't notice because there was no text in the textures. When the text was there, I realized things were reversed. I was missing the forest for the trees by not going back to the import process to begin with.
    I *kind of* noticed that the objects looked flat... but I just assumed that that was texturing changes I needed to make. In reality, it was the texture being inverted, so the bump maps were extruding / intruding the inside of the models.
    I'm still puzzling through the invisible surfaces. Changing the surfaces themselves makes no difference, which is why I am thinking the exports might be the problem.
    By
    Jason Galterio Jason Galterio April 2022 in Technical Help (nuts n bolts)
  • [Released] Substance Painter Assistant [Commercial]
    RiverSoftArt said:
    RAMWolff said:
    This MAY be useful for those of us that work in Poser but have used DS in the past for working on figures like Dusk, Dawn, L'Homme or L'Femme by having their obj's imported from Poser and then sending via your script to SP?
    It is a Daz Studio script so you would need DS to run it.
    Also what version is needed of DS for this script to work?
    Right now, v4.20.  I am working with Silent Winter to at least get it down to 4.15 (I was using an undocumented function so I have NO IDEA when it was added)
    I can confirm the fix that RiverSoftArt sent me makes this work in DS 4.15 so if you're not on 4.20 and the script isn't working, you can confidently buy it now (to get the intro discount) and just hang on. (The export script was fine before, just the import had a hiccup - but all good now and going to save me lots of time)
    By
    Silent Winter Silent Winter April 2022 in Daz PA Commercial Products
    Okay, I resolved #2 by experimenting with the orientation of the import settings. It took three or four import attempts, but I finally found the combination that fixed the backwards images.
    Still can't fix the invisible OBJs, but I will come back to that another time.
    Edited to Add: I would provide the orientation settings, but I have a feeling that it is different based on the exported OBJs. In my case, I changed the first one to X, Y, and Z. Then changed the second one to one of the remaining ones. And just kept trying different combinations until it clicked. 3! = 6 different possible configurations, it wasn't as time consuming as it sounds.
    By
    I'm just batting 1000 today...
    Importing OBJs into DS and seeing behavior that I haven't experienced before.
    1. Some import invisible. If the object is highlighted, the surfaces ghost into appearance. Otherwise they will not appear.
    2. Images are coming in reversed. Text is backwards, etc.
    These both seem to be related; as if the objects are one sided and I am on the wrong side of them.
    Has anyone seen this before? And is there an easy way to fix it?
    By
  • Diffeomorphic DAZ Importer version 1.6.0 released
    okay... I figured it out myself.
    just sleced Principled as the import material method
    And I'm getting this
    I can even remove the nodegroup and the result stays the same.
    But it looks like that the normal map is missing. Is this intended?
    By
    Hurdy3D Hurdy3D April 2022 in Blender Discussion
    3. Saved the file.
    By
  • Renders have become impossibe 9 out of 10 times
    I run a Ryzen 7 3700X with a RTX 3060, no tweaks. I will gety black renders or black renders in scenes which previously worked. I could set up to three figures in a big scene by PW productions and the machine too kit. Not anymore.
     I often get something like this in the log:
    2022-04-22 15:10:11.038 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2022-04-22 15:10:11.038 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating motion transforms.
    2022-04-22 15:10:11.038 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2022-04-22 15:10:11.038 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2022-04-22 15:10:27.081 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 115 M triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 115 M triangles, 0 fiber instances yielding 0 segments) took 16.043 s
    2022-04-22 15:10:27.081 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating section objects.
    2022-04-22 15:10:27.081 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2022-04-22 15:10:29.204 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 474 textures, 0 lambdas (0 unique)
    2022-04-22 15:10:29.214 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating volumes.
    2022-04-22 15:10:29.214 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
    2022-04-22 15:10:29.214 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
    2022-04-22 15:10:29.214 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2022-04-22 15:10:29.214 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2022-04-22 15:10:29.215 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
    2022-04-22 15:10:29.218 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
    2022-04-22 15:10:29.218 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2022-04-22 15:10:29.222 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
    2022-04-22 15:10:29.223 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2022-04-22 15:10:29.227 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
    2022-04-22 15:10:29.227 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
    2022-04-22 15:10:29.230 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing OptiX for CUDA device 0
    2022-04-22 15:10:29.319 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2022-04-22 15:10:29.319 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3060)
    2022-04-22 15:10:29.319 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2022-04-22 15:10:29.319 Iray [INFO] - IRAY:RENDER ::   1.17  IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3060): Processing scene...
    2022-04-22 15:10:31.290 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.16  IRAY   rend error: Unable to allocate 2.289 GiB from 464.402 MiB of available device memory
    2022-04-22 15:10:31.297 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.17  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): Scene setup failed
    2022-04-22 15:10:31.297 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.17  IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): Device failed while rendering
    2022-04-22 15:10:31.297 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - IRAY:RENDER ::   1.17  IRAY   rend warn : CUDA device 0 (NVIDIA GeForce RTX 3060) ran out of memory and is temporarily unavailable for rendering.
    2022-04-22 15:10:31.322 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - IRAY:RENDER ::   1.17  IRAY   rend warn : All available GPUs failed.
    2022-04-22 15:10:31.322 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.17  IRAY   rend error: Fallback to CPU not allowed.
    2022-04-22 15:10:31.322 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.17  IRAY   rend error: All workers failed: aborting render
    2022-04-22 15:10:31.322 [ERROR] Iray :: Internal rendering error.
    2022-04-22 15:10:31.441 [INFO] :: Saved image: K:\TEMP DAZ\render\r.png
    2022-04-22 15:10:31.450 [INFO] :: Finished Rendering
    2022-04-22 15:10:31.472 [INFO] :: Total Rendering Time: 4 minutes 52.39 seconds
    2022-04-22 15:11:26.945 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2022-04-22 15:11:26.945 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3060): 0 iterations, 2.066s init, 0.025s render
    By
    Second Technician Rimmer Second Technician Rimmer April 2022 in Technical Help (nuts n bolts)
  • dForce Chic Club Outfit Textures Issue
    This looks as if the files have not decrypted correctly when installed through Daz Studio. Try this, and if the eror persists open a support ticket:
    1. right-click on the product's container>Unisntall
    2. right-click on the product's container>Delete
    3. then from the Connect menu either refresh meatadata or go offline and then log back in, which should refresh the metadata thoroughly,
    4. reinstall the product
    By
    Richard Haseltine Richard Haseltine April 2022 in Technical Help (nuts n bolts)
  • Daz Studio and the DAE Format? Better than FBX and OBJ????
    im always downloading stuff from online vendors and sketchfab etc.  Often they will be in FBX and DAE and i always have problems with both these formats.  Obj is the only format i trust Daz to import correctly.  I systematically convert files to obj before importing them - i dont even bother testing DAE and FBX to see if they work anymore.
    By
    lilweep lilweep April 2022 in The Commons
  • Projection Morph Manager (Commercial)
    Zev0 said:
    In a nutshell fit clothing to figure. Dial up figure shape, modify clothing projections.
    Now, on clothing, favourite the desired projection morph, remember its value.
    Now zero figure, clothing will be zeroed as well. On clothing click favourites, the projection morph you favourited will still be there, dial in the value you remembered.
    Now hide figure, export clothing only with projection morph dialed up, now import that as a new clothing morph onto clothing item.
    Thank you very much, I will try it.
    By
    fengkan fengkan April 2022 in Daz PA Commercial Products
    I am aware of that link but sadly I lack the skill, I would (and actually did back in the day for D|S3 export only) pay for a decent Import plugin
    https://web.archive.org/web/20140220204003/https://www.daz3d.com/fbx-plug-in-for-daz-studio
    By
    WendyLuvsCatz WendyLuvsCatz April 2022 in The Commons
    WendyLuvsCatz said:
    well DAZ FBX import sucks more than collada but that's not saying much
    I have actually gotten dae files rigged into D|S not mangled but it depends on where from, Carrara rigging for example imports animated as dazcollada a specific form of dae for D|S
    Have fun https://github.com/daz3d/StudioFbxImporter if you (or anyone else) wish to improve it
    By
    Richard Haseltine Richard Haseltine April 2022 in The Commons
    SnowSultan said:
    Can the importing of textures be done in a separate work session, without Substance Painter needing to be open? For example, if I send an object to SP from Studio using this, work on a texture over a few days, then open Studio and just import and quickly apply the maps I generated earlier from Substance Painter based on their filenames? It sounds like you can, I just ask because I have a Blender plugin that is finicky about having both open at once in order to transfer anything between them.
    Looks like a useful product, will be waiting for it.   :)
    Substance Painter does not need to be open or even installed.  Substance Painter Assistant works with files... exporting the OBJs for use in Substance Painter and importing graphics files to be used in DS.
    (tiny edit: also is there any reason why this would not work with the standalone Steam version of SP?)
    It will work with the steam version.
    By
    RiverSoft Art RiverSoft Art April 2022 in Daz PA Commercial Products
    By
    SnowSultan SnowSultan April 2022 in Daz PA Commercial Products
    By
    Zev0 Zev0 April 2022 in Daz PA Commercial Products
    You are very lucky to get a .DAE or collada file to import correctly, I never have, rigged or not. FBX import and export with DS is useless in my experience also. for me, OBJ has given me the least amount of issues. I would give my first born to have a flawless, rigged  FBX import option that works. I can get it to work in carrarra, but not DS,  go figure.
    By
    FSMCDesigns FSMCDesigns April 2022 in The Commons
  • Kento 8.1
    FenixPhoenix said:
    ALLIEKATBLUE said:
    sid said:
    I buy most of the core male characters, I can't help it. I'm not sure how I feel about him, but some renders for your interest. He has attachment eyebrows! I don't have anyone's HD here, apart from Kwan's. Daz 4.16, files hosted on imjur, no tweaks to textures.
    My favourite Gen 8 Asian men were non-core, so I'll post a render with them if they finish before bedtime.
    Edit:
    Who are these guys?
    The first guy looks like: https://www.daz3d.com/haru-hd-for-kwan-8
    The third guy kind of looks like: https://www.daz3d.com/wufei-hd-for-genesis-8-male
    Not sure the second one, but I love his eyebrows!
    Sorry, chucked em up before bed and forgot import details, but Haru and Wufei are correct. Also didn't notice I buried Wufei's feet, or that Haru's skull cap through, not their fault!
    By
    sid sid April 2022 in The Commons
    By
    First:
    A DAE file is a Digital Asset Exchange file format that is used for exchanging data between interactive 3D applications. This file format is based on the COLLADA (COLLAborative Design Activity) XML schema which is an open standard XML schema for the exchange of digital assets among graphics software applications.
    As a person who mixes and matches different formats for me stuffs, I sometimes get into battles with what's UV unwrapped and bad Meshes and, and the Daz import fails a lot with some of the FBX formats.
    Sometimes everything arrives glued together - and the OBJ can also be problematic.
    I've never had an issue (yet) with anything DAE. It shows up, has its shaders and such and is also the right scale.
    What am I missing about the DAE format that it isn't talked about or used around these parts?
    It seems to be the ONLY true Drag & Drop format that works with Daz (consistently [so far, so good]).
    Someone enlighten me.
    * Post Script. I'm battling an older product and NOTHING works to install it. Even manual install is a big fail. Missing icons or imports without geometry or gives errors on open. I tried the direct FBX and OBJ and the item glued together or still gives errors that it dows not exist- even though I am navigating directly to it in the content librarian. AND another item is installed and works fine until I restart Daz. But that's another story for another thread..
    By
    Griffin Avid Griffin Avid April 2022 in The Commons
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
