• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • Poke Away 3 For Genesis 3
    Poke Away works by using magnets/deformers to shrink parts of the figure back below the clothing, if I am not mistaken. Whilst this is obviously one solution to the problem, it does not give very good results if the clothing is translucent. I'm also not sure how precise the changes are. An alternative method is to simply make the body part, which is poking through the clothing, invisible. However this does not always work if the clothing only covers part of the body part.
    A much better solution would be to make a morph in Hexagon or Blender or Zbrush and then apply that in DS. Repeat that untill all the poke throughs are gone. This works but is time consuming.
    An even better solution would be to have a plugin for DS which provides mesh brushes so that in real time in DS you can brush away the poke through by moving, smoothing, expanding (as appropriate) the clothing mesh. It would take seconds and provide immediately visible results. Unfortunately, neither DAZ3d nor a PA has made such a plugin. A pity really!
    By
    IsaacNewton IsaacNewton October 2016 in Product Suggestions
  • Toddler clothes for Genesis 3
    Thanks Zylox. OK, so there is your answer dtinc88, if there is no Toddler for genesis 3, no one will make toddler clothing. If you make your own Toddler morph for Genesis 3, then autofit will try to make clothing items fit, but in all likelihood it will look awful. The difference between a Toddler and adult Genesis 3 is too big for autofit to handle... it even messes up with teen figures. Then of course it would be "adult" clothing on a child, mostly it would look very strange. If you can persude DAZ3d to make a Toddler figure based on genesis 3 then the PAs might make clothing items specifically for that figure. In the meantime, you're on your own! You might try making your own Toddler morph and then making toddler specific clothing yourself in a program like Marvelous Designer. However, that is a considerable time and money investment.
    By
  • Modifying/Morphing Clothing for Morphed Characters
    In general, a clothing morph made in a 3rd party program like Hexagon, Blender or Zbrush should work fine when applied to the clothing in DS. Especially if using the DS feature of "Send to..", like the GoZ feature for Zbrush. However, I have come across situations like you describe where the morph seems to be over-ruled by something else going on in DS. One such case was when making a morph to flatten the breasts on a dress to make it suitable for a child character based on genesis 3. Normally auto fit will try to do this automatically but usually makes a pretty poor job of it, screwing up the clothing mesh quite badly. On a number of such occasions I have found that even though the morph I made in Zbrush was perfectly fitting the shape of the morphed Genesis 3 figure, when that clothing morph was applied to the clothing item in DS (via GoZ or not) the center of the chest of the clothing stood out away from the figure's chest. Even a deformer added in DS would not change this. No one could explain why this happened or what to do about it.
    Perhaps it was a specific issue with the rigging of the clothing. The same may be true for the clothing you have mentioned. Sometimes DS does wierd things.
    One possible way around this would be to have mesh brushes that work in real time within DS (such as those in Poser and Blender), so that you could manipulate the mesh in DS and see immediately if the results are what you want. Unfortunately, no one has made a plugin for such mesh brushes in DS yet. Personally, I think they would be very popular and would help to solve a lot of these problems. In the meantime... good luck with your outfit morphing problem.
    By
    IsaacNewton IsaacNewton October 2016 in Technical Help (nuts n bolts)
  • Runtime DNA Merges With Daz 3D
    Looks like most of the "Furries for..." add-on presets and texture additions have finally appeared in the store.  Of course, the "face poses" won't be of much use until the base "Furries for Melody" and "Furries for Micah" are finally listed as they contain the actual morph dials.
    So that's why I was going mad trying to make them work just now. Thank you! I'll hope it's soon.
    DAZ really should update the informationon on those pages. The pics talk about RTE still being needed, and they don't say that we need the "Furries for..."
    Amusingly - or not so much: http://docs.daz3d.com/doku.php/public/read_me/index/24993/start
    I had bought Furries for Melody at RDNA and it showed up in DIM, it has a new Readme - but it's not in the store ...
    By
    Kerya Kerya October 2016 in The Commons
  • Gen3 Rigging Adjustment Problems
    To said more detail, about each facial rigs, may beyond my English skill,,
    But about those eyelids rigs, I recommend, only , remove Z orientation ERC ,, if you hope to  keep X, Y, orientation.. (yes it may help sometime to arrange well with current face mesh,,
    I said, there is almost no meaning add ERC about orientation Z about those facial rigs.
    to be frankly said,, those eye lids arrange ment is something srange at start point,,  all eye rids node ,center point start almost same positon, then they arrange very narrow,
    it cause real difficulity when I select nodes in the 3d view, as I like, ,,, maybe DAZ think,, we use parameter with scene tab, or use expression  which daz sell, but the strong point of facial rigs
    is ,,User can easy tweak detail by select and move bone t, who arrange eye lids rigs like that,  if you plan pose manually ??  (and daz do not  offer posing sheet still)
    then we many buy  expression morph product .
    By
    kitakoredaz kitakoredaz October 2016 in Technical Help (nuts n bolts)
    The problem is, mostly about Gen3 facial rigs around eye.   it never happen about gen2 or gen2,, because,, only genesis3 have those facial rigs.
    there are group about upper  and bottom , eylids rigs. then  about under eyelids rigs are orientate z  180 alerady..
    (I can not see  any practical meanig, to set under eye rigs like that)
     even though you select only about r eye (influenced node)  , or l eye, those rotation often return 180 to around 0,  when you adjust rigging to the shape.
    then when you add morph,  those rigs rotate with Z axis.    maybe there are still some nodes,,  z orientated 180 around,, (without clear reason)    or,, about x, y. such way. then when adjust rigts to the shape,, they turn oposit.
    That's pretty much it. I would also add that after fiddling with it for a while I've spotted which ones get messed up. Basically, there are eight bones around each eye: inner, upper inner, upper, upper outer, outer, lower inner, lower and lower outer. Out of these the upper trio have proper behavior after ERC freeze, other prefer to perform pirouettes every time I move the dial. I've only managed to deal with them by making manual adjustments.
    By
    Tamuna Tamuna October 2016 in Technical Help (nuts n bolts)
  • Carrara not using all of my render nodes! Solved!
    With SSD's there is now the M2 version that is just a chip really but transfer speads up to 10Gb/s in stead of 6 Gb/s on SATA.
    Sweet! But I doubt that these older motherboards have such an interface, right? Still... it's cool how fast technology is speeding up our intense computations. Not long ago the stuff I do now would light my older machine on fire, I'm sure! Drag it down to a locked up crawl... then the flames would errupt from within!!! LOL
    By
    Dartanbeck Dartanbeck October 2016 in Carrara Discussion
    By
    will shetterly will shetterly October 2016 in The Commons
  • 3D Art Freebie Challenge -- October: Double Bubble Toil and Trouble -- Main Thread
    The link for Mortella Dress for Genesis needs to be fixed.  It reads:  http://http//www.arien-graphics.com/wp/?p=852 ; Once I removed the extra http: it worked.
    All other links verified
    ENTRY ACCEPTED
    Please move to Entry Thread
    The Mortella link still doesn't work for me.  It says, "This site can't be reached.  :( "
    I was pretty sure that the Mortella Dress was actually a pay item at Renderosity.  It was in my wishlist there.  And it was Poser Dynamics, I think.
    Dana
    By removing the duplicate http's I get this address:  www.arien-graphics.com/wp/?p=852
    I do not see where it indicates any payment is required for this item.
    I saw the trouble.  The original had https:, but the site does not have a certificate, so that makes it an invalid address.  It worked without the https:.  Come to find out, I have that stuff.  I guess it was the Mortessa character morph that was a pay item.
    Dana
    By
    DanaTA DanaTA October 2016 in Freebies
    Then if you will  hope  when , demon shape appleid to character,, the morph shape  auto-applied to the cloth, , with fit to.demon character.
    there is way (usually just overwrite, generate FHM or FBM , by this morph, (you need to set morph name as  those generated character morph name (not labbeled name, but actuall morph name)  then save it as morph for clothing.
    but I may not do so, because,, sometimes you may hope to add demon shape without Geo grafted item.  just change shape with another mat,, etc.
    if you overwrite the demonFBM or HFM of the cloth,,( auto imported from g2m, , when cloth fit to character) , the cloth must trun to the shape.
    then I keep the morph, as manuall (when you apply the mosnter shape with geografted, I apply this  morph manually ,  then fit shape about this character)
    By
  • It's Raining Men Again! Winners Announced!!! Over in the Art Studio!
    I was looking at the prizes from last contest and I will donate one of the $10 Gift Certificates like last time but how do I do that? Just buy it and than somehow transfer to the official contest administrator?
    By
    nonesuch00 nonesuch00 October 2016 in The Commons
    So the problem is when you import moprh-obj for the clothing, did  you set riverse defomation option=Yes,
    I use shirt product, with demoen, G2m then see my pic, 1 is without riverse defomation, 2 is with riverse defomation.
    As you know,, when I use option Yes,, I think my tweaked shape is correctly imported.
    (sorry, I just make morph for one side,)
    (then I really recommend,, you will try blender, if you have already played hexagon,, and hope more powerful tool,
     because,, blender is actually really powerful for those task , like make moprhs)
    By
  • The new Centaur 'n stuff thread - reloaded
    Hemi hasn't been in the forums for awhile but here's the link to the tutorial
    http://www.daz3d.com/forums/discussion/6465/the-new-centaur-n-stuff-thread-reloaded/p10     ;
    scroll down to Tiger LeeArt 's post,oh and there is a morph for M4 and V4 at Philosopher's Egg's store
    By
    carrie58 carrie58 October 2016 in Freebies
  • The older generation: Victoria 2/3, Michael 2/3 and their children renders
    For those using Laura, there's a free morph set for her at ShareCG, which is especially useful since DAZ has vaulted the Laura/Luke face and body morph sets:
    http://www.sharecg.com/v/56962/gallery/11/Poser/135-Morphs-for-Laura-3
    There's also a set for those who can't use PMD files:
    http://www.sharecg.com/v/73761/related/11/Poser/Laura-3-Morph-Pack-CR2Diff-Beta
    I don't know how that one works; I still have DS3 installed and so I just use the first one.
    Also, the Laura morphs can be injected into other figures, like Luke and the Mil Baby 3. Here's a quick test render I did with the Mil3 baby using a mix of the baby morphs and the 135 Morphs for Laura 3:
    By
    mmalbert mmalbert October 2016 in Art Studio
    I've been hunting around for advice/tutorials on creating morphs for clothing.  Everything I find deals with a base Genesis (or Genesis 2, 3, etc).  Then creating a morph around that shape using a modeler and bringing it back into Daz Studio using the Morph Loader Pro.  A great example of this is Sickleyeilds tutorial here:  http://sickleyield.deviantart.com/journal/Tutorial-Requested-Loading-Morphs-in-DAZ-Studio-450007378
    My question has to do with Non-Standard or Morphed characters, particularly those with extreme changes such as RawArts Legendary Demon HD or those with GeoGraphed tails such as Roark 2.  I've tried modeling around an exported .obj of these modified characters, but (as you probably already know) they fail miserably.  Mostly because the adjustments that allow the clothing to fit to the character in the first place are reapplied, moving it.  For example, I tried using a modeler (Hexagon in this case) to move the shoulders of the GIS Emperor Coat in enough to clear the spikes.  The edge moves in, but it also increase the size of the coat by the same amount it did when it tried to AutoFit to the larger character.
    So, is there any way to fit clothing to a modified character?  What's the best way if I want to create a loincloth that'll split around a tail or hood that'll allow for horns?  What model (if any) should I export as an .obj to use as a manequin?  What steps are needed to get the new or modified clothing back in without issues?
    Thanks in advance for any suggestions or advice.
    By
    bshugs1525871 bshugs1525871 October 2016 in Technical Help (nuts n bolts)
    By
    chickenman chickenman October 2016 in Carrara Discussion
  • Question - preferred setup for furniture props with drawers
    Linear motions, such as drawers sliding open, can be handled by morphs - just make sure the whole drawer moves as a unit. However you will get odd rsults if you try to make a rotary motion with a morph - the item will shorten as it approaches the hallf-way point and then lengthen again. For those separate objects, or bones n a figure, are better.
    By
    Richard Haseltine Richard Haseltine October 2016 in The Commons
  • How to delete a morph knowing his name ?
    The label is not the name - the label is how the item shows in the UI, but it isn't used for internal manipulations. In any event, you can't actually delete a morph from within DS once it is created, as far as I know - you would, in principle, need to find the asset file on disc and delete (or chnage the extension of) that.
    By
    Richard Haseltine Richard Haseltine October 2016 in Daz Script Developer Discussion
    hello,
    is there a way to delete a morph knowing his name ?
    I'm using this script to detect the name of the group where the morph belong and I get his name using getLabel
    var oPaneMgr = MainWindow.getPaneMgr();
    var oPane = oPaneMgr.findPane( "DzParametersPane" );
    if( oPane ){
    	print ("ok")
     var oEditor = oPane.getNodeEditor();
     var aProperties = oEditor.getPropertySelections( true );
     for( var i = 0; i < aProperties.length; i += 1 ){
      print( aProperties[ i ].getLabel() );
      oGroup = aProperties[ i ].getGroup()
      print( "Group : " + oGroup.name )
    thanks
    By
    ratus69_c6741fefbf ratus69_c6741fefbf October 2016 in Daz Script Developer Discussion
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
