can't install Glute and Breast Control Bundle for Genesis 8 Female
Hi, i bought [Glute and Breast Control Bundle for Genesis 8 Female] this bundle but it doesn't appear in DAZ central and manual installation is... very difficult with DAZ3D.
I don't know where to install it, because it doesn't work when i put it in "my daz 3d library"
If someone could help me, it would be great !
(sorry for my poor english)Genesis 8 takes forever to load...to be honest I'm not sure I understood what you did there.. just to be sure anyway, when you add one or ten folder you mean you copy the relevant dependencies folders, too? because otherwise you are going to make things worst and slower..
for example inside each package you download/install, you have folder like /data /people /runtime. if you only take the data folder you'll have issues..
that's why my suggestion was not to remove everything and add stuff randomly, but to check what has issues and what slows down the loading times.. I attached a screenshot taken from the program I use to check the log file.. as you can see there's something that slows down the loading times for 16 seconds.. the full line of the log will tell you exactly where to look.. so for example if it reports the affected character is /genesis 8/johnny I move that character to a different folder. this mean remove ALL folders that character install into my pc.. it happened to me for maybe 3 characters form another store.. but as I said you'll need to check the package file you got from the store or to simply uninstall with DIM/Daz Central..
I know it seems hard but at the end of the day is better than proceeding randomly, imo..
about the rest, it should make no difference from where you load stuff, if from smart directory or content library. anyway you can right click on a content, choose Choose Custom Action, select Favorites form the Root menu dropdown and make a shortcut to that content directly into the main daz menu, so that you can load that content with a single click.
Las but not least, generally speaking Genesis 8 has longer loading times; same as Genesis 3 has longer loading times compared to Michael 4. I hope this will not be a constant for the future.
No need to remove all character related files, only the ones in ...\Data\Daz 3D\Genesis 8\[Gender]\Morphs\... will be read when loading a Genesis 8 character.
The files in ...\People\... are the ones you see in content manager, but those are "just" triggers for the morphs and have nothing to do with slow loading
Files in ...\Runtime\Textures\... are just textures and only the ones used in the loaded character are being read - Even if you remove the character morph, you can still use it's textures.
There is no \data\people\runtime\
The way Marksinister has been tracking down the problem, is a good way to do so.
When loading previously saved scenes, there are two more locations to check for morph files that can be removed;
...\Data\Daz 3D\Genesis 8\[Gender]\Projection Morphs\... and ...\Data\Daz 3D\Genesis 8\[Gender] Eylashes\Morphs\...
No Suits for Genesis8 [commercial]There is NO ReadMe file included with the product, at least not with my install via DAZ Central, or in the manual download zip files. Is that an error in the included download files, and a ReadMe actually exists? If so, how about linking it here or something please.
DazCentral vs Install Manager vs Connect confusionShould I leave it for now and hope that DazCentral becomes the new All-in-One feature?It won't. Note that Central is NOT "the latest, greatest, all-in-one", it's a simplified cut-down version of DIM specially designed for new users, who have a track record of getting confused by the full range of DIM features. And if you're not a new user, if you know how to modify and control your content library, a lot of people have realised too late that Central has a habit of destroying your custom content settings, replacing everything with the base defaults. If you're happy with Connect or DIM and find it easy to use, stay with it. There are way too many posts here from people who tried it and regretted it. IMO Central's just too trigger-happy with that default reset.
After 20+ years...My rule of thumb: if it has Smart, AI (and similar) in its name, leave it the hell alone because it wont be close; nor will it allow for smart useage.
Amen to that, and I usually add the words automatic and central to that list. What makes it doubly ironic is that the one thing that DAZ has come out with that works exceptionaly well is called DIM.
Haha.
Good point; I've said it does what it says on the tin, and does it well. I'm not sure how someone can have issues with DIM and expect to manage Studio - but that is apparently the reason for Daz Central.
No Sitric Hair download? (Solved)!These issues only started to happen at the same time they rolled out DAZ Central. And I think we can all agree what an unmitigated disaster that has been for anyone who has tried to make that switch!
It happened before - the only oddity is that it now says Daz Central is available when it isn't.
I too am still unable to download this product, which is annoying as I love Redz' stuff! Why couldn't this have happened with a product I wasn't to impatient to download? XD
No Sitric Hair download? (Solved)!Ticket submutted to either make available thru DIM and/or manual install or refund.
That's the only way to get Daz to realize we don't want Daz Central as long as it destroys the functionality of the current content setup.
Problema en la instalación ayuda!!!!Logre instalar Daz3d, pero la libreria esta vacia!!! DIM al ingresar email, diche no estar registrado... aunque daz ya me registro como usuarioStill using the online translator ;-)
nótese bien. Todos estos Daz Central y DIM solo pueden funcionar con UNA cuenta de correo electrónico a la vez. En algún lugar dentro de DIM es un lugar para poner el correo electrónico / contraseña de Daz3D.com para que pueda iniciar sesión en su cuenta y saber qué hay para descargar e instalar. Si recuerdo correctamente, es bueno también iniciar sesión en la TIENDA [no en los foros] cuando intento usar DIM. También tenga cuidado con DIM y Daz Central que están descargando en el lugar que USTED desea. {de lo contrario, las cosas tienden a terminar en una nube en alguna parte}. Si en algún momento decide que no quiere tener nada que ver con DIM y Daz Central, puede ingresar a su cuenta, a la "Product Library" y hacer clic en el botón "manual" para descargar elementos :-)No Sitric Hair download? (Solved)!I'm in the same boat. I tried to install the hair product and couldn't find it. I opened DAZ Central and then my DAZ Studio went down; mostly white screen, couldn't load anything. It looked like DAZ Central tried to eat DAZ Studio. Then, after a reboot, lost a monitor input and no DAZ at all. Just WOW. I had to uninstall DAZ Central (which deleted my DAZ Studio) and then reinstall DAZ Studio via DIM (which had to then also update).
What a mess!
DAZ Studio finally opened ok, still no hair product .. I'm afraid to download DAZ Central.
Definitely wait for the fix; you do not want to swap DazCentral for your normal install method.
Problema en la instalación ayuda!!!!Hola necesito ayuda!!! eh intentado instalar Daz con 3 correos diferentes sin tener resultado, en principio me registre normalmente como indica y la pagina principal me descarga Daz Studio central al ingresar el email y contraseña no la reconoce como registrada siendo que si me dio la bienvenida y elalta de registro
lo mismosucede con install manager al colocar el email como la contraseña no lo reconoce
Como lo bien lo expresó Catherine, hay varias cosas a considerar:
- DAZ Studio | este es el programa
- DAZ Install Manager y Daz Central | son dos maneras de poder descargar el contenido para DAZ Studio. Se recomienda se utilize solo uno de estos.
Ahora una vez que te haz registrado (sign-up) con tu email y hayas creado tu contraseña, revisa si no tienes algún email de confirmación (lo hice hace tanto tiempo, que no recuerdo si mandan uno o no). De no tener uno, acude otra vez la pagina de descarga pero esta vez selecciona en la parte de abajo "Login Here". Ingresa el email y la contraseña con la cúal te registraste. Esto te debe llevar a una pagina en donde podrás descargar DAZ Studio, DIM (Install Manager) y DAZ Central.
What a mess!
Hello, I'm using the online translator so this might not all make sense.
1. Your email address is never the password.
2. The password would be the password that you use to log into the store.
3. Under "My Account" there is a "My Serial Numbers" page - there you will find a serial number for Daz Studio 4.x Pro. That is to be entered into the Daz Studio program.
4. When logging into the store via DIM or DazCentral, I think it would be your store login password it needs. {I do not use these utilities}.Hola, estoy usando el traductor en línea, por lo que esto podría no tener sentido. 1. Su dirección de correo electrónico nunca es la contraseña. 2. La contraseña sería la contraseña que utiliza para iniciar sesión en la tienda. 3. En "My Account" hay una página de "My Serial Numbers", donde encontrará un número de serie para Daz Studio 4.x Pro. Eso se ingresará en el programa Daz Studio.
4. Al iniciar sesión en la tienda a través de DIM o DazCentral, creo que sería la contraseña de inicio de sesión de su tienda lo que necesita. {No uso estas utilidades}.No Sitric Hair download? (Solved)!From past issues, when you see Daz Central only as a download, it seems to be a case of 'NO' download set-up for any method. But it will be fixed at a point in the morning. Although this is 3 July and a 3 day holiday for our 4th of July holiday in America.
Changes Made without My ConsentDaz Central... Just say no...
You probably need to uninstall and reinstall Daz Studio
I would use DIM...
Steve.The new Daz Studio UpdateI feel like an idiot, because I had no clue of the new update and now that I do...how do I get it. Been having Dforce problems of late and hoping it will fix them
You can download the update through either DAZ Central or DAZ Install Manager but I recommend not updating yet, I updated and have no access to DAZ studio and it seems like other people are having issues with DAZ appearing as a ghostly white color after the update. I would recommend sticking with your current version and waiting for the next stable build. In my case I can't install it whatsoever. I tried using both DAZ Central and DIM and it doesnt install the update but it did delete my previous version so now I have no way of using DAZ :(
UPDATE: Installing through DAZ Install Manager works.
