• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Exporting a custom morph so it can be used. Help
    pjzanca said:
    this works for any object, it doesn't have to be made into a figure, it works for static props too. the important thing is the object has to be saved to library first, and then delete the original from the scene (not from library!)
    load it from the library
    make your morph with d-former (and by the way you can save d-former setups too!)
    on the d-form pane, check the boxes as shown and "spawn morph" - this does what the checked options say (read them) and assign a name
    File -> Save As -> Support Assets -> Morph Asset as explained earlier
    from then on you should see your morph as shown in 2nd pic!
    I did all that already. What I need is a way so every figure can use it without having to import the morphed one into the scene
    Here is the file. Maybe you can figure out what I'm doing wrong?
    Right image shows the figure with the morph I made. Left shows the default model without being able to access the morph
    By
    takanuinuva_40f6ab6ae5 takanuinuva_40f6ab6ae5 March 2021 in Technical Help (nuts n bolts)
    By
    Squishy Squishy March 2021 in Technical Help (nuts n bolts)
    pjzanca said:
    Start from scratch and tell me exactly the steps you're taking please. i.e. what is the object you're making a morph for, did you make it? it needs to be something you loaded from the content library, what object are you dealing with exactly?
    I don't really want to make the dforms again. But the morph is applied to the head to make the morphing python smile. I made the morph myself from scratch. And saved it as it's own file so I can import it into scenes. So it should be from my content library.
    I might just want to keep it that way instead of trying to hassle with this. As it is easy enough to import on it's own.
    By
    By
  • I want a pig and it's pink and LoRez
    blaz said:
    cathan01_wwg1wga said:
    Does the boar morph have tusks like the original loREZ Pig?
    Nope, not if you mean the kind that protrude out of the mouth. But you do get floating teeth. So much better if you ask me.cheeky
    There are also very visible seam lines.
    Does the PA visit the forums? How is he with fixing his products? I'm kind of fed up with with buying a product, only to notice a problem the minute I load it...
    Thanks for the info, I removed LoREZ Pig 2 Bundle from my cart.  I don't believe I have seen a response from Predatron in the customer side forums; but I could be wrong.
    By
    gitika1 gitika1 March 2021 in The Commons
    Eek. I think I'll pass. The original may be a bit dated, but at least it has the boar morphs with tusks and textures. Thank you, blaz.
    By
    cathan01_wwg1wga cathan01_wwg1wga March 2021 in The Commons
    looks to me like the seams are on the normal/bump map
    By
    AllenArt AllenArt March 2021 in The Commons
    felis said:
    If you have been using dFormer, I would export it as an obj, and then reimport and apply it as a morph to the original.
    How would I go about doing that exactly? I managed to export it as an obj. But can't find how to apply it.
    By
    pjzanca said:
    if that didn't answer your question please explain exactly what steps you're taking, what kind of object is it, how did you load it etc - this morph asset feature works well for me and I'm pretty sure it should work for anyone else \o/
    Alright so I have the morph saved to the morphing python and can access it in shaping.
    I had to first convert the figure to weight mapping. Then save it as a figure prop asset before I could save it as a morph asset
    Once all that was done. I go to save it as morph asset and check only the morph box. (But there are 2 of them. One for the figure and one for the head where the morph itself is located) I've tried saving both individually In the 2 folder options I have. Daz3D/Studio/MyLibrary and MyDaz3D Library. Neither have ended up working.
    Perhaps if I provide you a save file of the morph you can help me save it properly?
    By
  • G8 - Basic v Dev Load v Real World
    bradassociates said:
    Richard Haseltine said:
    Base has textures, DevLoad iss et up with no maps and has other features zeroed to make a basis for content creation. I'm not sure what real World is.
    By the way, that glossary is user-generated not official.
    Thanks Richard - that helps.   But I think I didn't write the original query correctly re: "Real World".   The basic G8F/M doesn't have "real world" options, but many of the character produdcts do.   For instance, the image below is a screen capture of Auroa HD.   The figure can be loaded via different options, one being "Real World".   In addition, there are "Real World" settings for various body features in the Parameters.    Do you or anyone else know what the meaning of "Real World" is and why one might load the "Real World" character instead of the other options?
    That category means that this character is supposed to be like a "realistic person" you'd see in real life -- like in person, on TV, in printed advertisements. As opposed to "Stylized" which would be a toon, like Sakura 8. This is handy for people who don't want to render toons. But that category is chosen by the artist who made the morph, and sometimes the choices are often questionable. (They don't look like "realistic people" but this is a subjective observation.)
    By
    MimicMolly MimicMolly March 2021 in New Users
    By
    blaz blaz March 2021 in The Commons
  • AIUTO...CHI CONOSCE L’ITALIANO? PARTE TREDICI
    Alessandro Mastronardi said:
    Anfy said:
    Eccomi di nuovo.
    Sto imparando, da arruffone quale sono, a usare il programma a un livello elementare. Sto però cercando di dominare - si fa per dire - l'illuminazione, la mia dannazione, anche perché ho preso delle belle luci che simulano quelle di uno studio fotografico, e funzionano bene per quel che le ho provate (di base sarei un fotografo).
    Due domande (se son fuori luogo nel presente topic mi scuso e fate finta che non le abbia poste):
    1) faccio girare Daz Studio su una vecchia macchina, addirittura con poverssore... processore AMD Phenom II X4 940 di una dozzina d'anni fa, gloriosi 8 Gb di RAM, a cui ho affiancato, da molto tempo, una NVIDIA 970 con 4 Gb di RAM (che mi salvano un poco).
    Ho però preso gli eccellenti Scimpanzé e Orango di AM (Alessandro Mastronardi) che mi han fatto capire che con il mio attuale computer non posso illudermi di andare troppo lontano.
    Ora, se dovessi acquistare un PC nuovo, ovvio che un AMD Ryzen di fascia altissima, con 128 Gb di RAM e una NVIDIA 3090 sarebbe una bella scelta, ma occorrono veramente specifiche così alte, visto anche che allo stato non faccio animazioni?
    I rendering di scene non troppo complesse variano attualmente, con Iray, dai 10 minuti alle 2 ore circa;
    2) ho provato Face Transfer, e mi pare funzioni bene. Non sono tuttavia stato in grado di ottenere gli stessi risultati con HeadShop One Click 2021, nonostante dicano che dovrebbe esser migliore. Sbaglierò io qualcosa?
    Questi programmi sono dei giocattoli che al di là di un possibile effetto "wow!" servono a poco?
    O si possono usare con profitto?
    Grazie!
    Mia personalissima opinione, ma le specifiche che hai elencato mi sembrano altissime. Con un PC AMD Ryzen (o intel) di fascia medio-alta, RAM 64GB e scheda video Geforce 2070 8GB (se poi riesci a trovare la serie 3xxx meglio anche se al momento sembra tutto deserto), hai già un sistema di ottime caratteristiche senza dover spendere un budget esagerato.
    Purtroppo quello è il minimo per Iray. sad  Con meno non finisci mai di renderizzare.
    Io davvero non capisco per quale motivo la gente preferisca spendere 5000 euro piuttosto che imparare ad usare le luci e gli shader di 3Delight o spingere di più su Filament. frown
    By
    Imago Imago March 2021 in The Commons
    By
  • DAZ Studio 4.15 holds on to RAM
    I noticed that as well, and while it's a bit annoying when you only want to restart quickly for various reasons (crash, updating morph content, etc.), better let the thing unload properly from RAM unless you want to risk corrupting files in some way...
    By
    bbaluchon bbaluchon March 2021 in Technical Help (nuts n bolts)
  • Looking for a Genesis 8 female that's in the same vein of quality as Lilith 7.
    (Before someone says, "Just use Lilith 7".  I've actualy gone a step beyond that. I've transfered Lilith 7's body morph to Genesis 8 female, and am happily using that. But I can't keep using her body type forever, I need to change it up.)
    I was hoping you guys can recommend a Genesis 8 Female that rivals Lilith 7's body type. I was hoping one of you guys have actually figured this problem out and have the solution.  Please make sure you provide a screenshot from the DAZ Studio store that shows how the body type you're recommending is equal to or better than Lilith 7's body type.
    Note:
    - Genesis 8.1 Female has a very normal and realistic body type. That's not what I'm looking for, although her skin shader is amazing and top 1% material. Her skin shader is amazing.
    - I'm not looking for a super tall body type that has no curvature or devoid of an hourglass figure.
    So you're probably thinking, just mix and match morphs, create your own... That's not an easy process. I don't have the proper eye to create body types of absolute perfection. It's a difficult process.  In order to create a body type that is in the top 1% of appeal, it would take a very long time. I don't have that level of artistic talent. I can create something in the top 5%-10%, but the top 1%? Out of my skill range unfortunately.
    As you can see, Lilith 7 has a near perfect body. Her proportions are fantastic. The artist who created her is VERY talented.
    She's tall, but she has an excellent hourglass figure.  Now, looking at the image above, which Genesis 8 female model can rival her proportions?
    Before you begin recommendations, please make sure you provide a screenshot from the DAZ store of the body type that clearly looks better than LIlith 7, or at least matches her in beauty. Remember, I'm not looking for realistic, normal body types, or tall figures with no hourglass figure, thanks!
    (Please don't just respond to this thread with random speculation.  My inquiry is very serious. It's a problem I've been needing to deal with for over a year now. I'm hoping to hear from people who have my exact same problem and mindset as me. You either know what I'm talking about or don't. Thanks!)
    By
    vozolgant vozolgant March 2021 in The Commons
    Anfy said:
    Eccomi di nuovo.
    Grazie!
    By
    Alessandro Mastronardi Alessandro Mastronardi March 2021 in The Commons
  • [Released] Ultimate Zero [Commercial]
    barbult said:
    RiverSoftArt said:
    barbult said:
    RiverSoftArt said:
    barbult said:
    RiverSoftArt said:
    barbult said:
    I've had this for a few months, but I can't find any instructions for it. I saw Drew's video, which was helpful, but did not address my questions and frustrations. I thought this was for zeroing poses and expressions, but it changes shaping morphs, too. It doesn't zero out All shaping, it zeros some and leaves others. Why? What am I doing wrong? I don't understand what the options in the dialog box do and which I should select. How do I use it to zero a figure's POSE without changing the figure's SHAPE? Surely you don't expect me to go through a huge list of things in the dialog box and uncheck all shaping morphs. That would take forever and be incredibly error prone (I've tried and never got it right). Please help me figure this out.
    I was unable to figure out a way for the script to detect that a morph alters an expression vs a shape.  The script detects all active morphs.  Unfortunately, you have to uncheck the shaping morphs (which in practice I haven't found it that bad though I may use characters with less morphs than you do)
    Thanks for responding. I like to use randomizers to add subtle variations. It can end up with a lot of morphs. I'm sad that there is no quick way to clear a body pose.
    I still don't understand the options in the dialog. What are "properties"? How do I know whether to check them or not? How do I know whether to use the zero or replace?  Are there any instructions? The brief help in the dialog itself wasn't enough to make me understand.
    Transformations are the BONE rotations only.  Properties are in the parameters pane.  For example, zeroing out hand bones will NOT zero the hand pose if the Left Hand Fist parameter/property is non-zero.
    Now that I know what Properties are, what is the difference between Zero Properties and Replace Properties? Replace them with what?
    Zero properties just sets the property (e.g., Fist) to zero and that is it.  Replace properties sets the property to zero and then modifies bone rotations to make the bones look like they are still posed by the property.  If Zero Transformations is unchecked, using Replace Properties is useful as it allows you to to remove all the properties but keep the pose (e.g., the hand will still be in a fist but not controlled by the property).  Have you ever zeroed a pose (or combined poses) and the fingers are bent extremely backwards?  This can help.
    Thank you. I understand the intent of those controls now. All this additional information has been very helpful.
    You're welcome!
    By
    RiverSoft Art RiverSoft Art March 2021 in Daz PA Commercial Products
    By
  • IES Light direction
    Daz Studio apply IES profiles on the Z-axis (Light from front to back). In order to fix it, export to OBJ , rotate Xaxis ( -90° ) and apply the OBJ as a morph. The light will be from top to bottom.
    By
    Noah LGP Noah LGP March 2021 in New Users
    Eccomi di nuovo.
    Grazie!
    By
    Anfy Anfy March 2021 in The Commons
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
