New save formats - How and when to use them?
There's no big change in terms of saving support assets... only saving Morph Assets was changed to Modifier Assets because morphs or pose controls etc. are all Modifiers. So if you want to save a morph assets, go for save as Modifier Assets. Then, as usual, Save as Modified Assets is still used for the cases when you make a modification to an existing Property, then just want to save the changes. (DSF files will be overwritten.)
I've never used dynamic cloth which is pretty old but I don't think there's any change to Save as Dynamic Cloth Assets....
As for how to save a projeciton template, check this post: https://www.daz3d.com/forums/discussion/comment/9257551/#Comment_9257551
New save formats - How and when to use them?So I've been absent for a while and recently updated Daz Studio to the latest version.
I've noticed that there have been some changes to the save menu with some items added and some deprecated.
I'm wondering if best practice is now to save morphs by saving modified assets as morph assets is now deprecated.
Also I notice that there is a save dynamic cloth asset and would like to know if this is now the preferred method for saving dynamic clothing.
I'm also trying to work out how to save projection templates?
If anyone can help with answers I would appreciate it.
There's Always Another Sale Thread -- Discussions Only Pt 5Since tomorrow is the last day (maybe) of the holiday sale, I splurged a little bit more on this one:
https://www.daz3d.com/face-transfer-2
https://www.daz3d.com/z-luxe-office-chair-prop-and-poses-for-genesis-9-and-8-female I have a (2010's) Nikita esque render in mind for this one.
https://www.daz3d.com/mmx-genesis-9-clones-for-all
https://www.daz3d.com/dforce-fv-enigma-veil-hair-for-genesis-9
https://www.daz3d.com/hs-everyday-high-updo-hair-for-genesis-9
https://www.daz3d.com/alo-kasia-hair-for-genesis-9-8-and-81-females
https://www.daz3d.com/sy-web-restraints-genesis-9 Shelob's Lair render in my future?
https://www.daz3d.com/dforce-cs-rosemary-hair-for-genesis-9
https://www.daz3d.com/cecelia-updo-for-genesis-9
https://www.daz3d.com/dforce-fv-classy-pixie-hair-for-genesis-9
https://www.daz3d.com/fe-side-bob-hair-for-genesis-9
And from my Advent Calendar:
https://www.daz3d.com/natty-hair-for-genesis-8-females
Yesterday:
https://www.daz3d.com/z-everyday-smartphone-pose-mega-set-for-genesis-9-and-genesis-8-female
Advent Calendar: https://www.daz3d.com/real-faces-and-bodies-for-victoria-81
The Day prior:
https://www.daz3d.com/breena-boots-for-genesis-9-and-8-female
Advent Calendar (2.99): https://www.daz3d.com/dforce-sport-suit-outfit-for-genesis-8-and-81-female
The 27th:
https://www.daz3d.com/real-faces-and-bodies-for-rosa-maria-81
Advent Calendar: https://www.daz3d.com/dforce-void-suit-x-outfit-iray-texture-set
Any Way to Use G8Female Expressions on G8Male Characters?Technically, yes ~~
1) If an Expression dial is a Pose Control property (Modifier/Pose) that calls Base Pose Head properties of G8F or FACS properties of G8.1F, you can locate its DSF file in data folder, copy it from data\DAZ 3D\Genesis 8\Female\Morphs\... (or data\DAZ 3D\Genesis 8\Female 8_1\Morphs\...) to data\DAZ 3D\Genesis 8\Male\Morphs\... (or data\DAZ 3D\Genesis 8\Male 8_1\Morphs\...). Then open the DSF file (uncompress it if it's compressed...) with Notepad++, replace Female with Male. Load G8M or G8.1M, that Expression will work.
2) If an Expression dial is a pure morph (Modifier/Shape), you have to convert the expression morph from G8F to G8M with Transfer Utility by using Morph Targets option + G8M Clone on G8F (or vice versa...). Save the transferred expression morph on G8M as a Modifer asset. That'll also work. ( Edit: Check this post of how-to, same approach: https://www.daz3d.com/forums/discussion/comment/9364356/#Comment_9364356)
Any Way to Use G8Female Expressions on G8Male Characters?In theory, but how much of a hassle it is depends on the expression.
If the controller is just a preset of sliders that both figures have in common (and where the referenced sliders are sufficiently similar), then you can use an ERC bake in Parameter edit mode to turn them into a copyable or saveable pose. (Alternatively, you can edit the data files' JSON directly so that they refer to G8M as their figure rather than G8F).
If it requires actual morph data though, you would have to transfer those as well. (Obviously with the limitation of not having HD).
Would People Be Interested in Realistic G9 Bicep Morphs?Elor said:
If you have SimonWM's Muscularity Morphs for Genesis 9, there is a free addon taking care of dialing the various morphs depending on how a character is bent:
Quick demo using the above mentioned product. Hope it helps, I use it on every G9 figure, Sorry for the late response, been inactive on the forums awhile myself. TD
Fantasy Attic's 2025 Christmas Community Gift GatheringThank you for all the gifts
I don't know if it's the right place, but while I was trying some of them, when I tried to load Genesis 9 after placing the files for Renée in an active library, I was shown a missing file error because Daz was looking for
'/data/Angells Graphics/G9 June/G9 June/Genesis9.dsf'
Which is not where Genesis 9 is supposed to be.
To fix the problem, I had to uncompress 'Renee G9.dsf', and replace, at line 18:
"parent" : "/data/Angells%20Graphics/G9%20June/G9%20June/Genesis9.dsf#Genesis9-1",
by
"parent" : "/data/Daz%203D/Genesis%209/Base/Genesis9.dsf#Genesis9-1",
The id is also likely wrong so I replaced at line 4
"id" : "/data/Angells%20Graphics/G9%20June/G9%20June/Morphs/AngellsGraphics/Renee%20G9/Renee%20G9.dsf",
by
"id" : "/data/Daz%203D/Genesis%209/Base/Morphs/AngellsGraphics/Renee%20G9/Renee%20G9.dsf",
Once the changes were saved, Genesis 9 loaded without any missing file error and it was possible to apply Renée morph.
Sagan: A DAZ Studio to Blender Alembic ExporterSo I've been working with sagan for couple of days now and there are a few things that bother me. The settings still dont save per scene file, they seem to be global. Im not sure if you plan to change this so I'm mentioning it. I think it is really important to have settings save per scene file, like for example frame range so that when you open the older project you know what you are working with and not have to constantly fiddle with frame ranges especially if you work with multiple files. Another thing is, the order of material and the uv naming does not follow diffeomorphic template. I've tried fiddling with diffeomorphic material order settings but no success, this fix used to work in older versions of sagan. My suggestion is, keep uv naming same as diffeomorphic and keep material order/index the same as diffeomorphic default import because this simplifies the material transfer by an order of magnitude. Currently as it is you have to fiddle with both the uv's and material orders just to get a single piece of clothing working and then you have to do it for every single unique piece. I saw sagan exports some scripts also, I am not sure if and how they are supposed to be used.
Fitting hair with hatsRon Knights said:
Taoz, you have my sympathy.
My computer is almost in pieces and it's only 6 years old.
I replaced the NVME (boot) disc, and ripped apart most of the insides in the process.
Yes it's easy to destroy hardware, I've learned that the hard way. Many things that you can do wrong.
Anyway, I have tested the hat/hair tool now. It has two methods for fitting the hair, a simple one and a more advanced one, I've only tried the simple one so far. It's not easy to see what you're doing here when positioning the cube/sphere/cylinder that masks the part of the hair you want to hide, as you can't move the figure around. So I had to repeat and adjust four times and it takes several minutes each time to create/modify the hair morph. But here's the result. Looks pretty OK, but not perfect if you go into details, but then, it's probably not the easiest hair to fit to a hat.
I'll experiment with the other method later, here you work directly with the hair by selecting the vertices you want to hide, which is more complex but also gives more control over the details I guess.
Also, as far as I can see it only works with mesh hairs, not strand based hairs.
Celebrity Look-a-Likes for 3D figures Part 4druc said:
maikdecker said:
Gordig said:
druc said:
Has this been added Babydoll for Genesis 8 Female at Renderhub
It doesn't help your case that I can't even guess at who that's supposed to be.
Emily Browning was a girl called "Babydoll" in the 2011 movie "Sucker Punch" and wore an outfit kinda like the one shown. Good likeness, imho
The character morph, costume and hair are sold as a package deal, and sorry, I didn't name the character as Emily Browning from "Sucker Punch" The vendor is on sale at the moment, but as I own this, like Daz3d.com, I can't see the price of items I own.
"...but as I own this, like Daz3d.com, I can't see the price of items I own."
One can anonymously view the items that they own in a private browser window
Freebie Challenge December 2025 - "Christmas!" - Entries ThreadWaiting to see Santa Claus
From the window, a reindeer and a sleigh can be seen. Could this be a sign of Santa Claus's arrival? Maybe he'll be visible? Maybe no one can see him, because he's hiding behind a mysterious cloud that obscures his view. Perhaps the cat, with his sense of magic, can... but he can't reveal it!
Freebies
Simple Reading Room for DAZ by Shreddder
https://www.renderosity.com/freestuff/items/95862/simple-reading-room-for-daz
https://www.renderhub.com/shredder/simple-reading-room-for-dazPETIT BOIS by chacornac
https://www.renderosity.com/freestuff/items/87535/petit-boisSAPIN_NOEL by chacornac
https://www.renderosity.com/freestuff/items/75869/sapin-noelAMV_Fawn by Luna_s20
https://www.renderosity.com/freestuff/items/99317/amv-fawn
https://www.renderhub.com/luna-s20/amv-fawnBuck Antlers for AMV_Fawn - DS by Luna_s20
https://www.renderosity.com/freestuff/items/99334/buck-antlers-for-amv-fawn-ds
https://www.renderhub.com/luna-s20/buck-antlers-daz-studioEVERYPlant Christmas Tree for Daz by EVERYPlant
https://www.renderosity.com/freestuff/items/98106/everyplant-christmas-tree-for-dazNOEL_DECORS_GUIRLANDES by chacornac
https://www.renderosity.com/freestuff/items/75863/noel-decors-guirlandesCute Kay Toddler Morph for G9
https://www.renderhub.com/undeadcrabb/cute-kay-toddle-morph-for-g9Vergil DMC5 Hair For Genesis 8 Male
https://www.renderhub.com/intheflesh/vergil-dmc5-hair-for-genesis-8-maleTraining Suit for G9 by yomiuri
https://www.renderosity.com/freestuff/items/98613/training-suit-for-g9KT Child G9 by katyee
https://www.renderosity.com/freestuff/items/98181/kt-child-g9Hair 1 for Daz 3D Genesis 9
https://www.deviantart.com/amyaimei/art/Hair-1-for-Daz-3D-Genesis-9-935744713Halloweeny Part 1 by Leilana
https://www.renderosity.com/freestuff/items/83564/halloweeny-part-1Halloweeny Fabric by Leilana
https://www.renderosity.com/freestuff/items/83581/halloweeny-fabricBettina G9 mn V2.0 by mininessie
https://www.renderosity.com/freestuff/items/94068/bettina-g9-mn-v20Pajamas for G9 by yomiuri (shirt)
https://www.renderosity.com/freestuff/items/98594/pajamas-for-g9London Streetwear Outfit for Genesis 9 (pants)
https://www.renderhub.com/kuraikya/london-streetwearJamesF for Genesis 8 Male
https://www.renderhub.com/ohnomen/jamesf-for-genesis-8-male-1Classy Sweaters for Genesis 8 Couple by Dingo
https://www.renderosity.com/freestuff/items/87321/classy-sweaters-for-genesis-8-coupleDingo's Wild Curls for Genesis 8 Female by Dingo
https://www.renderosity.com/freestuff/items/86422/dingos-wild-curls-for-genesis-8-femaleCaptain Barbossa by Paspu (Santa's pants and boots)
https://www.renderosity.com/freestuff/items/91488/captain-barbossaMist Walker G8F by pjz99
https://www.renderosity.com/freestuff/items/98656/mist-walker-g8fNo count
dForce Santa Costume Mega Bundle for G8F by Yashiro amamiya (Santa's coat and hat) no longer available
gift by kalhh no longer available
LF Lil Comfy cute socks by LilFlame it was a DAZ freebie last year, now no longer available.Paid
HS Kelly Messy Curves Hair for Genesis 9, 8, and 8.1 Females
https://www.daz3d.com/hs-kelly-messy-curves-hair-for-genesis-9-8-and-81-femalesDaz House Cat with dForce Hair
https://www.daz3d.com/daz-house-cat-with-dforce-hair
Difficult to classifySleigh
It was free when I downloaded it (Renderosity), now it's paid on another site (3d Shards)
I don't know how to classify it (doesn't count or is it paid?)Let's appreciate/discuss today's new releases - more ongoinger threaddaveso said:
I think this character has some great skin textures, Ramalus HD for Genesis 9 | Daz 3D The only thing it appears as if there is no morph for normal ears, only elf style. Its too bad if that's the case.
I am not buying it for the same reason. It's rather odd since elves, as popular as they may seem, are a niche.
Let's appreciate/discuss today's new releases - more ongoinger threadI think this character has some great skin textures, Ramalus HD for Genesis 9 | Daz 3D The only thing it appears as if there is no morph for normal ears, only elf style. Its too bad if that's the case.
(Released) - dForce Bombshell Hair for Genesis 9 [Commercial]nakamuram002 said:
Is there a morph to move the front left hair behind the shoulder? Is there a morph to move the front right hair (if any) in front of the shoulder? In other words mirror the default view.
Hello there,
no, there is no way to 'mirror' the hairstyle.
ToyenSWTrium's Guide for fine tuning Push+dFormer mapsThis was requested by a client who wanted some guidance on how to quickly fix poke-throughs caused by dForce fabrics on layered meshes (without going down the rabbit-hole of using ghost colliders or building extended morph/bone-chain stacks).
You can download / view the full over here : SWTrium’s Quickstart Guide for fine tuning Push / dFormer Modifier Weight Nodes for Daz3D Studio.
But a Page by page breakdown will also be added in this thread.
Page01:
Page02:
Page03:
Page04:
Page05:
Daz Studio 2026 Beta - version 6.25.2026.4408! (Updated February 18, 2026)I had the a crash on the latest version of Daz ALPHA.
This crash was bad, no crash report, it gave an error and I needed to force a shut down. Steps on repeating it below.
This seems to happen because of one addon, with a specific morph that I honestly never use at all (see attached image).
This is how I repeated the crash...
- Load Daz (Latest Alpha)
- Load default, Genesis 8 female with nothing else.
- Go to Parameters Tab for the character
- Click Actor
- Click Legs and it crashes with an error (see attachment)
- I have to force a shutdown, so no crash report is generated.I managed to easily recreate this crash doing the above so I cleared the log file, and then carefully recreated it with a fresh, empty log, and then saved the log before I clicked LEGS which crashes it. I attached the log.txt. (Crash log.zip).
Creating an injection dsxI did try that. I ended up with mixed results tbh. I put the head morph on but when I tried to modify or add a body shape the entire figure changed, like it was linked to the head morph.
I am not sure why that is happening. If I try to change a shape on the body it changes the entire body shape. If I try to modify anything it changes the entire shape of the figure.
(Released) - dForce Bombshell Hair for Genesis 9 [Commercial]Is there a morph to move the front left hair behind the shoulder? Is there a morph to move the front right hair (if any) in front of the shoulder? In other words mirror the default view.
The best way to smooth out wrinkles?I don't have geometry sculptur so I have no experience with that.
I would take it into a modeller and create a morph from that.
In geometry sculptur have you tried change radius and see what difference it makes.
Maybe try to show an image of what you are trying to adjust, best in wire texture shaded
