• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • To the Blender users
    gregsgraphics_cafd0962a0 said:
    The downside of character "creation" in Daz is that everyone is starting with the same geometry, and while it's very convenient to shape a character using morphs and packaged assets, there's a limitation to how customized you can get.  For example, when you start creating characters from the ground up, you can decide how many polygons to use, and where it's best to put them.  You can decide how to rig the character with manipulators and helper objects in the rig itself that make animation much, much faster and easier than playing around with dials.  You get to paint textures that match the geometry from scratch, so there's no warping or stretching of the UV's which is very often a problem with morphed characters. Texture stretching becomes very much noticeable on models if the morphs are extreme.
    So in that regard, when it comes to custom character creation, Blender does offer the tools to do it the right way.  It's not as fast or easy as DS, but it's certainly more powerful and as long as you know what you're doing you will get exactly what you want or need, right down to the last pixel and polygon, with little to no wasted geometry or textures.
    ????? or you can export genesis, sculpt it however you want, and import it back as a morph. You aren't limited to dial spinning. you could also paint textures on a morphed shape, make new uvs, create a different rig if you feel like it - now some of these things you need an external program (tbf if we're talking texture painting odds are you're using an external program for blender too - blender's texture painting tools are less than great) but you need external programs to do stuff is very different than "can't be done" if you're completely excluding external programs then the real problem is that you can only render primitives morphed with dforms as ever mesh was imported from another program.
    You don't even have to start with the same geometry - you could import a completey custom figure rig them etc (there are several non genesis figures right in the store)
    edit: I would say access to the sort of equivalent of being able to make HD morphs for non-pas in blender (via multiresolution sculpting) is a tick in blender's favor on the character creation front
    you can definitely do custom uvs for genesis though - I've even made some
    By
    j cade j cade December 2020 in Blender Discussion
  • Changing the value of a morph on a g8 figure
    This seems to work, as a proof of conceept rather than a proper script:
    // make sure a figure is selected
    var oFig = Scene.getPrimarySelection();
    var oObject = undefined;
    // make sure we got a figure
    if ( oFig && oFig.inherits( "DzSkeleton" ) ) {
    	// get the object
    	oObject = oFig.getObject();
    // if we have a valid object
    if ( oObject ) {
    	// get the Forearm Size morph
    	var oMorph = oObject.findModifier( "PBMForearmsSize" );
    	// get its value channel, if it was found
    	if ( oMorph ) {
    		var oValChan = oMorph.getValueChannel();
    		// if successful, set it to 1
    		if ( oValChan ) {
    			oValChan.setValue( 1 );
    By
    Richard Haseltine Richard Haseltine December 2020 in Daz Script Developer Discussion
    If it's actual morph those are on the figure, not the bone. You get the object from the figure node http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/node_dz#a_1a5b6bf06e4ee1b03b841f22efb27b3e3b , then the modifier can be found on the object (by name, rather than label) http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/object_dz#a_1a259d193e74e4003ab512d904e214509c . Once you have the modifier you get its value channel as I recall (DzModifier dosc are curently offline) on which you can then use setValue( val ) or one of its variants (setting at a time, for example).
    By
  • Update to Genesis 8 Figure Teased - Daz Blog
    scott762_948aec318a said:
    hansmolleman33 said:
    I dont understand the need of Gen9. What is it going to bring ? More polygons?
    Read what marth_e wrote... more polygons is needed because the base mesh resolution is far too low to do anything with other than basic shape changes.  Yes, there's displacement maps but it's a huge PITA compared to using a bridge like Daz GoZ to Zbrush, sculpt changes, then bam GoZ back to Daz.  For example, there's lots of interest out there for Trek and Star Wars stuff, but since it's IP it can't be sold commercially.  Want to do some forehead ridges for a Klingon?  Not with the base mesh you're not.
    Keeping the polygons low makes sense with the computer hardware we had years ago, but look at the hardware available to regular consumers now.  The Unreal Engine 5 demo is amazing, AND running on a console.
    https://youtu.be/PBktSo0bXas
    The day where my stills look like 10 year old amateur stuff compared to a video game is when I throw in the towel.  Either with rendering completely, or take a hard look elsewhere.
    Are you sure you're taking into account all of the implications of a denser base mesh? There are reasons that HD add-ons exist (as opposed to just making a denser base mesh). DAZ doesn't take this approach simply to annoy people - give them a little credit.
    You have to consider the amount of data for each character "morph" for a figure. This isn't just the basic figure shape, but all of the JCMs, etc. as well. There are already major issues with load times for base figures if you have a lot of morphs, not to mention lag during posing, etc. There would be other un-intended consequences, too - like the time it takes the smoothing modifier to calculate or dForce simulations to run, the system resources required for everything, etc.
    - Greg
    That may be true if you don't have enough horsepower, but since we'll never be able to morph in HD that's our only alternative.
    With Nvidia 3000 series cards on the market, 2000 series should see a serious price drop when they become more widely available.  And I'm still working on a 1000 series... not enough horsepower shouldn't be an excuse for long, if now even.
    Also watch the video - decimation is all done inside the engine.  That's the beauty of it.  You work in your high detail versions, then there's no need for multiple versions of the same mesh and possibly textures optimizing for hardware or viewing distance.
    I have seen the video a long time ago, but the issues I'm talking about come way before anything is ever rendered. That's the part you may be missing. Not everything lends itself to parallel processing that can be accelerated by a GPU. As a matter of fact, many operations in DS don't even utilize multiple CPU cores.
    You could see for yourself by using the Transfer Utility to create a higher resolution G8 base. You'll quickly find out what working with such a figure is like firsthand.
    - Greg
    By
    algovincian algovincian December 2020 in The Commons
  • Shrinkwrapping a custom head to G8?
    gibrril_fa945a6cee said:
    So you can't convert a custom blender head to a G8 head morph in blender?
     Well "I" can't - but allegedly some can do so using Blender.
    Is this custom blender head an .obj you can send my way? I can see if Facegen will load it. IF it can, then I can have it make morphs with it for any of the Genesis people - so do let me know also which figure you want it for. {you could upload it to Google Drive for example and PM me the link}
    Hmm ... this might not be a solution for you. I found a wrinkled old man's head .obj and tried it. Facegen does its thing and the general head shape is made. It did not make all the lumps and bumps! n.b. the .obj was not ideal as the expression was not 'neutral'.
    {to make the character in D/S would then require either using existing wrinkle morphs and/or making additional morphs in the normal manner {not via shrinkwrap}}.
    By
    Catherine3678ab Catherine3678ab December 2020 in Daz Studio Discussion
    By
    gibrril_fa945a6cee gibrril_fa945a6cee December 2020 in Daz Studio Discussion
    - Greg
    By
    Gator Gator December 2020 in The Commons
    This seems insanely simple, but the sample scripting and other questions posted on here do not seem to have much direction to give me.
    I want to change the value of a handful properties so I can run a script and have the selected propertyies' value change to a value written in the script.
    I know how to select the figure and read the skeleton and locate bones, but I'm not quite sure how to find a property and then change its value. Is there something similar to "findbonebylabel" but for morphs?
    Thanks.
    By
    MeneerWolfman MeneerWolfman December 2020 in Daz Script Developer Discussion
  • Fitting G8F heels to G8M-based model?
    Richard Haseltine said:
    Using https://www.daz3d.com/weaver-outfit-for-genesis-8-females
    1. let AutoFit do its thing
    2. pose Genesis 8 Male to show the shoes' deformation
    3. select left foot
    4. activate the Node Weight Map Brush from the Tools menu
    5. In Tool Settings select general Weights - you should now see red to blue shading over much of the model.
    6. right-click in Viewport>Brush Mode>Geometry Selection
    7. drag to select some vertices at the bottom of the heel going all the way around, you can use ctrl to add to the selection and alt to subtract
    8. press ctrl + to keep growing the selection until it has the whole shaft but not going into any non-red areas - doing this avoids having to click-select in iunaccessible areas
    9. right-click>Weight Editing>Fill Selected
    10. enter a value of 100% and click Accept
    The heels should then straighten out. You can of course then do the same for the other foot.
    In this case there was already a Smoothing Modifier applied so I just changed the smoothing type to generic (because the base shape has some baked in wrinkles) and added a couple of iterations - if there's no Smoothing Modifier initially you can apply one through Edit>Figure>Geometry>Apply Smoothing Modifier. It's not perfect, but once it has textures it should be usable. The technique won't work for platforms, of course, and might fail for heels with thicker attachments or shoes with thicker soles but ti should give a starting point.
    I think there's something else going on here too. Every time I load the shoes I'm wanting to use, the character's full body morph gets overridden and defaults/reverts to G8M. Not sure how to explain that one.
    By
    RenderPretender RenderPretender December 2020 in Daz Studio Discussion
  • G2 clothes convert to G8
    Hi everyone. Happy Christmas
    I am sitting home and trying to convert clothes from G2 to G8. It is not working properly as whe I do that, doesnt matter if I use auto fit, transfer utility or rssy clothes converter I have problem with this: (plese see attached pic)
    Is there any way to fix this?
    It was originaly for poser but I managed to transfer to daz for G2. now I am trying to convert from G2 to G8
    By
    martin36 martin36 December 2020 in The Commons
    - Greg
    By
  • Gianni 8.1
    For what it's worth: you can kinda sorta get Gianni 6 shape to G8M, depending on what things you have, and how much work you're willing to go through. For the easiest method, you'd need to have Character Converter G2M to G8M to do it. There are other methods, but that way would be the simplest. (His texture would require a few other things, because he was done back in the days of unique character UVs, and because he's two generations ago, when the texture had a different layout.) You can also use XTransfer or Character Converter G3M to bring Gianni 7 over.
    I wound up using a different process -- partly by accident, actually -- but Gianni 6 came through mostly OK. He looks ... closely related to himself, let's say.
    I've got something else rendering, and then I have to take care of some other business, but I can do a render for you later tonight, if you want to see how they compare.
    (A Gianni 8 morph was reportedly seen in the morph list for some product -- I don't know which one -- but that was nearly three years ago now. I think that was almost certainly some kind of mistake; it's been just over two years since the last of the Genesis 3 characters -- Eva 8 -- had a new version for Genesis 8.)
    By
    vwrangler vwrangler December 2020 in Product Suggestions
    Thanks for the replies. I would like to use the shape of my custom head as a morph for the G8 head that I could then just dial in. How would I go about that in Blender? (Or DAZ) Thanks a lto, kind regards, Me
    By
  • DazToUnreal Not Visible in Unreal Editor Plugin List
    Hi. Please read this article and follow those steps : https://www.daz3d.com/forums/discussion/452926/daz-to-unreal-bridge-materials-plugin-fix-morph-exporting-smooth-meshes-fix#latest
    By
    moreffector_3290526 moreffector_3290526 December 2020 in Unreal Discussion
  • No Pose Controls on Import [SOLVED]
    Same here, I foolishly upgraded to 4.14 because I thought I could make use of the IK rig exporter to c4d in the video above! But now Ive got zero morph controls on all the exports, which is way harder to set up then an IK rig. :( woud like to roll back but I cant find my zip...
    By
    smyrkphace smyrkphace December 2020 in Cinema 4D Discussion
  • Are there any actually good face cloning tools out there? (E.g. not Facegen or Headshop)
    Paradigm said:
    What if I have neither?
    Commision TritiumCG to create a morph for you ?
    Seasons greetings from Steve.
    By
    stephenschoon stephenschoon December 2020 in The Commons
  • The Marvelous Designer Thread
    In Esha's content creation series of tutorials, available on the store, what she did was she made two versions of the garment - the 'final' draped version and also a 'tight' version.  The 'tight' version would be derived from the 'final' draped version of the garment, and would be created so that it more closely follows the contours of the figure compared to the more loose 'final' version.
    She used the 'tight' version when running the transfer utility.  This was a way to reduce errors in the transfer utility assigning rigging to wrong parts of the mesh.  Because the tight version hugged the contours of the body, the transfer utility did less guess work in assigning weights to the bones etc.
    The 'final' version was used as a morph (via morph loader pro or via Update Geometry).
    By
    lilweep lilweep December 2020 in Technical Help (nuts n bolts)
  • Improving load times
    vwrangler said:
    The tricky part is actually going to be keeping track of which scenes/characters use those morphs and which do not. Opening up such a scene without making sure that the unused morphs directory is checked will result in a lot of "this morph could not be found" messages when you open a file, and the characters will look wrong when you eventually clear the mesages. You'll then need to remember to close the file without saving, check the directories in the content directory manager, and reopen the file.
    I had hoped that DAZStudio would be able to find the absolute path name.  That tricky part kindof ruins the work round.  Requiring per-scene CMS setups, while better for many than the current behavior, doesn't really work.  The only obvious thing is to have a "used" installation directory and an "unused" version.  The "unused" is not normally used, so to speak, except when setting up a new scene with new characters.  In that case anything from "unused" that is actually used needs to be uninstalled from DIM and reinstalled in the "used" directory.
    Uugh.  This is horrible.  PLEASE DAZ FIX THIS, sorry to shout.  Oops, I lied.
    By
    jbowler jbowler December 2020 in Daz Studio Discussion
    DMax said:
    Been toying with MD for a week now and find that the most difficult bit is in exporting to DAZ and turning the clothing into a conforming, rigged item. I have yet to study UV, normal, diffusion, etc and definitely not yet into FBM nor JCM. To this jacket, I added sub-D, transfer utility, smoothing and saved as a support asset>figure/prop asset. I removed dForce as it failed to simulate and froze DS each time at 2%.
    (1) Why is there such horrible poke through despite the transfer utility?
    (2) Why is my beautiful collar so badly disfigured boohoo.. the left collar is upright and standing firm but the right collar is just a mess (after I apply the pose)
    (3) I sewed my sleeves down the middle of the shoulder but the pose moved the seams excessively and the stitches look plain unsightly as well (I didn't add any top stitches)
    (4) My zipper lost its teeth after I added Uber shader, I am guessing I did not have a proper normal map
    (5) Are JCM and Weight-mapping necessary for all clothing items?
    I'm very much just a beginner with this (I'll show off my first ever completed piece tomorrow when it's done rendering tonight overnight), and the others can probably help more than me, but I do at least know the answer to 4 and (maybe) 1...
    1) I've found that poke-through like this happens when the mesh is intersecting... for instance, that hand is touching his hip, and the clothes stuck in the middle don't know where to go.  There's some sort of "air gap" (not sure what else to call it) that seems to exist to keep the fabric on top of the figure, but when the geo gets super close like that it gets all confused.  I'd reccomend posing it out with a bit more space there and seeing if that helps.  I dunno, though, it's just a guess.  Hopefully as I get better I can be more useful in the future...
    4) For the zipper, I do know that this is a shader.  You should probably be able to find the tileable shader somewhere in the Marvelous Designer files, since it's a resource you can use in that program.  If you find that tileable shader you can just add it to diffuse.  You won't get any "definition" without a bump/normal map, but at least the teeth will be there.
    I don't know about the rest... I'm very new to this, but I'm excited that there's a dedicated thread for it.  I think MD is an amazing tool, and it just seems to get better with each update.  There's a learning curve, sure, but at least for me it seems worth the effort :)
    By
    duckbomb duckbomb December 2020 in Technical Help (nuts n bolts)
    You can definantly do this with blender and I'm working on a video tutorial on how I got it to work. I have not tried inside Daz but will to see if it is easier.
    But basically you need to export the g8 model as an obj with specific vertex perserving options on, shrinkwrap and align, then export back out perserving your vertexes and directions and bring that into daz using Morph Loader Pro (built in.) You may then need to realign your rigging.
    By
    charles charles December 2020 in Daz Studio Discussion
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
