• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • *Released* dForce Faustian Fringe Hair
    Looks like the update is available, and the missing morph is now there.
    I'll be posting my render soon.
    By
    DoctorJellybean DoctorJellybean December 2024 in Daz PA Commercial Products
  • Transfering utility but not JCMs
    godless1893 said:
    crosswind said:
    godless1893 said:
    crosswind said:
    godless1893 said:
    crosswind said:
    You should rig the amors to the base figure with default A-Pose... then Transfer Utility won't create pJCMs on the armors when rigging the armors to the figure.
    Then you need to fix necessary FBM and pJCMs with different poses.
    So the JCMs still exist in different poses and I can't  stop them from appearing or delete at once?
    If you make armors on Genesis 8/9, you can simply turn off or zero Base Joint Correctives on G8 / G9.
     May I ask how to turn off them all at once?
    That's a control property... if you turn it off, no pJCM / cbs will be triggered on the figure and generated on the wearables. Select G8 / G9, filter by Base Joint in Parameters Pane.
    Thanks I see it, but this will turn off JCMs on all wearables and the figure itself...If I want to turn off them on one single armor and keep others on, there is no one-cilck option,right?
    Right.... there's no other options except for using rigidity, by clearing generated morphs on a target wearable. You either fix pJCMs or set a rigidity... each option has its pros & cons.
    By
    crosswind crosswind December 2024 in Technical Help (nuts n bolts)
  • diffeo simulation tool, softbody + cloth will occur distortion
    I easy import a G9 character, add some facs morph and jCMs. if I only add softbody or make cloth simulation respectively, softbody effect or cloth simulation works well. If I both add two simulations, cloth simulation seem nice but the figure's chest will appear distorted.  use Diffeo 4.2.1 and blender 4.0
    By
    liuboren66 liuboren66 December 2024 in Blender Discussion
  • Clothing for UE5.4 from DAZ
    OK so when building the Genesis character in Daz Studio the clothing should be attached as part of the Genesis base which in turn inherents the morph targets from the character base. To mantaine the shape change the clothing needs to be exported as part of the main shape so when exporting the clothing as stand alone will not fit right and in some cases deform in the manner you discribed. Now if you want to export and maintain the current shaping you need to set all of the parts not part of the clothing to invisable and set the exporter to export visable objects, in the FBX dialogue, to send only what is visable and the morph targes will be baked into the mesh and can then  be used as a component.
    By
    frankiev888_28b3c399af frankiev888_28b3c399af December 2024 in Unreal Discussion
    By
    godless1893 godless1893 December 2024 in Technical Help (nuts n bolts)
    By
    By
    By
    By
  • HeadShop Questions
    Brief update: So far, sadly, I'm not really impressed. But I've dedicated my spare time this week to playing with it and watching the tutorials.
    Initial thoughts are that while I like some of the features- the 'autodots,' and an easy ability to mirror sides of the head without photoshop- the resulting mesh still relies too heavily on skin tone shadows substituting for real facial contours. It's something that the base Face Transfer also does. Swap the scanned UV maps out in favor of a vendor's maps and it can radically alter the appearance of the eyes, cheeks, and mouth, usually spoiling the model.
    By
    Blando Calrissian Blando Calrissian December 2024 in The Commons
    By
    I wanted to rig some models I made in Daz, and most of them are armors. I need them to keep the original shape most of the time(apparently not the rigid follow node type), but transfering utilities will make many JCMs, which causes unwanted morphs. I can delete them, but hidden JCMs never show at one time, they will only show after I transform the corresponding bones so I can't delete them all at once. I want to know if there is a way can transfer utility except JCMs or delete them all at once.
    By
  • Save morph as a support asset (depricated) - so how to?
    I want to save a morph, but the usual way "File->Save as->Support Asset->Morph" is gone (due to a new version?). It's grayed out and "depricated". My morph? The export function? My model?
    How do I save my morph?
    By
    arnon arnon December 2024 in The Commons
  • Copying Character File(s) from one folder to another, keeping the metadata?
    As the title indicates, is there a method to moving/saving a character from one folder to another while keeping the character file's metadata?
    I can copy/move a character (my own morphs) from one folder - Characters/MyStuff - to another folder - Characters/MyStuff/Coolstuff.  In doing so, however, it "loses" the Actor tag, and any other tags, and metadata.
    Is there an easier way to transfer/move that character from its original folder to the new one without going through loading the character and resaving it to the new folder?
    Thanks for the hints.
    Felix/FFDS
    By
    FelixFFDS FelixFFDS December 2024 in Daz Studio Discussion
  • Face transfer 2 not showing genesis 9 option
    rhbogaard_9fc5200211 said:
    Couldn't find an update for the plugin, removed the plugin manual but when i restarted daz studio nothing. In the DAZ Install Manager nothing, so I reinstalled daz studio completly and on startup indead found face transfer 2.1.0 and now i have the genesis 9 option in the face transfer window. I whas on daz studio 4.23 and still after all this, so don't understand what i updated but its working now.
    I'm not sure what caused your FT2 to not be updated, but it sounds like it's working properly now.
    That's good!
    By
    CES3D CES3D December 2024 in Technical Help (nuts n bolts)
    By
    rhbogaard_9fc5200211 rhbogaard_9fc5200211 December 2024 in Technical Help (nuts n bolts)
    here is a screenshot:https://ibb.co/Tt5VRWZ
    I don't see anything strange
    In my environment, Face Transfer 2's version is displayed as 2.1.0.0.
    It seems like your FT2 version is old.
    Could you try checking for FT2 updates or reinstalling it?
    By
  • G9F/G8F Size Difference
    Elor said:
    DarkElf said:
    Richard Haseltine said:
    How huge? The default height has certainly been reduced for Genesis 9.
    Thanks Richard. Is there a specific ration difference?
    G8F is around 10cm taller than G9.
    It can vary from character to character (most PAs will simply use G9 default height, letting users change the height of a character to their taste with the Proportion Height morph) and can vary between core figures in the same line:
    • Olympia 9 is taller than G9, almost as tall as G8F while Olympia 8 is smaller than G8F and Olympia 9.
    • Victoria 9 is the smallest Victoria, smaller than G9 and a couple of centimeters smaller than Victoria 8.1.
    • Michael 9 is taller than G9, he is the same height than Michael 8.1 and both are shorter than Michael 8.
    A couple of things to keep in mind:
    • G9 core figures who are smaller or taller than G9 usually have a specific proportion morph to get to the advertised height, a morph active if you're loading the character preset, but you'll have to activate it yourself if you start from Genesis 9 Base, because dialing, as an example, Victoria 9 character morph will not activate her proportion morph, only her head and body morphs.
    • Don't trust the height advertised on Daz Store, at least not without checking with people who bought the core figure your interested with: Daz had publisher wrong advertised heights a couple of time already (no idea if other measurements can also be wrong, height is the simplest to check by comparing two characters and discovering than the one supposedly 10 cm shorter than the other is actually a couple of centimeters taller surprise).
    Thanks so much for the explanation about the character morphs and how they work in comparison to starting with the G9 Base. I'm going to pay more attention to this so I can at least start with what the PA intended.
    By
    3DSaga 3DSaga December 2024 in The Commons
    This is so true and happens way too often.  Sometimes they're quite accurate while at times we have the Ashley 9 Petite form situation.  It would be nice if the Daz Original products listed accurate heights as they're typically perceived as higher quality and should be presented as such.
    With that said, it's really a superficial thing when you have height sliders, alternate forms, specific body part morphs, to make any model the size you really want.
    By
    NetherFalcon NetherFalcon December 2024 in The Commons
  • Morph Loader pro is gone in DAZ Studio
    In version 4.23.0.1 I have no access to Morph Loadewr proi anymore, only Tranfrer Utility is vissible.
    I would be greatful for any help.
    Regards
    By
    dyret dyret December 2024 in The Commons
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
