• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Art & Animations By Ivy Summers
    Richard Haseltine said:
    WendyLuvsCatz said:
    the camera
    it cannot photograph itself
    mine (360 camera not drone, don't have one) added a black circular hole at the bottom like that with the metadata details written in it
    lets face it, with a drone 99% of the time above and beyond the drone you would only ever see sky, they could have been cheeky and stiched a photograph of the drone into the software (or a dragon)
    Ah, I was thinking of the multiiple overlapping exposures used to make HDRis.
     I have a bunch of hdr's I have created and I plan on releasing as freebies , right now I am just enjoying flying the drone and exploring
    By
    Ivy Ivy May 2023 in Art Studio
    WendyLuvsCatz said:
    the camera
    By
    Richard Haseltine Richard Haseltine May 2023 in Art Studio
    the camera
    By
    WendyLuvsCatz WendyLuvsCatz May 2023 in Art Studio
  • DUF Prop Converter for Poser 12
    The resulting import is a static prop; one could do essentially the same thing by exporting from Studio as an .obj and bringing it into Poser...
    By
    WandW WandW May 2023 in Poser Discussion
  • Diffeomorphic - does a step by step tutorial exist?
    Padone said:
    You can use daz favorites in easy import.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Setup/Morphs/Import DAZ Favorites
    Thanks for the link. There is so much information available, but you have to find them in the huge pile wink
    By
    Singular3D Singular3D May 2023 in Blender Discussion
  • DazToHue 1.0 is out now!
    playbox1671 said:
    This is really great work! I've been trying this out recently, and I've had problems with the 'Additional Animations' option. When the additional animations pass through and are exported from the 'DazToHueExport' node, they don't match, and in some cases, the arms and neck of the daz characters are severely deformed. Although I first noticed this Unreal, I checked the fbx file in Houdini, and the skeleton has the same problems before the Unreal import. I'm using the Genesis 8.1 female base character.
    Has anyone else seen this? Is there a best practice for this process?
    Oh darn it!  Apologies playbox167 and everyone else.  I left out a critical piece of information in the tutorials regarding additional information.
    That is, the first frame of the animation must be the default Daz figure pose, otherwise what you describe happens.
    So, I always start my animations in Daz on frame 1, leaving frame 0 as the default figure pose. Then inside Unreal engine I just trim off the first frame of the animation.
    Sorry about missing that critical step in the tutorials.
    Please let me know if that solves it for you.
    By
    mrpdean_7efbae9610 mrpdean_7efbae9610 May 2023 in Unreal Discussion
    By
    Padone Padone May 2023 in Blender Discussion
  • Misc questions about converting to prop and Marmoset Toolbag
    Just have a couple of unrelated questions.
    - Is Edit->Figure-Rigging-Convert to Prop the recommended way to turn a figure or a part of one (using geometry editor) into a static object with no unnecessary bones or surfaces left over? It seems to work from the tests I've done, but I'd just like to confirm.
    - I understand that Marmoset Toolbag 4 still does not recognize UDIMs. Is it possible to still import a DAZ figure into it as an OBJ and apply separate textures to each body part? I'm not really concerned with being able to paint across UDIMs like you can in Substance Painter, but I'm not even going to consider it if DAZ figures do not come over properly. Thanks very much.
    By
    SnowSultan SnowSultan May 2023 in The Commons
  • DForce Cloth
    csteell_c2893e4ab6 said:
    Can I also convert the DForce cloth I have made from a primtive to a prop or figure? If so how? Cheers
    Actually you 'can't convert it' in that way, as the dForce Modifier (dynamic surfaces) and simulated result will be removed after you convert it from a Primitive Prop to a Figure (vice versa) , or after you conform it to a Genesis figure by using Transfer Utility...
    For example, I used a Primitive - Cone to make a 'simple skirt'. The typical SOP should be: Create a Primitive - Cone  > Geometry Editing (Cut top & botttom, Create surfaces, etc.) > Positioning > Export to obj and Import Back > Transfer Utility > Add dForce Modifier > Tweak params on dynamic surface > Add Shaders.. > Simulate it > Thicken it...  (Optional: Convert to SubD, Add Smoothing Modifier...)
    PS: You also can Thicken the object first before using Transfer Utility, but more tweaking on dynamic surfaces might be needed.
    By
    crosswind crosswind May 2023 in Daz Studio Discussion
  • Hair messing up when rotating neck bones on blender
    Ook said:
    crosswind said:
    Ook said:
    crosswind said:
    I tried this Zoren Hair but have not seen such an issue. I used the latest DDI - 1.7.1.1566 and DazHairConverter 2.1.2
    You may first try Easy Import or update to latest DDI ...
    Were you using the MHX rig?
    I tested zoren hair and for this one keyshaped bone works fine but the head bone doesn't.
    Yes, rigged...neck and head bones work all fine. And the rigging on your side seems not that correct... not sure... Have you updated MHX addon recently ?
    I have the one that came with diffeo. MHX version is 1.7.0.0067...
    Maybe I'm doing the process wrong? Just merge rig > convert hair > then rig to MHX right?
    Yea, your process was correct, only my MHX version is 1.7.0.0069... but I found no info. related to such the issue in the Commits log of MHX runtime, not sure... Will you just update and try again?
    By
    crosswind crosswind May 2023 in Blender Discussion
    I am attempting to get a g8f model with geografts into blender - with Diffeomorphic 1.7.0 I am able to use the easy import with merged geografts, all of the textures transfer correctly and all of the geometry appears to be correct, I am just completely lost on the process of making morphs accessible/applying morphs and then finishing a mesh in a way which allows me to modify the morphs after. As it stands, I can see and access baked morphs, but attempting to modify them produces no visible results on my mesh, and importing morphs directly (from golden palace, for example) also results in morphs in the settings which seem to produce no visible results when adjusted. I have both downloaded the Diffeomorphic manual and read it online, and although I definitely appreciate how detailed the descriptions of each of the features are, I am still really missing a more step-by-step idiot guide and am just wondering if anyone knows if such a thing is available. Thanks!
    By
    jerbus.franklin jerbus.franklin May 2023 in Blender Discussion
    By
    Ook Ook May 2023 in Blender Discussion
    By
    playbox1671 playbox1671 May 2023 in Unreal Discussion
  • How do you send G9 strand based hair into Zbrush with GOZ?
    If an SBH is exported without line tesselation generated, ZBrush even cannot import obj file while blender can but the hair is not sculptable..only editable. At the end of the day, obj cannot be loaded back to Ds.
    By
    crosswind crosswind May 2023 in The Commons
    By
    Even if you can export an SBH to obj with Line Tessellation generated, you have no way to import the morph back to the hair... Only a PA has THE 'toolset'..
    So just use a couple of D-Formers to 'reshape' it...
    By
  • Is it possible to "Bake to transforms" for all keyfames in animation
    useful tip for those who use Carrara
    Genesis 3,8,8.1&9 in Carrara using the discontinued Mimic for Carrara and Fenric's BVH exporter will bake the facial bone animations
    and Carara BVH exported animations including facials import to DAZ studio for those figures
    By
    WendyLuvsCatz WendyLuvsCatz May 2023 in Daz Studio Discussion
  • UV Mapper help
    If you don't want to go through a lot trouble making regular UV maps and just need or want a quick UV map to paint in a 3D painting program like ArmorPaint ($20), Blender's automatic UV unwrapping features are fairly easy to use and there are tons of tutorials out there... plus if you decide you like it, there are a bunch of great plugins (called "Addons" in Blender-world) that will make it even more useful.
    The only drawback with most "Auto-unwrapping" programs is they tend to break the map up into lots of tiny bits instead of the more familiar "pelt map" most of us are familiar with... there are a few that do a great job of that automatically, but they are pretty expensive...  Rizom UV (Virtual Spaces) is one, but the Perpetual Indy License is $167... there are others, but they are all around $200 - $300...
    I use 3D Coat a lot, it's auto unwrapping feature is better than Blender if you don't like messing with the unwrapping manually too much... but it's expensive (around $370... I got mine on sale for like $180 a few years back)... 3D Coat is also a modeling/sculpting program and you can do 3D painting in it too.
    If you don't like Blender at all, Ultimate Unwrap ($50 - $60) is pretty good, but you need to learn how to use it to unwrap manually and there aren't a lot of tutorials and it expects you to already understand UV mapping somewhat... but it has a lot of features and if you get the pro version which is around $60, it comes with a huge import/export file conversion capability list... not that you'll need most of the formats, but it generally is pretty good with Theo one that count.
    Lastly... the guy who created Ultimate Unwrap (Brad Bolthouse)... (that'd make a cool superhero name), used to have a simple UV unwrapping program call "LithUnwrap" for free on ShareCG... it was the predecessor to Ultimate Unwrap, but it disappeared from SCG a few years ago and I recently came across it again on GitHub... I haven't tried this version out and it's been years since I dabbled with the on that was on SCG... but here the GitHub link...
    https://github.com/timdetering/HomeworldSDL/tree/master/tools/editors/texture/LithUnwrap
    If I recall correctly, it was about the same more or less as the free version of UVmapper.
    Then there is Roadkill which was a good (Free) simple mapper that was easy to use and learn, but that disappeared about 6 or 7 years ago when the site that was hosting it closed down.
    By
    McGyver McGyver May 2023 in The Commons
  • Custom G2F keeps crashing Daz
    Liphisbus said:
    crosswind said:
    I also use that plugin but haven't encountered any issue like this... Which morph splitter plugin did you use in VAM ?  1) After blending the converted morphs, export your custome G2F to obj and import back as a single dial, then see if that'll be okay or not... 2) If the issue still persists, try to use some VAM default characters to convert, see if you'll still have such an issue...
    PS: attach your Ds log if possible...
    Not sure what you mean but I didn't use any plugins, I just transferred the full characters or "looks" that the people offered in there. I'II see if I can do the first one. Weird, I posted my crash log in the OP but it's gone, here you go if that's what you mean?
    Not this log ~ Daz Studio menu, Help - Troubleshooting - View Log File...
    Okay, you did not split Head and Body morph in VAM, but suggest you do so. On the page of Vam to Daz 2, the author gave the guidlines...
    By
    crosswind crosswind May 2023 in Technical Help (nuts n bolts)
    By
    Liphisbus Liphisbus May 2023 in Technical Help (nuts n bolts)
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
Create An Account
