• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Transfer Utility Hangs At 17%
    The transfer utility hangs at 17%, no matter what my source and destination. Within seconds of starting the utility, DAZ's memory usage shoots to over 7GB. I'm running a high-spec overclocked machine. I'm mostly trying to do various combinations of -
    Vicky 4.2 or Michael 4 with exported then imported morphs --> Gen 2 with the V4/M4 clone
    V4/M4 current --> Gen 2 with clone
    V4/M4 based obj current --> Gen 2 based obj current with near vertices
    Obviously I'm trying to force Gen 2 to in some way accept my V4/M4 morphs - I know a couple of ways to do it and I'm hypothesising a couple of others (eg translate to the vertices on a Gen2 obj then import from there), but I can't get the transfer utility to play ball with any of them.
    Incidentally, I've only been doing this since last night (after the Daz update). I have used the transfer utility in the past - admittedly on low-polygon items - successfully.
    Thoughts?
    By
    deslea deslea December 2013 in Daz Studio Discussion
  • UV Setter for Genesis 2: Revised and Updated
    I got tired of manually changing the UV sets for my Genesis 2 Males and Females, so I made up a set of 10 presets to make it easier. I would like to share them with all of you, if you are interested.
    Use these presets to quickly change the UV map of your character without affecting the material settings. All presets work on both male and female figures. Presets for Poser 9+ are included as well, but while testing them, I didn't seem to need to apply them. All materials I tried to apply already set the UVs. So, if you run into a problem using them in Poser, just let me know and I will see what I can do.
    Included are Basic Male, Basic Female, Gia, Girl 6, Michael 4, 5 and 6, Victoria 4, 5 and 6.
    ***Note that you must have these UV sets installed on your system for the presets to work. So if you don't have V6, then the V6 preset won't do anything and may give an error message.
    Presets are located in My Library/Presets/UVSetterGen2 for DAZ Studio and Runtime/Libraries/Materials/UVSetterGen2 in Poser. Also, I made metadata for these, so after you install them to your content folder, you will need to reimport metadata and make sure you uncheck everything except this product, which should be located at the bottom of the list. If you don't uncheck everything else, you will be changing all the metadata you have already set up.
    (see link below)
    Update March 25, 2014:
    I just updated my UVSetterGen2 freebie today to include Olympia and Stephanie 6, and also to include the Generation 5 UVs for Genesis 2, which will be released in the DAZ Store later this week (subject to change). These UVs include Aiko 5, Stephanie 5, Hiro 5, Freak 5 and David 5. The Generation 5 UV presets will only change UVs on Genesis 2 and will do nothing when used on Genesis. You must own any of the figures listed for the UV presets to change anything. So, for example, if you do not own Victoria 6, then the V6_UV preset will do nothing and may even give you an error that the Victoria 6.dsf can't be found.
    I hope you all find these useful, I know I use them a lot. The presets will apply the selected UV set to either Genesis 2 Male or Genesis 2 Female, regardless of the intended gender of the UV set. So you can put S6 textures on M6 or Jayden, and vice versa.
    Please note that the textures for Creature Creator skins for Genesis 2 Female use the Basic Female UVs, so you would want to use the BF_UV preset on Gen2Male to use the Creature Creator textures.
    Here is a link to ShareCG where the freebie is housed, but you can also find it following the Freebies link in my signature:
    By
    Slosh Slosh December 2013 in Freebies
  • Luck with FaceShop 8?
    This is an update to my earlier problem with Faceshop. I spoke with Lazlo@abalonellc today and he walked me thru the entire process.
    He was very helpful.
    Although I now have a working version of Faceshop I will probably need to get Michael 4 to avoid modifying
    the facial points manually.
    It works best with either Michael 4 or 5.
    Lazlo did provide a workaround by selecting 'Basic Child' as the avatar but I will probably need to read the manual
    and see how to fine tune the settings.
    Again a BIG thank Lazlo!
    By
    wcthrill wcthrill December 2013 in Daz Studio Discussion
  • Novica & Serene Night’s Renders, Tips, Tutorials & Product Reviews PART 2
    One of these days I will render Victoria 4 and Michael 4 together.
    I was looking for a science fiction corridor with big windows. GIS Project looks nice. I did not know that it comes with a backdrop. Thanks for sharing the information.
    SereneNight said:
    GIS Project Nebula Image http://www.daz3d.com/gis-project
    If you have GIS project, make sure to nab the free nebula image that is included in your runtime. It is a great backdrop. And looks well here.
    By
    starionwolf starionwolf December 2013 in Art Studio
  • 3D Fig leaf Service?
    After putting a month into recreating Botticelli's masterpiece 'Birth of Venus' in Carrara with Victoria 4 and Michael 4, I discover I cannot submit it to my Daz art gallery due to nudity. I understand that much modern art is distasteful, and some arbitrary standard needs to be drawn to prevent the hated 'slippery slope' of moral decay. On the other hand, the net is rife with depictions of the human form which are contrary to Michelangelo's proposition that God created the human form, and so if drawn with Godly love, there is no shame in it.
    As you could well know, later on, far inferior painters appeared who objected to the Sistine chapel in the Vatican, and so covered up the parts they felt offensive with fig leafs. After that, many people found the fig-leaf painters more offensive than the nudity, exploiting naive morality in order to desecrate another's art and moreover draw a stipend for the service
    I myself do not consider myself a good enough artist to place fig leafs over a 3D rendition of Botticelli's Venus as yet. But maybe that means it is something I should do if no one else dares to. In the interim I posted my art on my own webserver at:
    LINK REMOVED
    in case any are interested to see the images for artistic or other reasons.
    Are there any artists in the 3D community offering fig-leaf services as yet? I would only want to do so for 3D reproductions of classical masterpieces, and maybe that is a good calling, if no one else is willing. For surely there could not be a more noble cause than reproducing the Sistine Chapel and Botticelli in 3D?
    I'll be curious to learn your own opinions of fig-leaf toters in the 21st century :)
    By
    Yofiel Yofiel December 2013 in Art Studio
  • Using Mimic in Carrara Pro
    Nope. DAZ is very new to me. I have much to learn. I will try these things. Thanks.
    Next Day
    wendy♥catz,
    I ran the batch file DzCreateExPFiles-M4. It created some morphs in the Michael 4 dir beneath it. The Michael 4 cr2 was not modified by running this file. Then I read,
    'Power Loader': Only ExP morph products will have power loader installers. These are only intended for use in Studio.
    Since I'm trying to go straight from Poser to Carrara, without going via DS, I'm not clear on how ExP impacts me. I'm not even sure what it is. What am I missing?
    Dartanbeck,
    A clean copy of the M4 cr2 worked fine. Now I have some work to do.
    If I recreated this character in DS, using the new Genesis figure, where would I find a dmc file for it?
    Thanks.
    By
    laststand laststand December 2013 in Carrara Discussion
  • Morphing Daz Sea Dragon
    https://www.youtube.com/watch?v=XWYZj4Ll1iA
    https://www.youtube.com/watch?v=d22pyRfNy58
    helped me using faceshop 6 EZ on M4, was able to create poses INJ my head.pz2 and REM myhead.pz2
    used with 05-my head_Chnnls.pz2 05-my head_Grps.pz2 files I put iin My Library\Runtime\Libraries\!DAZ\Michael 4\head
    I saved it to another folder first
    so you can share your morph
    By
    WendyLuvsCatz WendyLuvsCatz December 2013 in Daz Studio Discussion
  • Missing files error when loading base m4 scene
    I made a basic scene with base M4 loaded and nothing else, saved that scene, and every time I try to load that scene Daz3D hangs while it's importing materials then gives a missing files error with a long list of .pz2 files in the /Runtime/Libraries/!DAZ/Michael 4/Deltas folder. I checked for a couple of the files on the list and couldn't find them, what should I do?
    By
    JBlackwell JBlackwell December 2013 in Daz Studio Discussion
  • WELCOME TO THE 5TH ANNUAL WINTER WONDERLAND
    Dollygirl said:
    My entry for the main contest
    The Prince and the Pea
    Seriously, you don't think I am a Prince?
    You see Hans had it all wrong. I told him it was me but he didn't listen very well. Truly though, I was the one tested and not my princess. Oh and it wasn't a bed but a pile of pillows.
    The Freebies:
    Cat: * Millennium Cat LE by DAZ 3D.
    Cat: Texture * Three-Colored Cat for DazMillCat by ArMa Vision.
    Décor: Window stiles * MathMagic Windows by MatheMagic.
    Décor: Window Wall Floor * Window Prop by Olympus.
    Environement: Snowman * Flinks Snowman by Flink.
    Environment: Castle * Little castle by Maria.
    Environment: Lighting InaneGlory's Simple Soft Lighting by InaneGlory.
    Environment: Rain * Modualz Atmospherics - Rain Vol 1 by Traveler.
    Environment: Sky * Sky dome by glaseye.
    Environment: Snowman Hat * Morphing St Pat Hat by Deerpath.
    Environment: Texture on skydome * SkyDome Expansion 4 by glaseye.
    Environment: Trees * Winter Pine by Traveler Judith.
    Prince: Character and Texture * !Tyrese! For m4 by Sheldon24.
    Prince: Crown * Piggy Crowns by Jordi R. Cardona.
    Prince: Glasses * Prae's Pince-Nez by Prae.
    Prince: Hair * SOTO's Vincent for The Freak 4 by SOTO.
    Prince: Pants * Japanese School Uniform & Inner Shoes by Aziqo 3574.
    Shader: Blanket * J-Tex Tartan 2 for Fabricator by jansilla.
    Shader: Crown * Ultimate Shader Pack for DAZ Studio by Georgehaze.
    Shader: Orrey table top * Super Shine Shader - TopCoat for DAZ|Studio 1.7 by Marianne Gilliand.
    Shader: Pea * Shader Pack 1 for Daz|Studio 3 by Groovemaster.
    Shader: Snow * WinterLand Fabrics - 23 Ice and Snow Shaders by Calida.
    Shader: Window * Glass, Ice and Drink Shader Preset by Questor.
    Shaders: Pillow Pile * YuleTide (Victorian Christmas tiles) by tyllo.
    The No Counts
    MIA for various reasons, Christmas gifts, prizes, owner no longer offers the product or you just can't determine where in the picture it is
    Prince: Shirt Texture AngelFlutterJTex by Jezz. Christmas gift 2012
    Prince: Shirt Angel Flutter Shirt & Silk Hat for M4 by Aziqo 3574. Christmas gift 2012
    Environment: Snow on Window Sill 3dk Abstract Sculpture by Westormi. Freebie for DAZ Contest in 2009
    Environment: Ground Vikike's Ground 02 by vikike176. Rendo Christmas Gift
    Environment: Ground Base Light by Krissy. Freebie Contest Prize
    Décor: Plant Terracotta pot with soil and small tree by dorkati. Shocktober 4
    Décor: Orrey and Table Orrey C by SAMS3D. Rendo Christmas Gift
    Prince: Base * Michael 4 Base by DAZ 3D.
    Prince: Base * Michael 4 Morphs++ by DAZ 3D.
    The following are from two sites I am not going to link to here in the thread. If you wish these links you can contact me through PM.
    Décor: Pillow Pile Sofa armchair coffeetable 3D Collection by 3DBar.
    Décor: Curtains Curtain N231211 by Alexey Pavlov.
    Décor: Curtain Curtain N041010 by Helen Bergson.
    Décor: Blanket on Bed Veil N150413 by Annalisa.
    Décor: Bed Bed by Tom Petty.
    The Paid Fors:
    Environment: Lighting * Advanced Ambient Light by Age of Armour.
    * means registration is required. Curtains were shaded with one of my shaders. Poses for cat and Prince are what you get in the base packages. Pea was made with a primative sphere.
    Another great one from you Dollygirl. your links all checked out except when I went to the millennium cat it had a $6.95 price. You still have enough freebies to cover the min. requirement but you may want to change the link if it's not free. other than that
    ENTRY ACCEPTED
    By
    jeeperz jeeperz December 2013 in Freebies
  • Superheroes Rebooted - Ready to Rrrrrender?
    Geminii23 said:
    RawArt said:
    BlumBlumShub said:
    Hi guys,
    I'm looking for a really good (and free) Batman outfit, preferably from the modern era of movies. Got a friend that's a huge Batman fan and I want to make him a Christmas card featuring the said hero.
    I have the really cool cowl on ShareCG but the outfits on there look a bit rubbish.
    Any ideas? Thanks in advance,
    Barry.
    I made this second skin for m4...there is a link to the cowl in the thread.
    http://rawart3d.deviantart.com/art/Arkham-Bat-Suit-282692374
    Rawn
    Wow! That is pretty fantastic! Do you have any plans on making something like this work with Genesis or G2M? I noticed that Alfaseed is starting to make some stuff for G2 so are we to assume that G2 is easier to build for than Genesis was?
    It should work on Genesis if you switch the UVset to M4, or on G2M if you have http://www.daz3d.com/michael-4-for-genesis-2-male
    By
    fixmypcmike fixmypcmike December 2013 in The Commons
  • Too dumb for this outfit
    First of all, you are putting this onto M4, not Genesis. There are two vesions of this set, one for M4 (Generation 4) and one for Genesis.
    The one you screenshot is for Genesis and works perfectly on Genesis but it looks like you are trying to put it on an M4 (Generation 4 character Michael 4), it just wont work.
    Use this set on Genesis or use the set for M4 on M4. The M4 mentioned here is for those who used the old one for M4 and now need to have a character looking "the same" but based on Genesis.
    By
    Totte Totte December 2013 in New Users
    It means the Michael 4 shape for Genesis, not the Michael 4 figure.
    By
    Richard Haseltine Richard Haseltine December 2013 in New Users
    The Freebies:
    The No Counts
    The Paid Fors:
    By
    DollyGirl DollyGirl December 2013 in Freebies
  • how you think about this in the gallery...already deleted
    Darkothe said:
    Good thought. Funny that just a bit of cropping on the bottom, and the image in question wouldn't raise an eyebrow.
    oh, that reminds me, I should render Michael 4/Genesis male without a shirt and upload it to the Daz Galleries. lol :) I will still need to dress him in pants though.
    By
    starionwolf starionwolf December 2013 in The Commons
  • Genesis inside untiy for FREE
    Genesis used inside unity for free.
    Link: https://dl.dropboxusercontent.com/u/150707256/sprite character/webplayer.html
    Please note you will need to copy the entire link above to gain access and play the scene.
    W, A, S or D to move, you may also use the arrow keys.
    Please note you can move in 8 directions.
    Roughly guessing the idea came to me about four or five years ago long before Genesis, initial testing was using Michael 4, using the free animation blocks that come with Daz.
    The main issue was using these animation blocks but with the Genesis figure, I was aware of the foot offset I wanted a free alternative rather than using the full version of animate 2.
    Within the development process a new Daz studio camera and light setup is being used, a core concept in the use of Genesis or the figure of your choice if you have poser content, but most important no license requirement as you are only ever using renders.
    The Daz studio camera and light setup has undergone many upgrades since the first draft, commented by, none other than Waldemar Belwon, Dreamlight.
    “I think this is brilliant! Very smooth and you've done a great job with all the camera angles as well.
    Keep up the great work, this is really good!
    Waldemar Belwon, Dreamlight”.
    The new system has 2.5d and 2d camera choices.
    Unity 3d is my current focus of attention but if your gaming software can use .png images then you can use this same setup.
    My goal was and is to provide the user with all of the information within the package still under development.
    Comments welcome
    By
    smithhondas_5f5e5bbc1d smithhondas_5f5e5bbc1d December 2013 in The Commons
    http://www.daz3d.com/forums/discussion/33195/#492723
    I am adding this link to the references section- Slosh did an excellent tutorial on how to use Michael 4 Skins Auto Converter For Genesis 2 Males. I still haven't tried it yet.
    And yes, I noticed my all time favorite hair Pyrit Hair is now for Genesis 2. :) (It was the very first hair I ever used, on Kaetl with her two baby dragon friends.)
    EDIT: Here is what got added to the References for November. Remember, you can always find this section from a link in the VERY FIRST POST.
    New In November
    File Types: http://www.daz3d.com/forums/discussion/15792/#330279
    File Types: https://helpdaz.zendesk.com/entries/22890557-Understanding-Content-File-Types
    Ron's Brushes- Tips http://www.daz3d.com/forums/discussion/32428/
    Clothing: Fitting M4 To Genesis 2 Male http://www.daz3d.com/forums/discussion/32596/
    DIM: Multi-Use/ More Than One Computer: http://www.daz3d.com/forums/discussion/32843/
    Frequently Asked Questions http://www.daz3d.com/forums/discussion/17/
    Photoshop Bridge-DOES NOT WORK WITH CLOUD!
    http://www.daz3d.com/forums/discussion/20485/
    http://www.daz3d.com/forums/discussion/19651/
    http://www.daz3d.com/forums/discussion/25174/
    Shader: How To Restore: http://www.daz3d.com/forums/discussion/33136/#491681
    UberArea Lighting: by Tjohn http://www.daz3d.com/forums/discussion/33160/P30/#492883
    By
    Novica Novica December 2013 in Art Studio
  • Shaders and Generation 4 Statues help
    Hi All,
    I just purchased the Generation 4 Statues Product to convert my Victoria 4 and Michael 4 figures to statues. It says in the description of the product that it can make a statue out of any Victoria 4 or Michael 4 figure including hair and clothes. I know that these are shaders and I am able to get my Victoria 4 character to look like a statue but no the clothes or hair. When I try it on a Michael 4 figure or any clothes, hair or (genitals for Michael 4) nothing happens. I even applied the shaders and did a quick render thinking that it might show up their but no luck. I am new to doing the shader and have tried other types and I have no luck with them either. Is there some setting that I need to change to get these to work? Any suggestions will be helpful.
    Thanks
    Rich
    By
    fishmanz fishmanz December 2013 in Technical Help (nuts n bolts)
  • Genesis Generation X (Upgrade) Installation Problems
    I bought the standard version Genesis Generation X and V4 and M4 Shapes for Genesis.
    http://www.daz3d.com/genesis-generation-x
    I think I have the same problem than quietrob.
    I drag and drop Michael 4.cr2 in GenX pane, the transfer starts but nothing appears in Genx pane. And transfer box says "figure not supported".
    And I don't register the plugin because I don't have the "Validate GenX option". But it seem working : it appears in green in the Plugins list.
    But I never used it. May be I don't understand something about.
    That is the message on the transfer box :
    GenX - Loading figure: Michael 4
    Loading figure file ...
    Resolving script calls ...
    Figure not supported.
    So nothing appears in the GenX pane.
    By
    donews donews December 2013 in Technical Help (nuts n bolts)
  • Michael textures
    OK, so maybe I'm showing my newbie side by asking this but what is the real difference between Michael 4 - 5 and 6? Is it just the texture resolution?
    So if I take a high resolution texture from M6 and apply it to M3 will it essentially make the render as good as M6?
    By
    sarifos_8d8c91b39d sarifos_8d8c91b39d December 2013 in The Commons
  • M4 and V4 Clothes on G2M and G2F
    You don't need to save as DUF. Just bring Genesis 1 into the scene, if you have the Michael 4 clone for Genesis 1 just autofit your M4 clothes to Genesis 1 first, then the next step will be to fit the clothes a second time now to Genesis 2 Michael 6 in the same scene. The clothes will just jump from Genesis 1 to Genesis 2 and autofit when you select From Genesis to Michael 6 in the "Fit to" dialogue. Same thing with V4 to V6.
    This is a "poor man's way" lol, of course using “Michael 4 for Genesis 2 Male” or the V4 to V6 product would be the best way to do it.
    By
    SimonWM SimonWM December 2013 in The Commons
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
