G2 clothes convert to G8
martin36martin36 Posts: 187
edited December 2020 in The Commons
Hi everyone. Happy Christmas
I am sitting home and trying to convert clothes from G2 to G8. It is not working properly as whe I do that, doesnt matter if I use auto fit, transfer utility or rssy clothes converter I have problem with this: (plese see attached pic)
Is there any way to fix this?
It was originaly for poser but I managed to transfer to daz for G2. now I am trying to convert from G2 to G8
467 x 675 - 19K
Post edited by martin36 on
  • JOdelJOdel Posts: 6,322
    Have you tried converting directly from Poser to G8? Sometimes things react badly if they've been converted before.
  • martin36martin36 Posts: 187
    I Couldn't make this to work.Right now it work fine on G2 and even on g3 using autofit but on G8 there is problem as on the attached pic :(
  • Matt_CastleMatt_Castle Posts: 3,309
    If you can get it to work on G3, then take a version you've fitted to G3 and try overriding the scene identification to G8; often, this is all that is needed for a lot of G3 followers to work respectably on G8, as the main difference is the default pose, and fitting automatically follows the pose of the target.
    Post edited by Matt_Castle on
    I will try it. I should mention it is dynamic suit (taekwondo) and I am also trying to use it as conforming only. Is it matter?
  • AllenArtAllenArt Posts: 7,176
    It matters if it's rigged. Your best bet is changing the identification from G3 to G8 as suggested :).
    Post edited by AllenArt on
  • Poser dynamic? If it's not rigged, for whichever figure it "lands" on perfectly as an .obj, use the transfer utility option to rig it into clothing. Save it. Then load it fresh and start converting it to the other figures. To jump from G3 to G8 you may wish to try the autofit clones which have the T pose options. For any remaining stretched mesh in the armpit area - fixes involve making joint control morphs, and like not tonight ;-)
    Thanks guys for reply. I really appreciate. I messing with but still have problem with... see attached pics. This is after transfer utility on g2 female figure :(
    2560 x 2048 - 3M
    2560 x 2048 - 4M
    2560 x 2048 - 5M
  • felisfelis Posts: 6,649
    That is some rather hard poses to fit to without corrective morphs.
    If it fits in the default pose, you could try add dForce to it, and probably a weight map to handle areas where dForce is acting weird.
    yes
