How to delete a morph knowing his name ?
hello,
is there a way to delete a morph knowing his name ?
I'm using this script to detect the name of the group where the morph belong and I get his name using getLabel
var oPaneMgr = MainWindow.getPaneMgr();var oPane = oPaneMgr.findPane( "DzParametersPane" );if( oPane ){ print ("ok") var oEditor = oPane.getNodeEditor(); var aProperties = oEditor.getPropertySelections( true ); for( var i = 0; i < aProperties.length; i += 1 ){ print( aProperties[ i ].getLabel() ); oGroup = aProperties[ i ].getGroup() print( "Group : " + oGroup.name ) }}
thanks
Post edited by ratus69_c6741fefbf on
The label is not the name - the label is how the item shows in the UI, but it isn't used for internal manipulations. In any event, you can't actually delete a morph from within DS once it is created, as far as I know - you would, in principle, need to find the asset file on disc and delete (or chnage the extension of) that.
thanks Richard,
well it looks like it's more a property here that drives a morph
when I import a morph from Zbrush, Daz creates a group, let's call it Zbrush, and put inside the name of the morph
if I go in edit mode I can delete the property with Delete Selected Property
is there a way to do the same with scripting ?
thanks
I'm not sure, but does the deleted property stay deleted when you reload the figure? As I recall (quite possibly incorrectly) it didn't in the past.
if I save the scene with the property and I reload the scene, the property is there but if I delete the property, save the scene and reload the scene, the property stay deleted
there no morph on the disk with the name I gave, it looks like the morph property is only in the scene not written elsewhere
