Renders have become impossibe 9 out of 10 times
Second Technician Rimmer
I run a Ryzen 7 3700X with a RTX 3060, no tweaks. I will gety black renders or black renders in scenes which previously worked. I could set up to three figures in a big scene by PW productions and the machine too kit. Not anymore.
I often get something like this in the log:
2022-04-22 15:10:11.038 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating geometry.
2022-04-22 15:10:11.038 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating motion transforms.
2022-04-22 15:10:11.038 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing scene graph.
2022-04-22 15:10:11.038 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing geometry for motion time 0
2022-04-22 15:10:27.081 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Geometry import (1 triangle object with 115 M triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 115 M triangles, 0 fiber instances yielding 0 segments) took 16.043 s
2022-04-22 15:10:27.081 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating section objects.
2022-04-22 15:10:27.081 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating materials.
2022-04-22 15:10:29.204 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : found 474 textures, 0 lambdas (0 unique)
2022-04-22 15:10:29.214 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating volumes.
2022-04-22 15:10:29.214 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating environment.
2022-04-22 15:10:29.214 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lens.
2022-04-22 15:10:29.214 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lights.
2022-04-22 15:10:29.214 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating object flags.
2022-04-22 15:10:29.215 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating backplate.
2022-04-22 15:10:29.218 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating caustic portals.
2022-04-22 15:10:29.218 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating decals.
2022-04-22 15:10:29.222 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using iray core convergence estimate.
2022-04-22 15:10:29.223 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Allocating 1-layer frame buffer
2022-04-22 15:10:29.227 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using batch scheduling, caustic sampler disabled
2022-04-22 15:10:29.227 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing local rendering.
2022-04-22 15:10:29.230 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Initializing OptiX for CUDA device 0
2022-04-22 15:10:29.319 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering with 1 device(s):
2022-04-22 15:10:29.319 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 3060)
2022-04-22 15:10:29.319 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...
2022-04-22 15:10:29.319 Iray [INFO] - IRAY:RENDER :: 1.17 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3060): Processing scene...
2022-04-22 15:10:31.290 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER :: 1.16 IRAY rend error: Unable to allocate 2.289 GiB from 464.402 MiB of available device memory
2022-04-22 15:10:31.297 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER :: 1.17 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): Scene setup failed
2022-04-22 15:10:31.297 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER :: 1.17 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): Device failed while rendering
2022-04-22 15:10:31.297 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - IRAY:RENDER :: 1.17 IRAY rend warn : CUDA device 0 (NVIDIA GeForce RTX 3060) ran out of memory and is temporarily unavailable for rendering.
2022-04-22 15:10:31.322 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - IRAY:RENDER :: 1.17 IRAY rend warn : All available GPUs failed.
2022-04-22 15:10:31.322 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER :: 1.17 IRAY rend error: Fallback to CPU not allowed.
2022-04-22 15:10:31.322 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER :: 1.17 IRAY rend error: All workers failed: aborting render
2022-04-22 15:10:31.322 [ERROR] Iray :: Internal rendering error.
2022-04-22 15:10:31.441 [INFO] :: Saved image: K:\TEMP DAZ\render\r.png
2022-04-22 15:10:31.450 [INFO] :: Finished Rendering
2022-04-22 15:10:31.472 [INFO] :: Total Rendering Time: 4 minutes 52.39 seconds
2022-04-22 15:11:26.945 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Device statistics:
2022-04-22 15:11:26.945 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 3060): 0 iterations, 2.066s init, 0.025s render
I might have found the rat in the end. Subdivision for render on my figures was at 5 instead of 2 x_x
