• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Iray in DAZ or migrating to Blender?
    For those of us who use Daz to generate images for comics and such, exporting to Blender and then fiddling with the materials just takes too long.
    You're just using it the wrong way.
    The thing with blender is once you import your content you can do whatever you want. Especially with effects and simulations that are great in blender. But also for sculpting and character customizations. Plus there's eevee that's great to render fast and that's good for comics as well as for animations. This is worth fiddling a bit. A viable comics workflow will be to first export the assets, then use them in blender and work in blender to pose the characters and setup the scene and lights. Sticking to work in daz studio then exporting every single scene just to render it in eevee or cycles does not make much sense.
    But in another discussion I asked about creating a library of figures, props, environments, etc., in Blender and I understood the response to say that there is no such concept as a content library in Blender. I don't get how to compile scenes within Blender without access to the DAZ Studio library.
    The Blender devs have recognized that asset management is an area that needs work, and as I understand it improvements are coming.  Not sure what it will look like.  Meanwhile, the old school method of organizing your content in folders and within library .blend files for different types of content still works.
    Keep in mind Blender is not designed primarily as part of a marketing strategy for content from one particular online store.  It has to encompass content from any source, including self-made.  So a content library very like Daz Studio's isn't possible: I don't think you will ever have a BIM and Blender Central to work alongside a Blender content library.
    By
    andya_b341b7c5f5 andya_b341b7c5f5 September 2020 in Daz Studio Discussion
  • Introducing the all-new Daz to Unreal Bridge & native Unreal File Formats
    I'm so so excited about this, and I'm trying to figure out - is this Mac compatible? I can't seem to locate the plugin installer in either DIM or DAZ Central.
    By
    Storypilot Storypilot September 2020 in Unreal Discussion
  • Installing Daz to Blender plug in for Blender on Mac?
    For me, the needed zip file to install in Blender 2.9 was located here:
    /Users/myusername/Library/Application Support/Blender/2.90/scripts/addons/AppData/Blender Foundation/Blender/DAZ 3D Add-ons
    Daz Central and DIM have been updated so that this manual step is no longer required.
    Thanks. I'll see about updating.
    By
    brainmuffin brainmuffin September 2020 in Blender Discussion
    By
    Richard Haseltine Richard Haseltine September 2020 in Blender Discussion
  • New Updates: the Daz to Blender Bridge 2.0!
    Anyone know how to install this on the Blender side?
    I used Daz Central to download and install. Guess what? That method also installs it in Blender. Just go to Blender Edit/Preferences/Addons. Type daz in the search bar, and if you have the old version installed, you should see the Armature: DaztoBlender. Uncheck the old one and check the new, and voila, the new features including environments are there.
    Whoa, I just tried that with my laptop that I hadn't installed 2.0 yet and it was installed in Blender already from DIM! Great catch!
    By
    benniewoodell benniewoodell September 2020 in Blender Discussion
    Blender:
    1. In Blender, go to Edit > Preferences.
    2. In the Preferences window, go to Add-ons and enable the Daz to Blender
    3. Browse to 'C:\Users\'username'\AppData\Roaming\Blender Foundation\Blender\DAZ 3D Add-ons\'.
    4. Open the tab and choose Import New Genesis 3/8 for Character.
      1. If the character has accessories in there hand run #accessory before importing.
    5. Open the tab and choose Import New Env/Prop for Environment and Prop.
    Daz Studio (advanced import):
    1. Open your character in Daz Studio.
    2. Locate and open the Daz to Blender Bridge, which can be found at the top of Studio under Scripts>Bridges>Daz to Blender.
    3. Click on the Blender HD version of the script in the above path to run the script.
      Blender:
    4. In Blender, go to Edit > Preferences.
    5. In the Preferences window, go to Add-ons (on the left side) > click Install (in the top right).
    6. Browse to 'C:\Users\'username'\AppData\Roaming\Blender Foundation\Blender\DAZ 3D Add-ons\'.
    7. Select the "DTB_v280-283.zip" folder here and choose Install Add-on in the bottom right corner.
    8. In the Preferences window, go to Save & Load on the left side.
    9. Check the box next to Auto Run Python Scripts.
    10. Exit out of Preferences and look for a tab named "DazToBlenderHD" on the right side of the Blender viewport.
    11. Open this tab and choose Import New Genesis HD.
    By
    Raitan2008 Raitan2008 September 2020 in Blender Discussion
    By
  • Diffeomorphic DAZ Importer Version 1.5.1
    No show-stopper bugs have shown up in RC2, so it now becomes the stable version 1.5.0.
    I'm switching to v1.5.0. Still having issues with loading morphs at the Corrections step. For instance:
    - BrowUp-Down<br /> - BrowUp-DownL<br /> - BrowUp-DownR<br /> - CheekCrease<br /> * CheekCreaseL<br /> * CheekCreaseR<br /> - CheekEyeFlex<br /> - CheekEyeFlexL<br /> - CheekEyeFlexR<br /> ...
    I could import them as custom morphs directly from the character's folder and /Daz 3D/etc folders as well. I'm not using the standard Daz folder for the Libraries, but they were updated via Global Settings / Load Root Paths.
    The materials are very faithful to the original Iray shaders, and MHX rig is fast.
    I'm not familiar to Daz internal policies, but you could offer your plugin as an alternative to Bridge, as a Published Artist or via Daz Central.
    Thank you for your hard work. The Daz to Blender importer is a crucial link for my project.
    Regards.
    By
    Fantasyart3D Fantasyart3D September 2020 in Blender Discussion
  • ERROR HAIR CUBE
    Installation issue - use DIM/Daz central or Daz Studio itself to install to avoid such things, but you can fix it by taking everythign out of IM.../Content/ folder in the My Library folder and placing it directly in the My Library folder.
    By
    Richard Haseltine Richard Haseltine September 2020 in Daz Studio Discussion
  • Hair and Katana in Promo
    @KA1 Thanks for that. That does indeed look like the Katana used. :)
    @scorpio I kept coming back to the Helena Hair as well because of the ornaments, but I'm not sure if it is them because the ones in Helena Hair are a completely different style. The ones used in the promo have more intricate curls and a large central stone, plus there appears to be some detailing on the shaft just below the decorative end.
    I'm beginning to think perhaps Crocodile Liu has made the sticks as well since they feature in so many of the promos for different elements, but there's never anything listed in the Products Used or included in the products that the promos feature.
    By
    ObscuroArcanum ObscuroArcanum September 2020 in The Commons
  • Novica & Forum Members Tips & Product Reviews Pt 13
    I really hope they get that Daz Central install button off of there. I almost click it every day I go to download the product pages, it is right there. I have to keep myself from my buttons on the mouse. But one day, I will not be paying attention and I hope there is a failsafe to say 'NO!'.
    Yes, at least as of right now, it takes you to a page where you would have to click several more things before ending up with Daz Central installed.
    By
    Nath Nath September 2020 in Art Studio
    By
    memcneil70 memcneil70 September 2020 in Art Studio
  • OT, Mornington Crescent: Round 8 :- (Tudor Court Rules)
    And surely, 2nd time round,   Archway must lead to
    Archway>Holborn>Arsenal>Tufnell Park>Hyde Park Corner> Hounsow Central>Archway>
    Monument
    Using, of course, the good old-fashioned DCMS variant which I have just invented.
    By
    Chohole Chohole September 2020 in The Commons
  • Not a fan of the new product library layout
    I appreciate that progress has been made in restoring features we asked for.
    They need to stop listening to whoever is coming up with these bright ideas to begin with.  Now if they put it back the way it was, and ditched Daz Central (fat chance) everything would be peachy.
    By
    Sevrin Sevrin September 2020 in The Commons
    Since the Lazarus option has been invoked that allows me to play...
    Archway
    By
    3dcheapskate 3dcheapskate September 2020 in The Commons
  • Papyrus Outfit Textures won't install with Daz Central
    Hello,
    I have purchased the Papyrus Outfit Textures add-on for the dForce Papyrus Outfit and Daz Central is indicating that there is an update for it. However every time that I try to install the update Daz Central gets about 50% done and then terminates the install. Has anyone else had this issue?
    Thanks for any help with this.
    nabob21
    By
    nabob21 nabob21 September 2020 in The Commons
    Seeing as how this trhread resurrects, and we are using the Calvin's Presbyterian version rues, I call the Lazarus option  and run all the way to:
    Hounslow Central
    By
    hacsart hacsart September 2020 in The Commons
  • Skin Builder 8 Merchant Resource for Genesis 8 Female (Commercial)
    Hello everybody. I have installed this product some weeks ago but I never managed to make it work.. Can somebody help, please?
    This is what I did:
    • I installed theproduct via Daz Central
    • The folder is in C:\Users\Public\Documents\My DAZ 3D Library\People\Genesis 8 Female\Materials\Skin Builder 8\Resources\ and inside of it there are many files and folders (blush, brows, eyelashes..) with different pngs
    • When I run the program the product window appears normally and I set the path for the temporary files like this C:\Users\Pelu\Documents\DAZ 3D\Studio\My Librar\Runtime\Textures\SkinBuilderG8FMR\tempFiles
    Now there are two problems:
    1. When I try to build the skin, I can see that it is working for some time in the bottom left corner but then it keeps being busy without properly finishing the skin.
    2. Even if I wanted to just apply some details on an existing skin, the png images of the brows, veins, freckles, moles etc do not appear in the window so I can't use them either because I don't know what I am applying
    Is something wrong with the installation? What should I do?
    Thanks in advance
    By
    pelu pelu September 2020 in Daz PA Commercial Products
  • Water Spring
    Hi, Just purchased the above from the Daz Shop, however it does not show in Daz Central but does in DIM, it also states it requires an update tried to but it will not update, halp please. TIA
    By
    petes images petes images September 2020 in Technical Help (nuts n bolts)
  • Problem with Erik HD G8M and Erik HD for Lee 8
    Just a friendly warning:
    Anyone who has both the newer Erik HD for Genesis 8 Male and Erik HD for Lee 8, be aware. Some Erik G8M files in the Characters directory may overwrite files for Erik for Lee 8, and vice versa, depending on installation sequence. This is probably only an issue for DIM/manual installation (and possibly, but not definitely, Daz Central installation). Connect installs into SKU numbered directories, as I recall, so they may or may not be separate from each other when installed that way. Daz Central reportedly shares some of the same foundations as DIM, so it may be an issue there; I don't use Central, so I don't have any way to find out.
    The main slider for both characters is just called "Erik", so if you have "Consolidate Properties" active, they will combine, because Studio has no way to tell identically named sliders apart.
    The default character directory for both is also just called "Erik" (/People/Genesis 8 Male/Characters/Erik/), so those two directories combine on installation as well.
    I wound up having to delete and reinstall the front-facing files and directories for both characters, renamed so that they wouldn't combine this way.
    In all seriousness, it seems at this late stage of G8, with no immediate sign that G9 is nigh, for characters, the first step in QC should be to see if the name has already been used this generation. If it has, the character should be sent back to the PA, with a note saying, "Sorry, but you need to rename this character to prevent conflicts." Ideally with a checklist of things the vendor would need to fix. This would keep installations from overwriting each other, and it would also prevent Combine Properties from combining similarly named sliders from different characters.
    By
    vwrangler vwrangler September 2020 in Daz Studio Discussion
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
