• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Is it possible to transfer UV maps to new figure?
    kaotkbliss said:
    but getting it back into DS at the exact correct size is a pain and I have not figured the correct import scale yet.
    I don't know how you have tried, but blender unit is 1 m, while Daz Studio is 1 cm, so a factor 100 in difference..You must correct either when exporting from blender or when importing into DS.
    By
    felis felis July 2023 in Technical Help (nuts n bolts)
    Yep :(
    The thing is, I like the result I get from merging the 2 objects in Hexagon, except for the wiping of the UV textures
    I like that Blnder's diffeomorphic can merge the 2 without losing the UV maps, but getting it back into DS at the exact correct size is a pain and I have not figured the correct import scale yet.
    By
    kaotkbliss kaotkbliss July 2023 in Technical Help (nuts n bolts)
  • What do people here use to animate?
    Padone said:
    benniewoodell said:
    it's still not perfect as there's still feet slippage
    That means you didn't bake to FK before exporting, or didn't bake correctly, remember that daz poses are FK so you need to bake IK to FK. Plus now Thomas is working to support hierarchy poses, so you can animate figures with geografts in blender then export the pose preset for daz studio directly from blender.
    Then personally I'm not interested to import animations back in daz, I mean blender is so much better to animate and render.
    https://bitbucket.org/Diffeomorphic/import_daz/issues/1603/
    I totally did bake to FK before I exported, I'm following the instructions you've shown me before.
    I agree Blender is so much better to animate in, but my clients need these animations rendered out quick and I can't get cycles to render nearly as good quality as I can render in iray in the same amount of time. I can render frames at 1920x1080 in iray in 45 seconds to a minute with the post denoiser on and it's looks perfect with no streaks, but I can't get cycles to render without it looking all water painter-like unless I bake for at least 6 minutes and I've gone through all the youtube videos on how to render out cycles faster, and I can't apply any of that to Daz models. So I'm kind of stuck needing to use Daz to render because the difference is astronomical in terms of rendering. For personal projects, I just let it run as long as it needs to in Blender, but I can't do that when clients want the turn around that they do.
    By
    benniewoodell benniewoodell July 2023 in Daz Studio Discussion
    By
    Padone Padone July 2023 in Daz Studio Discussion
  • Is there a way to disable the influence of a morph only on certain area of the cloth in daz3d?
    James said:
    The only way to selectively block is to create a custom morph for the ones you want to block (which must use the same name, not label, to work).
    So... there will be another morphs to specially counter the effect?
    Can't the existing morph be somehow edited in daz?
    Sorry I don't get it.
    No, instead of lettign DS create a morph on the fly you make one explicitly to match the shape and adjust it as required. The posts above offer one fix, but a smoother option would be to export the morphs clothing as OBJ, making sure the name matches the morph name, making a note of the rpeset used (Daz studio would be logical), then apply a dForm to the clothing and paint in a weight map to mask out (or in) the areas you don't want affected - then you can clear the morph from the base figure, reload the clothing (so it doesn't have the generated morph - though you an also clear generated morphs from the figure menu if you just zero the morph on the base figure) and open Morph Loader Pro you can import the OBJ and in the Attenuate section select the dForm with the weight map - you can then choose whether the weight map excludes or includes the morph, depending on what you painted in.
    By
    Richard Haseltine Richard Haseltine July 2023 in Daz Studio Discussion
  • Confuse! My morph acts unexpectedly
    Zero hijab's and export to obj;
    Fix in Blender and export obj;
    Import obj with Morph Loader Pro : Reverse Deformations - Yes and Overwrite Existing - Delta Only
    By
    crosswind crosswind July 2023 in Daz Studio Discussion
    I also use MD but in most cases I must use ZB/Blender as well since 'MD only' cannot get everything 'well done'. In your case, the way to 'selective fix' is just as Richard said... or you resimulate the garment in MD with necessary Freeze or Pin and import back as a delta...
    By
  • [SOLVED] Exploding FBX Objects when importing into Daz
    Looks like the best way is to open the product in blender then export it as a collada product...and manually readd the textures, which is fine
    I bought a couple of products at turbosquid, and one file option was fbx; however, when I try to import them, they blow up.  The files look fine in Blender, but when I go to import, the model looks like something from the Matrix. 1. What am I doing wrong (this is with all 3 products I bought)
    2. Is there a simple way (that is not simply importing an obj file) to bring these in, where I can hide certain objects, so I can see where I can place others (this is mainly for a gas station)
    3. I'm find re-adding texture, but is there a simpler way to bulk add it?
    4. If a product has movable parts (doors, windows, etc), I assume I would have to add the morph in DAZ?
    Or should I simply start using Blender?
    By
    shg0816_13461e8196 shg0816_13461e8196 June 2023 in Blender Discussion
  • How to make dforce not holding on the initial fabric folds?
    James said:
    I have a problem.
    I make a hijab.
    The front part is up to covering the breast
    Then I make a morph to anticipate bigger breasts by making the front hovering in the air a bit,  as the initial position for dforce.
    In doing so the fabric has more folds initially.
    When I simulated, the result is, the fabric has a bit of unnatural folds/creases when draping. As if dforce trying to hold on to the initial folds.
    What is the solution for this?
    While sometimes it can work, dforce isn't meant for making morphs. Make the morph in the hijab by sending it and the figure with larger breasts dialed in, over in the modeller. Then dial out the morphs in D/S and select the clothing. Then either via the bridge or via import, bring the morphed hijab back into D/S via Morph Loader Pro [advanced bridge setting in D/S if using Hexagon bridge]. Reverse shape, yes. If the morph looks to be good, then zero it and save it. Then load a fresh clothing piece, restore the figure to high res [goes to base when using Hexagon], and try the simulation again.
    It's also possible to adjust the simulation settings, i.e. for thicker, heavier cloth, or lighter fly away cloth. And of course one can put a weight map on it and freeze the portions that are not to be affected, or only affected a little bit, when simulated.
    By
    Catherine3678ab Catherine3678ab June 2023 in Daz Studio Discussion
  • Opulent Bathing Vignette can't be found after installation in DS
    daveso said:
    PerttiA said:
    I have the installation file I downloaded on Wednesday at 3AM Daztime
    The Manifest refers to the original locations and the only change I see, is Daz adding "Daz Originals" after "Environments".
    Should not prevent one from using the set from the Content Library -> Daz Studio Formats -> Environments -> Daz Originals -> Opulent Bathing Vignette
    it dies noit ven show up in content library for me ... I only have 1 product listed under DAZ Originals and its not this one. I tried installing manually and that did not help.
    Just installed it (manually) and it works just fine.
    The Daz Studio Formats -> [Your Content Library] is showing everything you have installed in your Content Library as it can be seen in Windows Explorer, no matter if the metadata or manifests are wrong
    By
    PerttiA PerttiA June 2023 in The Commons
    Well, I first uninstalled on my Win10 laptop the DIM installation. Then I did a manual download and I manually added the files into the appropriate areas as I would if I had purchased the product from Rendo. The environments showed up, but when I tried to load a scene, I got a warning it couldn't find the textures. Additionally, there was no metadata for any files.
    I am no way an expert, but I would think this is an issue caused by Daz, and needs to be fixed by them and released to everyone who purchased the product. It is a gorgeous set and deserves the best Daz can do for it.
    Mary
    Add note: I allow DIM to download and install files as it will does. The most I do is add metadata for old files, add additional metadata for my sub-categories, but file structure where it is downloaded I leave alone totally. And until I had seen this thread I hadn't had a chance to look at this product this morning. Those thunderstorms have been wicked around Denver and I didn't want a computer to fry.
    By
    memcneil70 memcneil70 June 2023 in The Commons
  • Which generation(s) of poses work with standalone figures?
    tubbesing said:
    Is there an easy way to tell which generation(s) of poses work with standalone figures?
    F’rinstance, Lil Alien Guy is a standalone figure. Will he/it work well with Genesis 3 poses, or G8, or G9? Put another way, Ultimate Pose Master by V3Digitimes works with Genesis 3, 8, and 8.1. Will it work with a character like Lil Alien Guy? Is it just a matter of tweaking constraints, or are there more fundamental conflicts?
    Thanks.
    Another possibility to consider is importing/exporting BVH files (basically a look-up table of bone names and rotations). DS allows for the creation of maps that can be saved/loaded. These maps translate certain bone names from one figure to the other.
    So, for example, you could export a BVH file with a posed g9 selected and accept the default mapping. Then, select your custom figure and import the BVH file. When the dialogs pops up, make sure you click Show Details. Adjust the settings to map the transfer between the two. Save it for future use.
    HTH.
    - Greg
    By
    algovincian algovincian June 2023 in Daz Studio Discussion
  • Daz Studio 4.21[.0.x] Pro, General Release!
    Pakmule said:
    bishbosch said:
    Is there up-to-date documentation for the new (and old) FBX export settings? The environment I'm trying to transfer to Unreal as an FBX is exploding, with parented things like windows and doors scattering, which wasn't happening before.
    I can't export anything to Character Creator 4 anymore. I have tried all sorts of combiations in the new FBX dialog and CC4 still blows up on import.
    Did you find a solution? I too am trying relentlessly to get CC4 conversion from Daz G8M? Think I might roll back to 4.20 as I only use Daz now for exportation of assets.
    Post Edit - Should anyone encounter problems when exporting to CC3+, I found a solution to lock all the morphs before exporting to .fbx. I was getting my character into the software ok, but I discovered all the body morphs etc. were being dropped at the conversion stage. By locking the morphs prior to export I now have my character looking as it should. This is just my hack for now, so if anyone has another method or workaround, please let me know.
    By
    Fungible User Fungible User June 2023 in Daz Studio Discussion
  • Something wrong with geometry editor's merge graph?
    Even using the base G8 character with no morphs whatsoever, I get the same result.
    Diffeomorphic inblender does a real good job of merging the graft to the character, the only issue I have with that route is the obj size when importing back to DS to transfer the rigging. If I can get that scaling number down for the import, then I can continue with the blender route.
    Manually welding in hexagon results in a beautiful character that transfers easy and the bends look fantastic (as fantastic as the bends can look without JCMs and corrective morphs being used) but the UV is obliterated.
    I was just seeing if there was an easier method to take in doing this and am surprized DS's merge graft in the geometry editor has this issue (at least in this region of the character).
    By
    kaotkbliss kaotkbliss June 2023 in Technical Help (nuts n bolts)
  • Hot New (Northern) Season, New Sales Thread: Report Issues Here "Reporting Only"
    tombraider4ever said:
    I just bought this: https://www.daz3d.com/opulent-bathing-vignette but I can't find it either at my smart content filtered by most recent purchases or where the read me says it's supposed to be. Searched Daz for Opulent, nope. Please, if someone knows where it is can you tell me? Need help w finding it, downloaded through daz dim. Updating the meta data for smart content now, hope that will solve it.
    Metadata updated, still no Opulent bathing thing. Would be fun to actually find what I buy at where it's supposed to be..Or anwhere.
    Edit: I was looged out in daz studio, looged in to find this at smart content, under enviroments, architecture, BUT there is noting there when I click on it!! Downloaded through daz dim, looked through installed in dim to check as I always do, it was there. In daz: NOPE!! I get no such file exist message when I cl the smart content pick! Helpe needed w this, thanks in advance.
    Edit 2: Downloaded manually, and the product at smart content enviroment, architecture is still broken, says no file exist but I found it under environments, daz originals normally in daz, outside the smart content. I still want to download it in dim so I get updates on it, so I still need this fixed, thanks. I re imported the meta data after downloading manually and now it's under smart content enviroments and the link works, but doesn't show under all files, recent bought sorting.
    I am having the same problem and started a thread about it as this seems more of a technical issue than a sales issue. You are welcome to join the convesation. smiley
    By
    BlueFingers BlueFingers June 2023 in The Commons
  • Diffeomorphic: Bendy Buttocks & Swollen Thighs (Vice Versa)
    Sure, you can import jcms with morphs > import standard morphs, then to transfer the jcms to the outfit you use morphs > transfer shapekeys, the vendor morphs will be used when available. Or just select the options in easy import for a new figure.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Setup/Morphs
    By
    Padone Padone June 2023 in Blender Discussion
    By
    tombraider4ever tombraider4ever June 2023 in The Commons
    Padone,
    Thanks for the tips! I re-imported the G8.1 figure with JCM option set and loaded the pose. This time the figure morphed well. My question now: is there a way to import the JCMs for a figure I previously imported from Daz without JCMS? I've gone on to customize the figure in Blender and I'd like to avoid having to repeat the work with a freshly imported one.
    Related to all this, the Diffeo blog talks about JCMs specific to the Genesis figure. Looking through the Daz application file system, I found many wardrobe DUFs with the "JCM" label in their file names. When we instruct DIffeo to import from DBZ with the JCM option set, does DIffeo gather the JCMs for the wardrobes as well?
    I ask this because I see the wardrobe belts squished in a way I do not with the same figure and pose in Daz Studio. My thoughts are that if we can import JCMs for a figure into Blender, why not the JCMs for wardrobes too.
    Cheers!
    By
    csaa csaa June 2023 in Blender Discussion
  • New RTX 4070ti Can’t Render
    At the bottom of the log it says it can't find a useable device. I only tried to render a bird. No environment.
    2023-06-28 08:24:03.034 [INFO] :: Loading Layout: C:/Users/User/AppData/Roaming/DAZ 3D/Studio4/layout.dsx
    2023-06-28 08:24:13.822 [INFO] :: Prepare asset load (open): /Props/Stuffed Animals/Polygonal Miniatures/PM-Stuffed Animals/PM-Rode_Ibis.duf
    2023-06-28 08:24:13.822 [INFO] :: Locking viewport redraw...
    2023-06-28 08:24:13.822 [INFO] :: Viewport redraw locked.
    2023-06-28 08:24:13.853 [INFO] :: Native format content directories: 2
    2023-06-28 08:24:13.853 [INFO] :: Poser format content directories: 2
    2023-06-28 08:24:13.853 [INFO] :: Other import format content directories: 0
    2023-06-28 08:24:13.853 [INFO] :: Begin asset load (open): /Props/Stuffed Animals/Polygonal Miniatures/PM-Stuffed Animals/PM-Rode_Ibis.duf
    2023-06-28 08:24:13.862 [INFO] :: *** Scene Cleared ***
    2023-06-28 08:24:13.862 [INFO] :: Determining missing assets...
    2023-06-28 08:24:13.889 [INFO] :: Setting textures...
    2023-06-28 08:24:13.890 [INFO] :: Scanning for addons...
    2023-06-28 08:24:13.892 [INFO] :: Creating node geometry...
    2023-06-28 08:24:13.894 [INFO] :: Creating UV sets...
    2023-06-28 08:24:13.894 [INFO] :: Creating materials...
    2023-06-28 08:24:13.897 [INFO] :: Resolving legacy figures...
    2023-06-28 08:24:13.897 [INFO] :: Sorting property groups...
    2023-06-28 08:24:13.897 [INFO] :: Setting up follow targets...
    2023-06-28 08:24:13.897 [INFO] :: Finished asset load (open): 0m 0.43s - /Props/Stuffed Animals/Polygonal Miniatures/PM-Stuffed Animals/PM-Rode_Ibis.duf
    2023-06-28 08:24:13.927 [INFO] :: Unlocking viewport redraw...
    2023-06-28 08:24:13.927 [INFO] :: Viewport redraw unlocked.
    2023-06-28 08:24:14.291 [INFO] :: Loaded image: Rode_Ibis-N.jpg
    2023-06-28 08:24:14.335 [INFO] :: Loaded image: Rode_Ibis-T.jpg
    2023-06-28 08:24:32.708 [WARNING] :: QColor::setRgb: RGB parameters out of range
    2023-06-28 08:24:32.750 [INFO] :: Rendering image
    2023-06-28 08:24:32.768 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Users\Public\Documents\My DAZ 3D Library\Runtime\Textures\Polygonal Miniatures\Stuffed Animals\Rode_Ibis-T.jpg", no selector, pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.
    2023-06-28 08:24:32.769 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Users\Public\Documents\My DAZ 3D Library\Runtime\Textures\Polygonal Miniatures\Stuffed Animals\Rode_Ibis-N.jpg", no selector, pixel type "Rgb", 8192x8192x1 pixels, 1 miplevel.
    2023-06-28 08:24:32.777 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\resources\DTHDR-RuinsB-500.hdr", no selector, pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.
    2023-06-28 08:24:32.806 Iray (Scene Update) : Updating LPE labels
    2023-06-28 08:24:32.807 Iray (Scene Update) : Updating geometry
    2023-06-28 08:24:32.807 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2023-06-28 08:24:32.807 Iray (Scene Update) : Retrieving geometry
    2023-06-28 08:24:32.807 Iray (Scene Update) : Updating motion transform data
    2023-06-28 08:24:32.807 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating motion transforms.
    2023-06-28 08:24:32.807 Iray (Scene Update) : Updating section objects
    2023-06-28 08:24:32.807 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2023-06-28 08:24:32.808 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Auto instancing compression ratio 1.00 (Full instancing compression ratio 1.00)
    2023-06-28 08:24:32.809 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2023-06-28 08:24:32.810 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 21924 triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 21924 triangles, 0 fiber instances yielding 0 segments) took 0.002 s
    2023-06-28 08:24:32.810 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating section objects.
    2023-06-28 08:24:32.811 Iray (Scene Update) : Updating materials
    2023-06-28 08:24:32.811 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2023-06-28 08:24:32.813 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 2 textures, 0 lambdas (0 unique)
    2023-06-28 08:24:32.813 Iray (Scene Update) : Updating volumes
    2023-06-28 08:24:32.813 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating volumes.
    2023-06-28 08:24:32.813 Iray (Scene Update) : Updating environment
    2023-06-28 08:24:32.814 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
    2023-06-28 08:24:32.820 Iray (Scene Update) : Updating lens data
    2023-06-28 08:24:32.820 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
    2023-06-28 08:24:32.821 Iray (Scene Update) : Updating lights
    2023-06-28 08:24:32.821 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2023-06-28 08:24:32.821 Iray (Scene Update) : Updating instance topology
    2023-06-28 08:24:32.821 Iray (Scene Update) : Updating flags
    2023-06-28 08:24:32.821 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2023-06-28 08:24:32.821 Iray (Scene Update) : Updating backplate
    2023-06-28 08:24:32.821 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
    2023-06-28 08:24:32.823 Iray (Scene Update) : Updating portals
    2023-06-28 08:24:32.823 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
    2023-06-28 08:24:32.823 Iray (Scene Update) : Updating decals
    2023-06-28 08:24:32.823 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2023-06-28 08:24:32.836 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
    2023-06-28 08:24:32.837 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2023-06-28 08:24:32.844 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
    2023-06-28 08:24:32.844 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(369): Iray [ERROR]
     - IRAY:RENDER ::   1.0   IRAY   rend error: Cannot render: found no usable devices. Please update your NVIDIA driver (www.nvidia.com)
     to at least 471.41, or enable CPU-only rendering.
    2023-06-28 08:24:32.844 [ERROR] Iray :: Invalid parameters (NULL pointer).
    2023-06-28 08:24:32.927 [INFO] :: Saved image: C:\Users\User\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
    2023-06-28 08:24:32.932 [INFO] :: Finished Rendering
    2023-06-28 08:24:32.957 [INFO] :: Total Rendering Time: 0.26 seconds
    By
    andrewburgon andrewburgon June 2023 in Technical Help (nuts n bolts)
  • Diffeomorphic DAZ Importer version 1.6.0 released
    It depends. Poses in daz studio are quite complex and they may include morphs too. If the pose only affects bones then it should import fine. If the pose also affects morphs then you have to import the needed moprhs or the pose will not work, in this case you should get a warning for missing morphs in the console.
    Please note that body morphs are not compatible with ik so you can only load them on the daz rig.
    Then if you're sure you did it all right and that's a bug you can report it at bitbucket for Thomas to check.
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
Create An Account
